Author: wmb Date: 2009-12-12 03:49:14 +0100 (Sat, 12 Dec 2009) New Revision: 1586
Modified: cpu/x86/pc/olpc/via/assy.fth cpu/x86/pc/olpc/via/runin.fth cpu/x86/pc/olpc/via/smt.fth Log: OLPC manufacturing test scripts - checkpoint.
Modified: cpu/x86/pc/olpc/via/assy.fth =================================================================== --- cpu/x86/pc/olpc/via/assy.fth 2009-12-11 22:49:18 UTC (rev 1585) +++ cpu/x86/pc/olpc/via/assy.fth 2009-12-12 02:49:14 UTC (rev 1586) @@ -40,13 +40,21 @@ then ;
-: put-tag ( value$ key$ -- ) +: special-tag? ( value$ key$ -- true | value$ key$ false ) 2dup " KA" $= if ( value$ key$ ) - put-ka-tag exit + put-ka-tag true exit then ( value$ key$ ) + false +; + +: put-ascii-tag ( value$ name$ -- ) 2swap dup if add-null then 2swap ( value$' key$ ) ($add-tag) ( ) ; +: put-tag ( value$ key$ -- ) + special-tag? if exit then ( value$ key$ ) + put-ascii-tag +;
: .instructions ( adr len -- ) cr blue-letters type black-letters cr @@ -192,9 +200,13 @@
: inject-tags ( -- ) flash-write-enable - clear-mfg-buf + get-mfg-data
- " " " ww" put-tag + " TS" ($delete-tag) + " MS" ($delete-tag) + " BD" ($delete-tag) + " NT" ($delete-tag) + sn$ " SN" put-tag fwver$ " BV" put-tag swid$ " T#" put-tag @@ -202,12 +214,12 @@ mac$ " WM" put-tag swdl-date$ " SD" put-tag
-\ " EN" " SS" put-tag -\ " NA" " FQ" put-tag + response$ parse-tags
- response$ parse-tags + flash-write-enable (put-mfg-data) - flash-write-disable + no-kbc-reboot + kbc-on ;
: make-assy-request ( -- )
Modified: cpu/x86/pc/olpc/via/runin.fth =================================================================== --- cpu/x86/pc/olpc/via/runin.fth 2009-12-11 22:49:18 UTC (rev 1585) +++ cpu/x86/pc/olpc/via/runin.fth 2009-12-12 02:49:14 UTC (rev 1586) @@ -2,6 +2,16 @@
visible
+\ Location of the files containing KA tag data +: ka-dir$ ( -- adr len ) " http:\10.1.0.1\ka" ; + +: nocase-$= ( $1 $2 -- flag ) + rot tuck <> if ( adr1 adr2 len2 ) + 3drop false exit ( -- false ) + then ( adr1 adr2 len2 ) + caps-comp 0= ( flag ) +; + \ The Linux-based runin selftests put this file at int:\runin\olpc.fth \ after they have finished. On the next reboot, OFW thus boots this \ script instead of int:\boot\olpc.fth . This script either displays @@ -67,32 +77,110 @@ d# 2000 ms ;
+: put-ascii-tag ( value$ key$ -- ) + 2swap dup if add-null then 2swap ( value$' key$ ) + ($add-tag) ( ) +; +: put-ka-tag ( value$ key$ -- ) + 2over 8 min ka-dir$ " %s%s" sprintf ( value$ key$ filename$ ) + $read-file if ( value$ key$ ) + ." ERROR: No KA tag file for " 2swap type cr ( key$ ) + 2drop ( ) + else ( value$ key$ file-data$ ) + 2swap ($add-tag) ( value$ ) + 2drop ( ) + then +; + +false value write-protect? + +: special-tag? ( value$ key$ -- true | value$ key$ false ) + 2dup " KA" $= if ( value$ key$ ) + put-ka-tag ( ) + true exit ( -- true ) + then ( value$ key$ ) + 2dup " WP" nocase-$= if ( value$ key$ ) + 2drop " 0" $= 0= to write-protect? ( ) + true exit ( -- true ) + then ( value$ key$ ) + 2dup " ak" nocase-$= if ( value$ key$ ) + 2drop " 0" $= 0= if ( ) + " " " ak" ($add-tag) ( ) + then ( ) + true exit ( -- true ) + then ( value$ key$ ) + false ( value$ key$ false ) +; +: put-tag ( value$ key$ -- ) + special-tag? if exit then + put-ascii-tag +; +: show-tag ( value$ -- ) + tag-printable? if ?-null type else wrapped-cdump then +; +: handle-tag ( value$ key$ -- ) + 2dup find-tag if ( value$ key$ old-value$ ) \ Tag already exists, check it + 2over " KA" $= 0= if ?-null then ( value$ key$ old-value$' ) + 2>r 2over 2r@ $= if ( value$ key$ r: old-value$' ) + 2drop 2drop r> 2drop ( ) + else ( value$ key$ r: old-value$' ) + type ." tag changed!" cr ( value$ r: old-value$' ) + ." Old: " r> show-tag cr ( value$ ) + ." New: " show-tag cr ( ) + then + else ( value$ key$ ) \ New tag, add it + put-tag + then +; + : parse-tags ( adr len -- ) begin dup while ( adr len ) linefeed left-parse-string ( rem$ line$ ) ?remove-cr ( rem$ line$ ) [char] : left-parse-string ( rem$ value$ key$ ) dup 2 = if ( rem$ value$ key$ ) - put-tag ( rem$ ) + handle-tag ( rem$ ) else ( rem$ value$ key$ ) 4drop ( rem$ ) then ( rem$ ) repeat ( adr len ) 2drop ( ) ; - +: format-date ( s m h d m y -- adr len ) + push-decimal + >r >r >r >r >r >r + <# + [char] Z hold + r> u# u# drop + r> u# u# drop + r> u# u# drop + [char] T hold + r> u# u# drop + r> u# u# drop + r> u# u# u# u# + u#> + pop-base +; +: make-md-tag ( -- ) + ntp>time&date ( s m h d m y ) format-date " MD" put-ascii-tag +; : inject-tags ( -- ) get-mfg-data
" TS" ($delete-tag) " MS" ($delete-tag) " BD" ($delete-tag) - + make-md-tag " SHIP" " TS" ($add-tag)
- put-mfg-data + flash-write-enable + (put-mfg-data) + \ Change "ww" to "wp" if we want security to be enabled + write-protect? if " wp" h# efffe write-spi-flash then + no-kbc-reboot + kbc-on ;
: mfg-ntp-server ( -- name$ ) @@ -102,6 +190,7 @@
d# 4 constant rtc-threshold : verify-rtc-date ( -- ) +\ XXX check RTC power lost bit ." Getting time from NTP server " begin ntp-timestamp while ." Retry " repeat ( d.timestamp ) cr @@ -121,6 +210,50 @@ then ;
+: put-key:value ( value$ key$ -- ) " %s:%s" sprint put-key-line ; + +: upload-tag ( data$ tag$ -- ) + 2dup " wp" $= if ( data$ tag$ ) + 4drop " 1" " WP" put-key:value ( ) + exit + then + 2dup " ww" $= if ( data$ tag$ ) + 4drop " 0" " WP" put-key:value ( ) + exit + then + 2dup " ak" $= if ( data$ tag$ ) + 4drop " 1" " ak" put-key:value ( ) + exit + then + 2dup " KA" $= if ( data$ tag$ ) + 4drop ( ) + exit + then + 2dup " SG" $= if ( data$ tag$ ) + 4drop ( ) + exit + then ( data$ tag$ ) + + put-key:value ( ) +; + +: upload-tags ( -- ) + mfg-data-top ( adr ) + begin another-tag? while ( adr' data$ tname-adr ) + 2 upload-tag ( adr ) + repeat ( adr ) + drop +; + + +\ Upload the result data +: final-result ( -- ) + smt-filename$ open-temp-file + upload-tags + test-passed? if " PASS" else " FAIL" then " RESULT=" put-key+value + " Result" submit-file +; + : finish-final-test ( -- ) show-result-screen
@@ -136,12 +269,17 @@
verify-rtc-date
- cifs-connect - ." Connecting to server " final-tag-exchange ." Done" cr - cifs-disconnect + ." Getting final tags .. " + cifs-connect final-tag-exchange cifs-disconnect + ." Done" cr
inject-tags
+ cifs-connect final-result cifs-disconnect + \ " int:\runin\olpc.fth" $delete-all + + " int:\runin\olpc.fth" " int:\runin\final.fth" $rename + ." Powering off ..." d# 2000 ms power-off ; @@ -206,6 +344,13 @@
: fail-log-file$ ( -- name$ ) " int:\runin\fail.log" ;
+\ The operator can type this to reset the state to run +\ the Linux-based runin tests again. +: rerunin ( -- ) + " int:\runin\olpc.fth" $delete-all + " int:\runin\fail.log" $delete-all +; + : after-runin ( -- ) fail-log-file$ $read-file 0= if ( adr len ) page @@ -214,11 +359,13 @@ key drop cr cr list else + \ set-tags-for-fqa -\ " int:\runin\olpc.fth" $delete-all
" patch final-tests play-item mfgtest-menu" evaluate + true to diag-switch? menu + false to diag-switch? \ Shouldn't get here because the menu never exits then
@@ -229,6 +376,8 @@
after-runin
+0 [if] + SN:SHC946009D3 B#:QTFJCA94400297 P#:1CL11ZU0KDU @@ -244,11 +393,11 @@ BV:Q2E34 U#:A4112195-98FE-419A-A77B-9F33C08FF913 SD:241109 -IM_IP:10.1.0.2 -IM_ROOT:CL1XL00802000 -IM_NAME:CL1XL00802000 + IM_IP:10.1.0.2 + IM_ROOT:CL1XL00802000 + IM_NAME:CL1XL00802000 WP:0 -Countries:Alabama + Countries:Alabama LO:en_US.UTF-8 KA:USInternational_Keyboard KM:olpc @@ -276,29 +425,33 @@ Send the following information to shop flow
SN: +B#: +P#: M#: -U#: -P#: -B#: LA: CC: F#: L#: S#: T#: +WM: +MN: BV: -TS: -SS: -FQ: +U#: SD: -WM: -MN: +WP: +LO: + KA +KM: KL: KV: -KM: -LO: -WP: + ak + sk + SG + DT + TS: test station + SS: smt status + FQ: ?? + RESULT:PASS - - - +[then]
Modified: cpu/x86/pc/olpc/via/smt.fth =================================================================== --- cpu/x86/pc/olpc/via/smt.fth 2009-12-11 22:49:18 UTC (rev 1585) +++ cpu/x86/pc/olpc/via/smt.fth 2009-12-12 02:49:14 UTC (rev 1586) @@ -125,10 +125,12 @@ get-opid ;
+0 value test-passed? + \ Upload the result data -: smt-result ( pass? -- ) +: smt-result ( -- ) smt-filename$ open-temp-file - if " PASS" else " FAIL" then " RESULT=" put-key+value + test-passed? if " PASS" else " FAIL" then " RESULT=" put-key+value " PROCESS=FVT" put-key-line " STATION=" put-key-line " OPID=" put-key-line @@ -149,11 +151,6 @@
: clear-mfg-buf ( -- ) mfg-data-buf /flash-block h# ff fill ;
-: put-ascii-tag ( value$ key$ -- ) - 2swap dup if add-null then 2swap ( value$' key$ ) - ($add-tag) ( ) -; - \ Remove possible trailing carriage return from the line : ?remove-cr ( adr len -- adr len' ) dup if ( adr len ) @@ -163,11 +160,29 @@ then ;
-: put-tag ( value$ key$ -- ) +: put-ascii-tag ( value$ key$ -- ) 2swap dup if add-null then 2swap ( value$' key$ ) ($add-tag) ( ) ;
+1 buffer: sg-buf +: special-tag? ( value$ key$ -- true | value$ key$ false ) + 2dup " SG" $= if ( value$ key$ ) + 2swap ( key$ value$ ) + over " 0x" comp 0= if 2 /string then ( key$ value$' ) + push-hex $number pop-base abort" Invalid tag value: SG tag value is not a hex number" ( key$ n ) + dup h# ff u> abort" Invalid tag value: SG tag value will not fit in one byte" ( key$ n ) + sg-buf c! sg-buf 1 2swap ($add-tag) ( ) + true exit + then ( value$ key$ ) + false +; + +: put-tag ( value$ key$ -- ) + special-tag? if exit then + put-ascii-tag +; + 0 0 2value response$
false value any-tags? @@ -195,21 +210,22 @@
response$ nip 0= if ." Null manufacturing data" cr exit then
- flash-write-enable + clear-mfg-buf ( ) + " " " ww" ($add-tag) ( )
- clear-mfg-buf ( ) response$ write-new-tags ( ) -\ " " " ww" put-ascii-tag ( ) + +\ board#$ " B#" put-ascii-tag ( ) \ " EN" " SS" put-ascii-tag ( ) \ " ASSY" " TS" put-ascii-tag ( ) -\ " D3" " SG" put-ascii-tag ( ) -\ board#$ " B#" put-ascii-tag ( ) - any-tags? if (put-mfg-data) then +\ " "(D3)" " SG" ($add-tag) ( )
- \ check-tags - - no-kbc-reboot - kbc-on + any-tags? if + flash-write-enable + (put-mfg-data) + no-kbc-reboot + kbc-on + then ;
: silent-probe-usb ( -- ) @@ -260,7 +276,6 @@ wait-usb-key ;
-0 value test-passed? : show-result-screen ( -- ) restore-scroller clear-screen @@ -277,9 +292,9 @@ : finish-smt-test ( pass? -- ) show-result-screen
- cifs-connect - ." Sending test result " test-passed? smt-result ." Done" cr - cifs-disconnect + ." Sending test result " + cifs-connect smt-result cifs-disconnect + ." Done" cr
test-passed? if ." Writing tags " parse-smt-response ." Done" cr @@ -322,9 +337,11 @@
get-info
- ." Connecting to shop floor server " cifs-connect ." Done" cr - ." Getting tags " smt-request$ to response$ ." Done" cr + ." Getting SMT tags .. " + ." Connecting .. " cifs-connect ." Connected .. " + smt-request$ to response$ cifs-disconnect + ." Done" cr
true to diag-switch? " patch smt-tests play-item mfgtest-menu" evaluate
