Author: wmb Date: Fri Dec 7 02:26:52 2012 New Revision: 3478 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3478
Log: Seti camera driver - changed register settings to match the Linux driver ones, except for register 0x111 which is currently set at the value for 30fps under low light conditions. The Linux driver changed that value in commit ddb0abd and then reverted it in commit 2b6599b.
Modified: dev/olpc/seti.fth
Modified: dev/olpc/seti.fth ============================================================================== --- dev/olpc/seti.fth Fri Dec 7 02:22:53 2012 (r3477) +++ dev/olpc/seti.fth Fri Dec 7 02:26:52 2012 (r3478) @@ -13,7 +13,7 @@ 34 10 ov! 27 11 ov! 21 12 ov! - c6 16 ov! + ce 16 ov! aa 17 ov!
00 20 ov! \ P_BNKT @@ -23,11 +23,11 @@
\ AE 01 00 ov! - 14 11 ov! \ 6fps at lowlux + 04 11 ov! \ Keep 30fps at lowlux (14 for 6fps) 78 12 ov! \ D65 target 0x74 78 13 ov! \ CWF target 0x74 78 14 ov! \ A target 0x74 - 08 1E ov! \ ini gain 0x08 + 04 1E ov! \ ini gain 0x04 7d 34 ov! 60 40 ov! \ Max x8
@@ -107,8 +107,8 @@ \ IDP 03 00 ov! ff 10 ov! - 1d 11 ov! - cb 12 ov! + 1d 11 ov! \ Change PIXDATA on falling edge of clock for better timing + 3d 12 ov! \ YUV422 setting; changed later if RGB565 04 14 ov! \ don't change
\ DPCNR @@ -283,7 +283,7 @@
( r: ycrcb? ) r> 0= if ( ) 03 00 ov! \ IDP - cb 12 ov! \ RGB565 setting (same as yCrCb setting?) + cb 12 ov! \ RGB565 setting then ;
