Author: wmb Date: Wed Jun 20 10:18:56 2012 New Revision: 3015 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3015
Log: Reinstate the USB probing change, but fixed so it works with USB 1.1 devices.
Modified: dev/usb2/hcd/device.fth dev/usb2/hcd/ehci/probe.fth
Modified: dev/usb2/hcd/device.fth ============================================================================== --- dev/usb2/hcd/device.fth Tue Jun 19 04:18:40 2012 (r3014) +++ dev/usb2/hcd/device.fth Wed Jun 20 10:18:56 2012 (r3015) @@ -392,26 +392,38 @@ \ Executed in root hub node context : get-str-descriptors ( -- ) language ( lang ) - dup dev-desc-buf d# 14 + c@ v$-desc-buf get-string to /v$-desc-buf - dup dev-desc-buf d# 15 + c@ d$-desc-buf get-string to /d$-desc-buf - dev-desc-buf d# 16 + c@ s$-desc-buf get-string to /s$-desc-buf + dup d# 14 dev-desc@ v$-desc-buf get-string to /v$-desc-buf + dup d# 15 dev-desc@ d$-desc-buf get-string to /d$-desc-buf + d# 16 dev-desc@ s$-desc-buf get-string to /s$-desc-buf ;
\ Executed in root hub node context : refresh-desc-bufs ( dev -- ) set-target - dev-desc-buf 12 get-dev-desc to /dev-desc-buf \ Refresh dev-desc-buf - cfg-desc-buf 0 get-cfg-desc to /cfg-desc-buf \ Refresh cfg-desc-buf + dev-desc-buf d# 18 get-dev-desc to /dev-desc-buf \ Refresh dev-desc-buf + cfg-desc-buf 0 get-cfg-desc to /cfg-desc-buf \ Refresh cfg-desc-buf get-str-descriptors ;
-\ Executed in root hub node context -: get-initial-descriptors ( dev -- ) +: get-initial-dev-desc ( dev -- ) + dev-desc-buf d# 18 erase ( dev ) + + \ Until we know the size of the control endpoint, we must be + \ conservative about the transfer size. dev-desc-buf /pipe0 get-dev-desc if ( dev ) - dev-desc-buf 7 + c@ 0 rot di-maxpayload! ( ) + 7 dev-desc@ ( dev maxtransfer ) + tuck 0 rot di-maxpayload! ( maxtransfer ) + d# 18 >= if ( ) + dev-desc-buf d# 18 get-dev-desc drop ( ) + then ( ) else ( dev ) drop ( ) then ( ) +; + +\ Executed in root hub node context +: get-initial-descriptors ( dev -- ) + get-initial-dev-desc ( ) cfg-desc-buf 0 get-cfg-desc to /cfg-desc-buf ( ) ;
@@ -453,7 +465,15 @@ tuck di-speed! ( port dev )
0 set-target ( port dev ) \ Address it as device 0 - over reset-port ( port dev ) \ Some devices want to be reset here + + \ Some devices (e.g. Lexar USB-to-SD and at least one USB FLASH drive) fail + \ on set-address unless you first read the device descriptor from address 0. + \ On other devices, this will fail, but it won't cause problems, and the + \ descriptor will be re-read later by make-device-node + dup get-initial-dev-desc ( port dev ) + +\ over reset-port ( port dev ) \ Some devices want to be reset here + dup set-address if ( port dev ) \ Assign it usb addr dev ." Retrying with a delay" cr over reset-port d# 5000 ms
Modified: dev/usb2/hcd/ehci/probe.fth ============================================================================== --- dev/usb2/hcd/ehci/probe.fth Tue Jun 19 04:18:40 2012 (r3014) +++ dev/usb2/hcd/ehci/probe.fth Wed Jun 20 10:18:56 2012 (r3015) @@ -7,10 +7,10 @@ 0 value port-speed
: make-root-hub-node ( port -- ) - \ Some devices (e.g. Lexar USB-to-SD) fail unless you get the cfg desc from device 0 first 0 set-target \ First address it as device 0 ( port ) port-speed 0 di-speed! \ Use high speed for getting the device descriptor - dev-desc-buf h# 40 get-cfg-desc drop ( port ) + + dup reset-port ( port )
port-speed ( port speed )
