Author: wmb Date: Tue Aug 3 11:53:23 2010 New Revision: 1901 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/1901
Log: OLPC XO-1.5 - Reduce the SD clock to 33 MHz for Windows; Windows doesn't work reliably otherwise.
Modified: cpu/x86/pc/olpc/via/acpi.fth
Modified: cpu/x86/pc/olpc/via/acpi.fth ============================================================================== --- cpu/x86/pc/olpc/via/acpi.fth Tue Aug 3 10:19:53 2010 (r1900) +++ cpu/x86/pc/olpc/via/acpi.fth Tue Aug 3 11:53:23 2010 (r1901) @@ -319,6 +319,9 @@ : rm-platform-fixup ( -- ) \ Disable the internal SD to prevent Windows from making it C: h# f9 h# 6099 config-b! + h# 80 h# 6088 config-b! \ Set timeout clock 0:33Mhz + h# 00 h# 6089 config-b! \ Set max clock to 33Mhz + true windows-mode-adr ! \ Tell the resume code to do it too
more-platform-fixup
