Author: wmb Date: 2009-12-15 05:16:21 +0100 (Tue, 15 Dec 2009) New Revision: 1608
Modified: dev/hdaudio/test.fth Log: HDaudio selftest - fixed channel format problem that was causing low volume for speaker playback test.
Modified: dev/hdaudio/test.fth =================================================================== --- dev/hdaudio/test.fth 2009-12-15 02:55:53 UTC (rev 1607) +++ dev/hdaudio/test.fth 2009-12-15 04:16:21 UTC (rev 1608) @@ -15,6 +15,7 @@ ; : speaker-test ( -- ) h# 19 to node + 2 to #channels pin-sense? if ." Disconnect headphones to continue.. " begin ?key-abort pin-sense? 0= until cr @@ -25,6 +26,7 @@
: headphones-test ( -- ) h# 19 to node + 2 to #channels pin-sense? 0= if ." Connect headphones to continue.. " begin ?key-abort pin-sense? until cr @@ -34,6 +36,13 @@ h# 1f to node power-on \ turn speaker back on ;
+: louder-mic-test ( -- ) + ." Recording ..." cr + record + ." Playing ..." cr + d# 0 set-volume play +; + : builtin-mic-test ( -- ) h# 1a to node pin-sense? if @@ -42,7 +51,7 @@ then ." Press a key to test recording / playback on the built-in microphone.. " key drop cr - mic-test + louder-mic-test ;
: external-mic-test ( -- )
