Author: wmb Date: 2009-05-14 10:55:20 +0200 (Thu, 14 May 2009) New Revision: 1198
Added: cpu/x86/pc/olpc/via/dramtiming.fth Modified: cpu/x86/pc/olpc/via/demodram.fth cpu/x86/pc/olpc/via/ioinit.fth cpu/x86/pc/olpc/via/romreset.bth Log: Via - checkpoint with new timing computation code - not finished yet.
Modified: cpu/x86/pc/olpc/via/demodram.fth =================================================================== --- cpu/x86/pc/olpc/via/demodram.fth 2009-05-14 08:19:39 UTC (rev 1197) +++ cpu/x86/pc/olpc/via/demodram.fth 2009-05-14 08:55:20 UTC (rev 1198) @@ -14,7 +14,8 @@ \ Must use "CPU delay" to make sure VLINK is dis-connect 0 7 devfunc 47 00 04 mreg end-table d# 20 wait-us 0 3 devfunc 90 07 07 mreg end-table d# 20 wait-us \ First set DRAM Freq to invalid - 0 3 devfunc 90 07 04 mreg end-table d# 20 wait-us \ 266 MHz +\ 0 3 devfunc 90 07 03 mreg end-table d# 20 wait-us \ 200 MHz ATEST + 0 3 devfunc 90 07 04 mreg end-table d# 20 wait-us \ 266 MHz !ATEST 0 3 devfunc 6b d0 c0 mreg end-table d# 20 wait-us \ PLL Off 0 3 devfunc 6b 00 10 mreg end-table d# 20 wait-us \ PLL On 0 3 devfunc 6b c0 00 mreg end-table \ Adjustments off @@ -24,10 +25,45 @@
\ TimingSetting.c 0 3 devfunc - 61 ff 55 mreg \ Trfc, Trrd - 62 ff 8a mreg \ CL, Trp, Tras - 63 ff 49 mreg \ Twr, Twtr, Trtp - 64 ff 66 mreg \ Trp, Trcd +[ifdef] phoenix-timings + 61 ff 55 mreg \ Trfc: 0x15+8 = 29 * 3.75 = 108.75 ns, Trrd: 01 -> 3T + 62 ff 8a mreg \ Tras: 8+5=13 *3.75=48.75, 8bank-timing constraint, CL 2+2=4 + 63 ff 49 mreg \ Twr:2+2=4 *3.75=15, Trtp:1+2=3 *3.75=11.25, Twtr:1+2=3 *3.75=11.25 + 64 ff 66 mreg \ Trp 5, Trcd 5 +[then] +[ifdef] coreboot-timings + 61 ff 54 mreg \ Trfc: 0x14+8 = 28 * 3.75 = 105.00 ns, Trrd: 01 -> 3T + 62 ff 7a mreg \ Tras: 7+5=12 *3.75=45.00, 8bank-timing constraint, CL 2+2=4 + 63 ff 40 mreg \ Twr:2+2=4 *3.75=15, Trtp:0+2=2 *3.75=7.5, Twtr:0+2=2 *3.75=7.5 + 64 ff 44 mreg \ Trp 2+2=4, Trcd 2+2=4 +[then] +[ifdef] compute-timings +\ The subtractions below (e.g. "2 -") account for the way that numbers are +\ encoded in bit fields - e.g. 00b means 2T, 01b means 3T, etc. +\ The shifts below (e.g. "6 <<") move the value into the correct bit position. + + 61 3f Trfc ns>tck 8 - mreg \ Trfc: ceil(127.50/5) = 26 - 8 = 0x12 + 61 c0 Trrd ns>tck 2 - 6 << mreg \ Trrd: ceil( 7.50/5) = 2 - 0 = 0x00 + +\ 61 ff 12 mreg \ Trfc, Trrd Trfc = 0x39+8 = 65 Trrd=4T ceil(7.5ns/5ns) + + 62 07 TCL 2 - mreg \ CL 3 + 62 08 08 mreg \ 8-bank timing constraint + 62 f0 Tras ns>tck 5 - 4 << mreg \ Tras: ceil( 40.00/5) = 8 - 5 = 0x03 + +\ 62 ff 3a mreg \ CL, 8-bank constraint, Tras Tras = 8T (3+5=8) + + 63 e0 Twr ns>tck 2 - 5 << mreg \ Twr: ceil( 15.00/5) = 3 - 2 = 0x01 + 63 08 Trtp ns>tck 2 - 3 << mreg \ Trtp: ceil( 7.00/5) = 2 - 2 = 0x00 + 63 03 Twtr ns>tck 2 - mreg \ Twtr: ceil( 10.00/5) = 2 - 2 = 0x00 + +\ 63 ff 20 mreg \ Twr, Twtr, Trtp Twr=3T (15ns/5), Twtr=2T (10/5) Trtp=2T ceil(7.5/5) + + 64 0e Trp ns>tck 2 - 1 << mreg \ Trp: ceil( 15.00/5) = 3 - 2 = 0x01 + 64 e0 Trcd ns>tck 2 - 5 << mreg \ Trcd: ceil( 15.00/5) = 3 - 2 = 0x01 + +\ 64 ff 22 mreg \ Trp 3, Trcd 3 +[then] end-table
\ DRDR_BL.c @@ -154,6 +190,7 @@
h# 11 port80
+forth #ranks 2 >= assembler [if] 0 3 devfunc 40 ff 00 mreg \ Rank 1 top back to 0 to work on other ranks
@@ -164,14 +201,15 @@ end-table
DDRinit #) call +[then]
+forth #ranks 3 >= assembler [if] 0 3 devfunc 41 ff 00 mreg \ Rank 1 top back to 0 to work on other ranks end-table
h# 14 port80
-0 [if] \ This is for a DIMM in the other socket 0 3 devfunc 54 ff 00 mreg \ Disable ranks 0,1 55 ff a0 mreg \ Enable Rank 2 @@ -183,6 +221,11 @@
0 3 devfunc 42 ff 00 mreg \ Rank 2 top back to 0 to work on other ranks + end-table +[then] + +forth #ranks 4 >= assembler [if] + 0 3 devfunc 54 ff 00 mreg \ Disable ranks 0,1 55 ff 0b mreg \ Enable Rank 3 43 ff 10 mreg \ Rank 3 top @@ -197,7 +240,8 @@ [then]
0 3 devfunc - 69 03 03 mreg \ Reinstate page optimizations (03) - FF #ranks + 69 03 03 mreg \ Reinstate page optimizations (03) - FF #ranks !ATEST +\ 69 c3 c3 mreg \ Reinstate page optimizations (03) - FF #ranks ATEST 8-bank interleave
\ RankMap.c \ DRAMBankInterleave @@ -205,29 +249,37 @@ 87 ff 00 mreg \ Channel B #banks or some such - FF BA \ SizingMATypeM
- 50 ff 20 mreg \ MA Map type - ranks 0/1 type 1 - 2 bank bits, 10 column bits + 50 ff 20 mreg \ MA Map type - ranks 0/1 type 1 - 2 bank bits, 10 column bits !ATEST +\ 50 ff a1 mreg \ 1T Command Rate, RMA Map type - ranks 0/1 type 5 - 3 bank bits, 14 row bits, 10 col bits ATEST 51 ff 60 mreg \ "Reserved" 52 ff 33 mreg \ Bank interleave on A17, A18, and - 53 ff 3f mreg \ A19 (but BA2 off because 4 banks), Rank interleave on A20 and A21 + 53 ff 3f mreg \ A19 (but BA2 off because 4 banks), Rank interleave on A20 and A21 !ATEST +\ 53 ff bf mreg \ BA2 on (80), A19, Rank interleave on A20 and A21 ATEST \ Different interleave bits might improve performance on some workloads
- 54 ff 89 mreg \ Rank map A 0/1 + 54 ff 89 mreg \ Rank map A 0/1 !ATEST +\ 54 ff 80 mreg \ Rank map A 0/1 ATEST Rank 0 only 55 ff 00 mreg \ Rank map A 2/3 56 ff 00 mreg \ Rank map B ? 57 ff 00 mreg \ Rank map B ?
- 40 ff 04 mreg \ Rank top 0 - 41 ff 08 mreg \ Rank top 1 + 40 ff 04 mreg \ Rank top 0 !ATEST +\ 40 ff 10 mreg \ Rank top 0 ATEST 1 GiB + 41 ff 08 mreg \ Rank top 1 !ATEST +\ 41 ff 00 mreg \ Rank top 1 ATEST + 42 ff 00 mreg \ Rank top 2 43 ff 00 mreg \ Rank top 3
48 ff 00 mreg \ Rank base 0 - 49 ff 04 mreg \ Rank base 1 + 49 ff 04 mreg \ Rank base 1 !ATEST +\ 49 ff 00 mreg \ Rank base 1 ATEST 4a ff 00 mreg \ Rank base 2 4b ff 00 mreg \ Rank base 3 end-table
- 20 8f60 config-wb \ DRAM Bank 7 ending address - controls DMA upstream + 20 8f60 config-wb \ DRAM Bank 7 ending address - controls DMA upstream !ATEST +\ 40 8f60 config-wb \ DRAM Bank 7 ending address - controls DMA upstream ATEST 0388 config-rb ax bx mov 0385 config-setup bx ax mov al dx out \ Copy Low Top from RO reg 88 to reg 85 0388 config-rb ax bx mov 8fe5 config-setup bx ax mov al dx out \ Copy Low Top from RO reg 88 to SB Low Top e5
@@ -261,7 +313,8 @@
\ FinalSetting.c \ RefreshCounter - 6a ff 86 mreg \ Refresh interval - FF frequency + 6a ff 86 mreg \ Refresh interval - FF frequency !ATEST +\ 6a ff ca mreg \ Refresh interval - FF frequency ATEST
\ DRAMRegFinalValue 60 00 d0 mreg \ Fast turn-around
Added: cpu/x86/pc/olpc/via/dramtiming.fth =================================================================== --- cpu/x86/pc/olpc/via/dramtiming.fth (rev 0) +++ cpu/x86/pc/olpc/via/dramtiming.fth 2009-05-14 08:55:20 UTC (rev 1198) @@ -0,0 +1,40 @@ +d# 5.00 value Tck +\ Compute ceil(ns/tck) +: ns>tck ( ns -- tck ) Tck + 1- Tck / ; + + +[ifdef] xo-board +\ DDR-400 timings for HY5PS1G4831C +d# 5.00 to Tck + +d# 127.50 constant Trfc +d# 7.50 constant Trrd +d# 3 constant TCL +d# 40.00 constant Tras +d# 15.00 constant Twr +d# 7.50 constant Trtp +d# 10.00 constant Twtr +d# 15.00 constant Trp +d# 15.00 constant Trcd + +1 constant #ranks +8 constant #banks +[then] + +[ifdef] demo-board +\ DDR-533 timings for Micron MT8HTF6464HDY DIMM +d# 3.75 to Tck + +d# 105.00 constant Trfc +d# 10.00 constant Trrd +d# 4 constant TCL +d# 45.00 constant Tras +d# 15.00 constant Twr +d# 7.50 constant Trtp +d# 7.00 constant Twtr +d# 15.00 constant Trp +d# 15.00 constant Trcd + +2 constant #ranks +4 constant #banks +[then]
Modified: cpu/x86/pc/olpc/via/ioinit.fth =================================================================== --- cpu/x86/pc/olpc/via/ioinit.fth 2009-05-14 08:19:39 UTC (rev 1197) +++ cpu/x86/pc/olpc/via/ioinit.fth 2009-05-14 08:55:20 UTC (rev 1198) @@ -179,8 +179,8 @@ bc ff 00 mreg \ SPI MMIO Base Address 15:8 (address is fed30000) bd ff d3 mreg \ SPI MMIO Base Address 23:16 be ff fe mreg \ SPI MMIO Base Address 31:24 - d0 f0 00 mreg \ SMBUS IO Base Address low (port is 4100) - d1 ff 41 mreg \ SMBUS IO Base Address high + d0 f0 00 mreg \ SMBUS IO Base Address low (port is 0500) + d1 ff 05 mreg \ SMBUS IO Base Address high d2 0f 01 mreg \ Enable SMBUS and set other characteristics e2 80 80 mreg \ Inhibit C4 during USB isochronous transaction e4 ff a0 mreg \ Enable short C3/C4 (80), select various multi-function pins
Modified: cpu/x86/pc/olpc/via/romreset.bth =================================================================== --- cpu/x86/pc/olpc/via/romreset.bth 2009-05-14 08:19:39 UTC (rev 1197) +++ cpu/x86/pc/olpc/via/romreset.bth 2009-05-14 08:55:20 UTC (rev 1198) @@ -56,6 +56,8 @@
fload ${BP}/cpu/x86/pc/olpc/via/startmacros.fth \ Via-oriented startup macros
+fload ${BP}/cpu/x86/pc/olpc/via/dramtiming.fth + start-assembling
hex
