Author: wmb Date: 2009-10-09 02:07:12 +0200 (Fri, 09 Oct 2009) New Revision: 1407
Added: cpu/x86/pc/olpc/via/cstate.fth Modified: cpu/x86/pc/olpc/via/fsupdate.fth cpu/x86/pc/olpc/via/fw.bth cpu/x86/pc/olpc/via/romreset.bth Log: Via - Added C-state testing words c{0-4}-test
Added: cpu/x86/pc/olpc/via/cstate.fth =================================================================== --- cpu/x86/pc/olpc/via/cstate.fth (rev 0) +++ cpu/x86/pc/olpc/via/cstate.fth 2009-10-09 00:07:12 UTC (rev 1407) @@ -0,0 +1,118 @@ +purpose: Test for processor C-states +\ See license at end of file + +: cpu-temperature ( -- degrees-C ) h# 1169 msr@ drop ; +: show-temperature ( -- ) space cpu-temperature .d ; + +variable start-time +variable sleep-time +: acpi-time@ ( -- t0 ) 8 acpi-l@ ; + +: arb-dis ( -- ) 1 h# 22 pc! ; +: arb-ena ( -- ) 0 h# 22 pc! ; +: bm-rld-on ( -- ) 4 acpi-w@ 2 or 4 acpi-w! ; +: bm-rld-off ( -- ) 4 acpi-w@ 2 invert and 4 acpi-w! ; + +\ Setting this makes C3 behave the same as C4 +\ So there are two ways to get into C4 - +\ Either set this bit and read the LVL_3 register, +\ or just read the LVL_4 register + +: lower-c3-voltage ( -- ) h# 26 acpi-b@ 1 or h# 26 acpi-b! ; + +: can-idle? ( -- flag ) + interrupts-enabled? if \ Interrupts must be enabled + h# 21 pc@ 1 and 0= \ Timer must be running + else + false + then +; + +defer do-idle ' noop to do-idle + +: safe-idle ( -- ) can-idle? if do-idle then ; +' safe-idle to stdin-idle + +alias c1-idle halt + +: c2-idle ( -- ) h# 14 acpi-b@ drop ; +: c3-idle ( -- ) arb-dis h# 15 acpi-b@ drop arb-ena ; +: c4-idle ( -- ) arb-dis h# 16 acpi-b@ drop arb-ena ; +code c5-idle ( -- ) acpi-io-base h# 17 + # dx mov wbinvd dx al in c; + +alias default-idle-state c2-idle +' default-idle-state to do-idle + +: enter-idle ( -- ) + acpi-time@ ( t ) + do-idle ( t ) + acpi-time@ swap - sleep-time +! +; +: idle-ms ( ms -- ) + tick-msecs + ( limit ) + begin enter-idle dup tick-msecs - 0<= until ( limit ) + drop +; +: idling ( xt -- ) + to do-idle + cursor-off + sleep-time off + acpi-time@ start-time ! + begin + green-letters (cr show-temperature d# 1024 idle-ms + black-letters (cr show-temperature d# 1024 idle-ms + key? until + acpi-time@ start-time @ - + cursor-on + ." Slept " sleep-time @ .d ." of " .d ." ticks" cr + ['] default-idle-state to do-idle +; +: .idling ( $ -- ) + ." Idling in " type ." state, showing core temperature" cr +; +: c0-test ( -- ) + " C0" .idling + ['] noop idling +; +: c1-test ( -- ) + " C1" .idling + ['] c1-idle idling +; +: c2-test ( -- ) + " C2" .idling + ['] c2-idle idling +; +: c3-test ( -- ) + bm-rld-on + " C3" .idling + ['] c3-idle idling +; +: c4-test ( -- ) + bm-rld-on + " C4" .idling + ['] c4-idle idling +; + +\ LICENSE_BEGIN +\ Copyright (c) 2009 FirmWorks +\ +\ Permission is hereby granted, free of charge, to any person obtaining +\ a copy of this software and associated documentation files (the +\ "Software"), to deal in the Software without restriction, including +\ without limitation the rights to use, copy, modify, merge, publish, +\ distribute, sublicense, and/or sell copies of the Software, and to +\ permit persons to whom the Software is furnished to do so, subject to +\ the following conditions: +\ +\ The above copyright notice and this permission notice shall be +\ included in all copies or substantial portions of the Software. +\ +\ THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, +\ EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF +\ MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND +\ NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE +\ LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION +\ OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION +\ WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. +\ +\ LICENSE_END
Modified: cpu/x86/pc/olpc/via/fsupdate.fth =================================================================== --- cpu/x86/pc/olpc/via/fsupdate.fth 2009-10-08 23:06:25 UTC (rev 1406) +++ cpu/x86/pc/olpc/via/fsupdate.fth 2009-10-09 00:07:12 UTC (rev 1407) @@ -3,9 +3,6 @@
\ Depends on words from security.fth and copynand.fth
-: cpu-temperature ( -- degrees-C ) h# 1169 msr@ drop ; -: show-temperature ( -- ) space cpu-temperature .d ; - : get-hex# ( -- n ) safe-parse-word push-hex $number pop-base " Bad number" ?nand-abort
Modified: cpu/x86/pc/olpc/via/fw.bth =================================================================== --- cpu/x86/pc/olpc/via/fw.bth 2009-10-08 23:06:25 UTC (rev 1406) +++ cpu/x86/pc/olpc/via/fw.bth 2009-10-09 00:07:12 UTC (rev 1407) @@ -300,6 +300,9 @@
fload ${BP}/ofw/gui/loadmenu.fth fload ${BP}/ofw/gui/insticon.fth + +fload ${BP}/cpu/x86/pc/olpc/via/cstate.fth \ C-state tests + \ Uninstall the diag menu from the general user interface vector \ so exiting from emacs doesn't invoke the diag menu. ' quit to user-interface @@ -514,9 +517,6 @@
" dhcp" ' ip-address set-config-string-default
-: c1-idle ( -- ) interrupts-enabled? if halt then ; -' c1-idle to stdin-idle - : fast-boot? ( -- flag ) [ifdef] rom-loaded button-x game-key? 0=
Modified: cpu/x86/pc/olpc/via/romreset.bth =================================================================== --- cpu/x86/pc/olpc/via/romreset.bth 2009-10-08 23:06:25 UTC (rev 1406) +++ cpu/x86/pc/olpc/via/romreset.bth 2009-10-09 00:07:12 UTC (rev 1407) @@ -119,6 +119,7 @@ fload ${BP}/cpu/x86/pc/olpc/via/starthostctl.fth
acpi-io-base 1 + 8888 config-ww \ Set ACPI base address + acpi-io-base wbsplit 0292 config-wb 0293 config-wb \ ACPI base address for C-states, big-endian
[ifdef] debug-startup cominit #) call
