Author: wmb Date: Mon Oct 3 23:16:03 2011 New Revision: 2568 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2568
Log: OLPC 1.75 - fixed error in currently-unused code introduced by a recent change.
Modified: cpu/arm/mmp2/dramrecal.fth
Modified: cpu/arm/mmp2/dramrecal.fth ============================================================================== --- cpu/arm/mmp2/dramrecal.fth Mon Oct 3 23:13:33 2011 (r2567) +++ cpu/arm/mmp2/dramrecal.fth Mon Oct 3 23:16:03 2011 (r2568) @@ -151,8 +151,8 @@ mov pc,r1 c;
-: apbc-clr-rst ( offset -- ) +apbc 4 swap io-clr ; -: apbc-set-rst ( offset -- ) +apbc 4 swap io-set ; +: apbc-clr-rst ( offset -- ) 4 swap +apbc io-clr ; +: apbc-set-rst ( offset -- ) 4 swap +apbc io-set ;
: disable-apbc-clks ( -- ) \ 3 h# 38 +apbc io-clr \ GPIO @@ -570,10 +570,10 @@ h# b0 d# 15 af! \ Wake SP on rotate key h# 220 d# 71 af! \ Wake SP on KBD CLK falling edge h# 221 d# 160 af! \ Wake SP on TPD CLK falling edge - h# 4c +mpmu h# 20.0000 io-set \ Keypress wakes SP + h# 20.0000 h# 4c +mpmu io-set \ Keypress wakes SP ['] disable-int40 d# 40 interrupt-handler! d# 40 enable-interrupt \ SP to PJ4 communications interrupt - 1 h# 29.00cc 1 io-clr \ Unmask the inter-processor communications interrupt + 1 h# 29.00cc io-clr \ Unmask the inter-processor communications interrupt ;
: breadcrumb ( n -- ) h# d000.0110 l! ;
