Author: quozl Date: Mon Aug 20 11:44:00 2012 New Revision: 3202 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3202
Log: OLPC - fs-update, sanity-check file size if the zdata file contains a size: header line, abort if invalid, ignore if missing, #12055
Modified: cpu/x86/pc/olpc/via/fsupdate.fth
Modified: cpu/x86/pc/olpc/via/fsupdate.fth ============================================================================== --- cpu/x86/pc/olpc/via/fsupdate.fth Mon Aug 20 11:35:44 2012 (r3201) +++ cpu/x86/pc/olpc/via/fsupdate.fth Mon Aug 20 11:44:00 2012 (r3202) @@ -8,6 +8,11 @@ push-hex $number pop-base " Bad number" ?nand-abort ;
+: get-dhex# ( -- d ) + 0 safe-parse-word + push-hex $dnumber pop-base " Bad number" ?nand-abort +; + 0 value min-eblock# 0 value max-eblock#
@@ -145,6 +150,13 @@ true to secure-fsupdate? ;
+0 2value file-bytes +: size: ( "bytes" -- ) + get-dhex# ( d.size ) + file-bytes d<> ( invalid? ) + " Inconsistent size of zdata file" ?nand-abort +; + : erase-all ( -- ) #image-eblocks show-writing ; @@ -259,6 +271,9 @@ false to secure-fsupdate? ( file$ ) r/o open-file ( fd error? ) " Can't open file" ?nand-abort ( fd ) + dup file-size ( fd [size.d] error? ) + " Can't size file" ?nand-abort ( fd size.d ) + [ also nand-commands ] to file-bytes [ previous ]
linefeed over force-line-delimiter ( fd )
