Author: wmb Date: 2008-09-09 04:22:38 +0200 (Tue, 09 Sep 2008) New Revision: 927
Modified: cpu/x86/pc/olpc/mfgdata.fth Log: OLPC - formatting tweaks to 2-column mfg data display
Modified: cpu/x86/pc/olpc/mfgdata.fth =================================================================== --- cpu/x86/pc/olpc/mfgdata.fth 2008-09-09 01:55:47 UTC (rev 926) +++ cpu/x86/pc/olpc/mfgdata.fth 2008-09-09 02:22:38 UTC (rev 927) @@ -77,27 +77,31 @@
: $tag-printable? ( adr len -- flag ) ?-null \ Ignore trailing null - bounds ?do i c@ printable? 0= if false unloop exit then loop + bounds ?do i c@ bl h# 7f within 0= if false unloop exit then loop true ;
: wrapped-cdump ( adr len -- ) lmargin @ >r rmargin @ >r tabstops @ >r - 4 lmargin ! d# 78 rmargin ! 3 tabstops ! + 4 lmargin ! d# 71 rmargin ! 3 tabstops ! + dup >r + blue-letters bounds ?do 3 .tab i c@ <# u# u# u#> type loop + black-letters + r> d# 10 > if cr then r> tabstops ! r> rmargin ! r> lmargin ! ;
: .mfg-data ( -- ) - 0 lmargin ! d# 78 rmargin ! d# 44 tabstops ! + 0 lmargin ! d# 78 rmargin ! d# 42 tabstops ! ??cr mfg-data-top ( adr ) begin another-tag? while ( adr' data$ tname-adr ) over 4 + .tab 2 type 2 spaces ( adr' data$ ) - 2dup $tag-printable? if ?-null type else wrapped-cdump cr then + 2dup $tag-printable? if ?-null type else wrapped-cdump then exit? if drop exit then repeat drop
