Author: wmb Date: Thu Jan 20 01:39:30 2011 New Revision: 2131 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2131
Log: Eliminated the need for the md5sum command (not present on Mac OS) in the sd8686.bth script.
Modified: cpu/arm/olpc/1.75/sd8686.bth
Modified: cpu/arm/olpc/1.75/sd8686.bth ============================================================================== --- cpu/arm/olpc/1.75/sd8686.bth Thu Jan 20 01:04:21 2011 (r2130) +++ cpu/arm/olpc/1.75/sd8686.bth Thu Jan 20 01:39:30 2011 (r2131) @@ -3,6 +3,24 @@ command: &builder &this build-now
+char * value prefix +\needs $md5digest1 fload ${BP}/ofw/ppp/md5.fth +: $md5sum-file ( filename$ -- ) + 2dup $read-file ( filename$ adr len ) + 2dup $md5digest1 ( filename$ adr len md5$ ) + 2swap free-mem ( filename$ md5$ ) + " md5string" $new-file ( filename$ md5$ ) + bounds ?do ( filename$ ) + i c@ push-hex <# u# u# u#> ofd @ fputs pop-base + loop ( filename$ ) + " " ofd @ fputs ( filename$ ) + prefix ofd @ fputc ( filename$ ) + ofd @ fputs ( ) + fcr + ofd @ fclose +; + + fload ${BP}/cpu/arm/olpc/1.75/wlan-version.fth
" macro: WLAN_FILE lbtf_sdio-${WLAN_VERSION}" expand$ eval @@ -14,15 +32,18 @@
" wget -q http://dev.laptop.org/pub/firmware/libertas/thinfirm/$%7BWLAN_FILE%7D.bin" expand$ $sh " wget -q http://dev.laptop.org/pub/firmware/libertas/thinfirm/$%7BWLAN_FILE%7D.bin.md..." expand$ $sh -" md5sum ${WLAN_FILE}.bin | cmp - ${WLAN_FILE}.bin.md5" expand$ $sh + +bl to prefix " ${WLAN_FILE}.bin" expand$ $md5sum-file +" cmp md5string ${WLAN_FILE}.bin.md5" expand$ $sh
" mv ${WLAN_FILE}.bin sd8686.bin" expand$ $sh
" wget -q http://dev.laptop.org/pub/firmware/libertas/sd8686_helper.bin" expand$ $sh " wget -q http://dev.laptop.org/pub/firmware/libertas/sd8686_helper.bin.md5" expand$ $sh -" md5sum -b sd8686_helper.bin | cmp - sd8686_helper.bin.md5" expand$ $sh +char * to prefix " sd8686_helper.bin" $md5sum-file +" cmp md5string sd8686_helper.bin.md5" expand$ $sh
-" rm ${WLAN_FILE}.bin.md5 sd8686_helper.bin.md5" expand$ $sh +" rm ${WLAN_FILE}.bin.md5 sd8686_helper.bin.md5 md5string" expand$ $sh [then]
\ This forces the creation of a .log file, so we don't re-fetch
