Author: wmb Date: Sat Jul 16 13:45:37 2011 New Revision: 2375 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2375
Log: OLPC XO-1.75 - Synchronized the boardgpio file in the OFW tree with the master one in the cforth tree.
Modified: cpu/arm/olpc/1.75/boardgpio.fth
Modified: cpu/arm/olpc/1.75/boardgpio.fth ============================================================================== --- cpu/arm/olpc/1.75/boardgpio.fth Sat Jul 16 13:40:24 2011 (r2374) +++ cpu/arm/olpc/1.75/boardgpio.fth Sat Jul 16 13:45:37 2011 (r2375) @@ -18,45 +18,36 @@ d# 58 gpio-dir-out \ WLAN_RESET# d# 73 gpio-dir-out \ CAM_RST
+ d# 125 gpio-set \ EC_SPI_ACK + d# 125 gpio-dir-out \ EC_SPI_ACK + d# 146 gpio-dir-out \ HUB_RESET# + d# 148 gpio-clr \ SOC_EN_KBD_PWR# + d# 148 gpio-dir-out \ SOC_EN_KBD_PWR# + d# 155 gpio-clr + d# 155 gpio-dir-out \ EC_SPI_CMD [ifdef] cl2-a1 d# 97 gpio-dir-out \ RTC_SCK d# 98 gpio-dir-out \ RTC_SDA -[else] - d# 53 gpio-set \ RTC_SCK - d# 53 gpio-dir-out \ RTC_SCK - d# 103 gpio-dir-out \ EC_EDI_DO - d# 104 gpio-set \ EC_EDI_CS# - d# 104 gpio-dir-out \ EC_EDI_CS# - d# 106 gpio-dir-out \ EC_EDI_CLK - d# 143 gpio-clr - d# 143 gpio-dir-out \ MIC_AC#/DC - d# 149 gpio-clr \ eMMC_RST# - d# 149 gpio-dir-out \ eMMC_RST# -[then] - - d# 125 gpio-set \ EC_SPI_ACK - d# 125 gpio-dir-out \ EC_SPI_ACK -[ifdef] cl2-a1 - d# 145 gpio-dir-out \ EN_CAM_PWR -[else] - d# 150 gpio-clr \ EN_CAM_PWR - d# 150 gpio-dir-out \ EN_CAM_PWR -[then] - d# 146 gpio-dir-out \ HUB_RESET# -[ifdef] cl2-a1 - d# 151 gpio-dir-out \ DCONLOAD -[else] - d# 142 gpio-dir-out \ DCONLOAD -[then] - d# 155 gpio-clr - d# 155 gpio-dir-out \ EC_SPI_CMD - -[ifdef] cl2-a1 - d# 162 gpio-dir-out \ DCON_SCL - d# 163 gpio-dir-out \ DCON_SDA -[else] - d# 161 gpio-dir-out \ DCON_SCL - d# 110 gpio-dir-out \ DCON_SDA + d# 145 gpio-dir-out \ EN_CAM_PWR + d# 151 gpio-dir-out \ DCONLOAD + d# 162 gpio-dir-out \ DCON_SCL + d# 163 gpio-dir-out \ DCON_SDA +[else] + d# 53 gpio-set \ RTC_SCK + d# 53 gpio-dir-out \ RTC_SCK + d# 104 gpio-set \ EC_EDI_CS# + d# 104 gpio-dir-out \ EC_EDI_CS# + d# 105 gpio-dir-out \ EC_EDI_MOSI + d# 106 gpio-dir-out \ EC_EDI_CLK + d# 110 gpio-dir-out \ DCON_SDA + d# 142 gpio-dir-out \ DCONLOAD + d# 143 gpio-clr \ MIC_AC#/DC + d# 143 gpio-dir-out \ MIC_AC#/DC + d# 149 gpio-clr \ eMMC_RST# + d# 149 gpio-dir-out \ eMMC_RST# + d# 150 gpio-clr \ EN_CAM_PWR + d# 150 gpio-dir-out \ EN_CAM_PWR + d# 161 gpio-dir-out \ DCON_SCL [then] ;
@@ -120,20 +111,20 @@ 3 af, \ GPIO_44 - SPI_MOSI 3 af, \ GPIO_45 - SPI_CLK 3 af, \ GPIO_46 - SPI_FRM - 3 af, \ GPIO_47 - G_SENSOR_SDL (TWSI6) - 3 af, \ GPIO_48 - G_SENSOR_SDA + 3 pull-up, \ GPIO_47 - G_SENSOR_SDL (TWSI6) + 3 pull-up, \ GPIO_48 - G_SENSOR_SDA no-update, \ GPIO_49 - Not connected (TP62) no-update, \ GPIO_50 - Not connected (TP114) no-update, \ GPIO_51 - Not connected (TP59) no-update, \ GPIO_52 - Not connected (TP113) -\ 2 af, \ GPIO_53 - RTC_SCK (TWSI2) if R124 populated -\ 2 af, \ GPIO_54 - RTC_SDA (TWSI2) if R125 populated [ifdef] cl2-a1 no-update, \ GPIO_53 - Not connected if nopop R124 to use TWSI6 for RTC no-update, \ GPIO_54 - Not connected if nopop R125 to use TWSI6 for RTC [else] - 0 af, \ GPIO_53 - RTC_SCK - 0 af, \ GPIO_54 - RTC_SDA + 2 af, \ GPIO_53 - RTC_SCK (TWSI2) if R124 populated + 2 af, \ GPIO_54 - RTC_SDA (TWSI2) if R125 populated +\ 0 af, \ GPIO_53 - RTC_SCK +\ 0 af, \ GPIO_54 - RTC_SDA [then] no-update, \ GPIO_55 - Not connected (TP51) [ifdef] cl2-a1 @@ -157,8 +148,8 @@ 1 af, \ GPIO_69 - PIXMCLK 1 af, \ GPIO_70 - PIXCLK
- 1 af, \ GPIO_71 - EC_SCL (TWSI3) - 1 af, \ GPIO_72 - EC_SDA + 0 af, \ GPIO_71 - SOC_KBD_CLK \ Was EC_SCL (TWSI3) + 0 af, \ GPIO_72 - SOC_KBD_DAT \ Was EC_SDA 0 af, \ GPIO_73 - CAM_RST (use as GPIO out)
1 af, \ GPIO_74 - GFVSYNC @@ -193,7 +184,7 @@ 0 af, \ GPIO_97 - RTC_SCK (bitbang) if R100 populated 0 af, \ GPIO_98 - RTC_SDA (bitbang) if R106 populated [else] - 0 af, \ GPIO_96 - EXT_MIC_PLUG + 0 pull-up, \ GPIO_96 - EXT_MIC_PLUG 0 af, \ GPIO_97 - HP_PLUG no-update, \ GPIO_98 - Not connected [then] @@ -214,7 +205,7 @@ 1 af, \ GPIO_105 - EC_EDI_DI 1 af, \ GPIO_106 - EC_EDI_CLK [then] - 0 af, \ GPIO_107 - ND_IO[4] + 1 af, \ GPIO_107 - (ND_IO[4]) - SOC_TPD_DAT
1 af, \ GPIO_108 - CAM_SDL - Use as GPIO, bitbang 1 af, \ GPIO_109 - CAM_SDA - Use as GPIO, bitbang @@ -225,10 +216,10 @@ 0 af, \ GPIO_112 - ND_RDY[0] [else] 1 pull-up, \ GPIO_110 - DCON_SDA - 2 af, \ GPIO_111 - eMMC_D0 - 2 af, \ GPIO_112 - eMMC_CMD + 2 +fast af, \ GPIO_111 - eMMC_D0 + 2 +fast af, \ GPIO_112 - eMMC_CMD [then] - 3 af, \ GPIO_113 - (SM_RDY) - MSD_CMD aka SD1_CMD (externally pulled up) + 3 +fast af, \ GPIO_113 - (SM_RDY) - MSD_CMD aka SD1_CMD (externally pulled up) 1 af, \ GPIO_114 - G_CLK_OUT - Not connected (TP93)
4 af, \ GPIO_115 - UART3_TXD (J4) @@ -246,21 +237,21 @@ \ 0 af, \ GPIO_125 - EC_SPI_ACK 0 pull-up, \ GPIO_125 - EC_SPI_ACK
- 3 pull-up, \ GPIO_126 - MSD_DATA2 AKA SD1_DATA2 - 3 pull-up, \ GPIO_127 - MSD_DATA0 AKA SD1_DATA0 + 3 +fast af, \ GPIO_126 - MSD_DATA2 AKA SD1_DATA2 + 3 +fast af, \ GPIO_127 - MSD_DATA0 AKA SD1_DATA0 0 af, \ GPIO_128 - EB_MODE# 0 af, \ GPIO_129 - LID_SW# - 3 pull-up, \ GPIO_130 - MSD_DATA3 AKA SD1_DATA3 - 1 +fast pull-up, \ GPIO_131 - SD_DATA3 AKA SD2_DATA3 - 1 +fast pull-up, \ GPIO_132 - SD_DATA2 AKA SD2_DATA2 - 1 +fast pull-up, \ GPIO_133 - SD_DATA1 AKA SD2_DATA1 - 1 +fast pull-up, \ GPIO_134 - SD_DATA0 AKA SD2_DATA0 - 3 pull-up, \ GPIO_135 - MSD_DATA1 AKA SD1_DATA1 -\ 1 +fast pull-up, \ GPIO_136 - SD_CMD AKA SD2_CMD - 1 +fast af, \ GPIO_136 - SD_CMD AKA SD2_DATA - CMD is pulled up externally + 3 +fast af, \ GPIO_130 - MSD_DATA3 AKA SD1_DATA3 + 1 +fast af, \ GPIO_131 - SD_DATA3 AKA SD2_DATA3 + 1 +fast af, \ GPIO_132 - SD_DATA2 AKA SD2_DATA2 + 1 +fast af, \ GPIO_133 - SD_DATA1 AKA SD2_DATA1 + 1 +fast af, \ GPIO_134 - SD_DATA0 AKA SD2_DATA0 + 3 +fast af, \ GPIO_135 - MSD_DATA1 AKA SD1_DATA1 +\ 1 +fast pull-up, \ GPIO_136 - SD_CMD AKA SD2_CMD + 1 +fast af, \ GPIO_136 - SD_CMD AKA SD2_CMD - CMD is pulled up externally no-update, \ GPIO_137 - Not connected (TP111) - 3 pull-up, \ GPIO_138 - MSD_CLK AKA SD1_CLK - 1 +fast pull-up, \ GPIO_139 - SD_CLK AKA SD2_CLK + 3 +fast af, \ GPIO_138 - MSD_CLK AKA SD1_CLK + 1 +fast af, \ GPIO_139 - SD_CLK AKA SD2_CLK no-update, \ GPIO_140 - Not connected if R130 is nopop \ 1 af, \ GPIO_140 - (SD_CD# if R130 is populated) 1 af, \ GPIO_141 - SD_WP# AKA SD2_WP# @@ -281,7 +272,7 @@ 1 af, \ GPIO_146 - HUB_RESET#
0 af, \ GPIO_147 - ND_WE_N - 0 af, \ GPIO_148 - ND_RE_N + 1 af, \ GPIO_148 - ND_RE_N - SOC_EN_KBD_PWR# [ifdef] cl2-a1 0 af, \ GPIO_149 - ND_CLE 0 af, \ GPIO_150 - ND_ALE @@ -289,7 +280,7 @@ [else] 1 af, \ GPIO_149 - eMMC_RST# 1 af, \ GPIO_150 - EN_CAM_PWR - 2 af, \ GPIO_151 - eMMC_CLK + 2 +fast af, \ GPIO_151 - eMMC_CLK [then] 1 af, \ GPIO_152 - (SM_BELn) - Not connected (TP40) 1 af, \ GPIO_153 - (SM_BEHn) - Not connected (TP105) @@ -299,7 +290,7 @@ no-update, \ GPIO_157 - PRI_TDS (JTAG) no-update, \ GPIO_158 - PRI_TDK (JTAG) no-update, \ GPIO_159 - PRI_TDO (JTAG) - 0 af, \ GPIO_160 - ND_RDY[1] + 1 af, \ GPIO_160 - (ND_RDY[1]) - SOC_TPD_CLK [ifdef] cl2-a1 1 af, \ GPIO_161 - ND_IO[12] - Not connected (TP 44) 1 af, \ GPIO_162 - (ND_IO[11]) - DCON_SCL @@ -311,13 +302,13 @@ 0 af, \ GPIO_168 - ND_IO[0] [else] 1 af, \ GPIO_161 - DCON_SCL - 2 af, \ GPIO_162 - eMMC_D6 - 2 af, \ GPIO_163 - eMMC_D4 - 2 af, \ GPIO_164 - eMMC_D2 - 2 af, \ GPIO_165 - eMMC_D7 - 2 af, \ GPIO_166 - eMMC_D5 - 2 af, \ GPIO_167 - eMMC_D3 - 2 af, \ GPIO_168 - eMMC_D1 + 2 +fast af, \ GPIO_162 - eMMC_D6 + 2 +fast af, \ GPIO_163 - eMMC_D4 + 2 +fast af, \ GPIO_164 - eMMC_D2 + 2 +fast af, \ GPIO_165 - eMMC_D7 + 2 +fast af, \ GPIO_166 - eMMC_D5 + 2 +fast af, \ GPIO_167 - eMMC_D3 + 2 +fast af, \ GPIO_168 - eMMC_D1 [then]
: init-mfprs
