Author: wmb Date: Mon Jun 27 22:49:20 2011 New Revision: 2314 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2314
Log: Added $compare and $caps-compare for lexicographic string comparision considering both string contents and length.
Modified: forth/lib/stringop.fth
Modified: forth/lib/stringop.fth ============================================================================== --- forth/lib/stringop.fth Mon Jun 27 18:54:07 2011 (r2313) +++ forth/lib/stringop.fth Mon Jun 27 22:49:20 2011 (r2314) @@ -108,6 +108,59 @@ until then then ( adr ) here over - ; +\ The result is < = > zero when $1 is < = > $2 +: $compare ( $1 $2 -- -1|0|1 ) + rot ( adr1 adr2 len2 len1 ) + 2dup = if ( adr1 adr2 len2 len1 ) + \ The strings are the same length, so consider only their contents + drop comp ( -1|0|1 ) + else ( adr1 adr2 len2 len1 ) + \ The lengths differ, so consider both contents and length + \ First consider the contents within the length of the shorter string + 2>r 2r@ min ( adr1 adr2 min-len r: len2 len1 ) + comp ?dup if ( -1|1 r: len2 len1 ) + \ The initial substrings differ, determining the answer + 2r> 2drop ( -1|1 ) + else ( r: len2 len1 ) + \ The initial substring are the same, so the longer string is ">" + 2r> swap ( len1 len2 ) + < if -1 else 1 then ( -1|1 ) + then + then +; +\ The result is < = > zero when $1 is < = > $2 +: $caps-compare ( $1 $2 -- -1|0|1 ) + rot ( adr1 adr2 len2 len1 ) + 2dup = if ( adr1 adr2 len2 len1 ) + \ The strings are the same length, so consider only their contents + drop caps-comp ( -1|0|1 ) + else ( adr1 adr2 len2 len1 ) + \ The lengths differ, so consider both contents and length + \ First consider the contents within the length of the shorter string + 2>r 2r@ min ( adr1 adr2 min-len r: len2 len1 ) + caps-comp ?dup if ( -1|1 r: len2 len1 ) + \ The initial substrings differ, determining the answer + 2r> 2drop ( -1|1 ) + else ( r: len2 len1 ) + \ The initial substring are the same, so the longer string is ">" + 2r> swap ( len1 len2 ) + < if -1 else 1 then ( -1|1 ) + then + then +; +0 [if] \ Test cases +" " " " $compare . +" a" " a" $compare . +" a" " b" $compare . +" a" " ab" $compare . +" b" " a" $compare . +" b" " ab" $compare . +" a" " a" $caps-compare . +" a" " B" $caps-compare . +" a" " Ba" $caps-compare . +" B" " a" $caps-compare . +" B" " ab" $caps-compare . +[then]
\ LICENSE_BEGIN \ Copyright (c) 2006 FirmWorks
