Author: wmb Date: Thu Aug 18 22:46:27 2011 New Revision: 2469 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2469
Log: ARM memory test - minor formatting change to align code with x86 version.
Modified: cpu/arm/memtest.fth
Modified: cpu/arm/memtest.fth ============================================================================== --- cpu/arm/memtest.fth Thu Aug 18 22:45:29 2011 (r2468) +++ cpu/arm/memtest.fth Thu Aug 18 22:46:27 2011 (r2469) @@ -89,6 +89,7 @@
2dup afill mask @ masked-atest ; + code random-fill ( adr len data index polynomial -- ) ldmia sp!,{r1,r2,r3,r4} \ tos:poly r1:index r2:data r3:len r4:adr
@@ -159,6 +160,7 @@
mov tos,#0 c; + \ Polynomials for maximal length LFSRs for different bit lengths \ The values come from the Wikipedia article for Linear Feedback Shift Register and from \ http://www.xilinx.com/support/documentation/application_notes/xapp052.pdf @@ -206,6 +208,7 @@ defer .lfsr-mem-error : (.lfsr-mem-error) ( adr len data index remain -- adr len data index remain ) push-hex + ??cr ." Error at address " 4 pick 2 pick la+ dup 8 u.r ( adr len data index remain err-adr ) ." - expected " 3 pick 8 u.r ( adr len data index remain err-adr ) ." got " l@ 8 u.r cr @@ -232,6 +235,7 @@ repeat ( r: polynomial ) r> drop ; + \ Not truly random - uses LFSR sequences : random-test ( adr len -- error? ) " Random address and data test" show-status
