Author: wmb Date: 2009-12-11 06:22:40 +0100 (Fri, 11 Dec 2009) New Revision: 1569
Modified: cpu/x86/pc/olpc/via/after_runin.fth Log: OLPC manufacturing tests - Added final test sequencing to RUNIN phase script.
Modified: cpu/x86/pc/olpc/via/after_runin.fth =================================================================== --- cpu/x86/pc/olpc/via/after_runin.fth 2009-12-11 05:15:35 UTC (rev 1568) +++ cpu/x86/pc/olpc/via/after_runin.fth 2009-12-11 05:22:40 UTC (rev 1569) @@ -1,5 +1,7 @@ \ Post-runin boot script $Revision$
+visible + \ The Linux-based runin selftests put this file at int:\runin\olpc.fth \ after they have finished. On the next reboot, OFW thus boots this \ script instead of int:\boot\olpc.fth . This script either displays @@ -36,28 +38,209 @@ ; [then]
-h# 128 buffer: ms-value -h# 128 buffer: bd-value +d# 20 buffer: sn-buf +: sn$ ( -- adr len ) sn-buf count ;
-: set-tags-for-fqa ( -- ) - " NM" find-tag if ms-value place then - " NB" find-tag if bd-value place then +: try-get-sn ( -- ) + sn-buf 1+ d# 20 accept ( n ) + d# 12 <> if + " Wrong length, try again" .problem + exit + then + sn-buf 1+ " TSHC" comp if + " Must begin with TSHC, try again" .problem + exit + then + sn-buf 2+ sn-buf 1+ d# 11 move \ Elide the T + d# 11 sn-buf c! +;
+: get-sn ( -- ) + ." *****" + + begin + " Please Input Serial Number ......" .instructions + try-get-sn + sn-acquired? until +; + +: board#$ ( -- adr len ) + " B#" find-tag 0= abort" Missing B# tag !!!" + -null +; + +: get-info ( -- ) + get-sn +; + +0 0 2value response$ + +\ Send the board number as the request and return the response data +: final-tag-exchange ( -- ) + board#$ " %s.txt" open-temp-file + sn$ " SN:" put-key+value + " Request" submit-file + " Response" get-response to response$ +; + +0 value test-passed? +: show-result-screen ( -- ) + restore-scroller + clear-screen + test-passed? if + ." Selftest passed." cr cr cr + green-screen + else + ." Selftest failed." cr cr cr + red-screen + then + d# 2000 ms +; + +: parse-tags ( adr len -- ) + begin dup while ( adr len ) + linefeed left-parse-string ( rem$ line$ ) + ?remove-cr ( rem$ line$ ) + [char] : left-parse-string ( rem$ value$ key$ ) + dup 2 = if ( rem$ value$ key$ ) + put-tag ( rem$ ) + else ( rem$ value$ key$ ) + 4drop ( rem$ ) + then ( rem$ ) + repeat ( adr len ) + 2drop ( ) +; + +: inject-tags ( -- ) get-mfg-data
" TS" ($delete-tag) " MS" ($delete-tag) " BD" ($delete-tag) - " NM" ($delete-tag) - " NB" ($delete-tag)
- ms-value count " MS" ($add-tag) - bd-value count " BD" ($add-tag) - " FINAL" " TS" ($add-tag) + " SHIP" " TS" ($add-tag)
+ response$ parse-tags + put-mfg-data ;
+: mfg-ntp-server ( -- name$ ) + " NT" find-tag if ?-null else " 10.60.0.2" then +; +' mfg-ntp-server to ntp-servers + +d# 4 constant rtc-threshold +: verify-rtc-date ( -- ) + ." Getting time from NTP server " + begin ntp-timestamp while ." Retry " repeat ( d.timestamp ) + cr + ntp>time&date unix-seconds> ( ntp-seconds ) + today unix-seconds> ( ntp-seconds rtc-seconds ) + - ( difference ) + dup rtc-threshold > if ( difference ) + page show-fail + ." Clock lost " .d ." seconds since SMT" cr + begin halt again + else + abs rtc-threshold > if + page show-fail + ." Clock gained " .d ." seconds since SMT" cr + begin halt again + then + then +; + +: finish-final-test ( -- ) + show-result-screen + + test-passed? 0= if + ." Type a key to power off " + key drop cr power-off + then + + wait-lan + wait-scanner + + get-info + + verify-rtc-date + + cifs-connect + ." Connecting to server " final-tag-exchange ." Done" cr + cifs-disconnect + + inject-tags + + ." Powering off ..." d# 2000 ms + power-off +; + + +d# 15 to #mfgtests + +: final-tests ( -- ) + 5 #mfgtests + 5 do + i set-current-sq + refresh + d# 1000 ms + doit + pass? 0= if false to test-passed? finish-final-test unloop exit then + loop + true to test-passed? finish-final-test +; + +\ Make the "wait for SD insertion" step highly visible +dev ext +warning @ warning off +: selftest ( -- ) page show-pass selftest ; +warning ! +dend + +\ This modifies the menu to be non-interactive +: doit-once ( -- ) do-key final-tests ; +patch doit-once do-key menu-interact + +: silent-probe-usb ( -- ) + " /" ['] (probe-usb2) scan-subtree + " /" ['] (probe-usb1) scan-subtree + report-disk report-net report-keyboard +; + +: scanner? ( -- flag ) + " usb-keyboard" expand-alias if 2drop true else false then +; +: wait-scanner ( -- ) + scanner? 0= if + " Connect USB barcode scanner" .instructions + begin d# 1000 ms silent-probe-usb scanner? until + then + ; +: wired-lan? ( -- flag ) + " /usb/ethernet" locate-device if false else drop true then +; +: wait-lan ( -- ) + wired-lan? 0= if + " Connect USB Ethernet Adapter" .instructions + begin d# 1000 ms silent-probe-usb wired-lan? until + then +; +: usb-key? ( -- flag ) + " /usb/disk" locate-device if false else drop true then +; +: wait-usb-key ( -- ) + usb-key? 0= if + " Connect USB memory stick" .instructions + begin d# 1000 ms silent-probe-usb usb-key? until + then +; +: wait-connections ( -- ) + silent-probe-usb + wait-scanner + wait-lan +\ wait-usb-key +; + : fail-log-file$ ( -- name$ ) " int:\runin\fail.log" ;
: after-runin ( -- ) @@ -68,12 +251,14 @@ key drop cr cr list else - set-tags-for-fqa - " int:\runin\olpc.fth" $delete-all +\ set-tags-for-fqa +\ " int:\runin\olpc.fth" $delete-all
- page - show-pass - ." System is ready for final test" cr + 5 to test-station + true to diag-switch? + " patch final-tests play-item mfgtest-menu" evaluate + menu + \ Shouldn't get here because the menu never exits then
." Type a key to power off" @@ -82,3 +267,77 @@ ;
after-runin + +SN:SHC946009D3 +B#:QTFJCA94400297 +P#:1CL11ZU0KDU +M#:CL1 +LA:USA +CC:2222XXXXXX +F#:F6 +L#:J +S#:CL1XL00802000 +T#:TSIMG_V3.0.6 +WM:00-17-C4-B9-39-ED +MN:XO-1 +BV:Q2E34 +U#:A4112195-98FE-419A-A77B-9F33C08FF913 +SD:241109 +IM_IP:10.1.0.2 +IM_ROOT:CL1XL00802000 +IM_NAME:CL1XL00802000 +WP:0 +Countries:Alabama +LO:en_US.UTF-8 +KA:USInternational_Keyboard +KM:olpc +KL:us +KV:olpc +ak:0 +sk:20 +SG:79 +DT:20091124152811 + +SET WO=304027439 + +Use these info to check the tags inside the SPI flash. + +Write the following tags from response file: + +WP: +SG: + +Get date time from NTP server 10.1.0.1 and write MD tag + MD: 20081014T200700Z + +Set TS tag to SHIP + +Send the following information to shop flow + +SN: +M#: +U#: +P#: +B#: +LA: +CC: +F#: +L#: +S#: +T#: +BV: +TS: +SS: +FQ: +SD: +WM: +MN: +KL: +KV: +KM: +LO: +WP: +RESULT:PASS + + +
