Author: pgf Date: Fri Sep 28 21:17:49 2012 New Revision: 3343 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3343
Log: usb: add a clock-names property for USBPHYCLK
Modified: cpu/arm/olpc/usb.fth
Modified: cpu/arm/olpc/usb.fth ============================================================================== --- cpu/arm/olpc/usb.fth Fri Sep 28 21:00:15 2012 (r3342) +++ cpu/arm/olpc/usb.fth Fri Sep 28 21:17:49 2012 (r3343) @@ -8,6 +8,7 @@ my-space swap " map-in" $call-parent h# 100 + ( adr ) ; : my-map-out ( adr len -- ) swap h# 100 - swap " map-out" $call-parent ; + " USBPHYCLK" " clock-names" string-property " /pmua" encode-phandle 5 encode-int encode+ " clocks" property d# 44 " interrupts" integer-property
