Author: wmb Date: Sat Oct 13 03:42:23 2012 New Revision: 3369 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3369
Log: OLPC - fixed a possible unitialized buffer address in fs-update.
Modified: cpu/x86/pc/olpc/via/fsupdate.fth
Modified: cpu/x86/pc/olpc/via/fsupdate.fth ============================================================================== --- cpu/x86/pc/olpc/via/fsupdate.fth Sat Oct 13 03:41:13 2012 (r3368) +++ cpu/x86/pc/olpc/via/fsupdate.fth Sat Oct 13 03:42:23 2012 (r3369) @@ -72,6 +72,7 @@ also nand-commands definitions
: zblocks: ( "eblock-size" "#eblocks" ... -- ) + load-base to data-buffer ?compare-spec-line get-hex# to /nand-block get-hex# to #image-eblocks @@ -84,8 +85,7 @@ \ Separate the two buffers by enough space for both the compressed \ and uncompressed copies of the data. 4x is overkill, but there \ is plenty of space at load-base - load-base to dma-buffer - load-base /nand-block 4 * + to data-buffer + load-base /nand-block 4 * + to dma-buffer /nand-block /nand-page / to nand-pages/block t-update \ Handle possible timer rollover ;
