Author: quozl Date: Wed Feb 15 01:23:33 2012 New Revision: 2863 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2863
Log: OLPC XO-1.75 - convert test menu to new add-icon construction method
Modified: cpu/arm/olpc/testitems.fth
Modified: cpu/arm/olpc/testitems.fth ============================================================================== --- cpu/arm/olpc/testitems.fth Mon Feb 13 23:49:31 2012 (r2862) +++ cpu/arm/olpc/testitems.fth Wed Feb 15 01:23:33 2012 (r2863) @@ -1,3 +1,8 @@ +purpose: Platform-specific layout of diagnostic GUI menu items + +d# 5 to #mfgcols +d# 4 to #mfgrows + icon: cpu.icon rom:cpu.565 icon: spi.icon rom:spi.565 icon: ram.icon rom:ram.565 @@ -16,10 +21,6 @@ icon: ebook.icon rom:ebook.565 icon: leds.icon rom:leds.565
-d# 15 to #mfgtests -d# 5 to #mfgcols -d# 4 to #mfgrows - + olpc-cl3 : screen-kbd-scroller ( -- ) blank-screen open-screen-keyboard ; + olpc-cl3 ' screen-kbd-scroller to scroller-on + olpc-cl3 ' close-screen-keyboard to scroller-off @@ -46,64 +47,65 @@ : leds-item ( -- ) " /leds" mfg-test-dev ;
: olpc-test-menu-items ( -- ) - clear-menu + 0 to #mfgtests + 1 0 set-row-col
-\ " CPU" -\ ['] cpu-item cpu.icon 1 0 install-icon +\ " CPU" +\ ['] cpu-item cpu.icon add-icon
" SPI Flash: Contains EC code, firmware, manufacturing data." - ['] spiflash-item spi.icon 1 0 install-icon + ['] spiflash-item spi.icon add-icon
" RAM chips" - ['] memory-item ram.icon 1 1 install-icon + ['] memory-item ram.icon add-icon
" Internal mass storage" - ['] int-sd-item sdcard.icon 1 2 install-icon + ['] int-sd-item sdcard.icon add-icon
-- olpc-cl3 " Plug-in SD card" -- olpc-cl3 ['] ext-sd-item sdcard.icon 1 3 install-icon +- olpc-cl3 " Plug-in SD card" +- olpc-cl3 ['] ext-sd-item sdcard.icon add-icon
" Wireless LAN" - ['] wlan-item wifi.icon 1 4 install-icon + ['] wlan-item wifi.icon add-icon
" Display" - ['] display-item display.icon 2 0 install-icon + ['] display-item display.icon add-icon
" Camera" - ['] camera-item camera.icon 2 1 install-icon + ['] camera-item camera.icon add-icon
" Audio: Speaker and microphone" - ['] audio-item audio.icon 2 2 install-icon + ['] audio-item audio.icon add-icon
" Battery" - ['] battery-item battery.icon 2 3 install-icon + ['] battery-item battery.icon add-icon
" RTC (Real-Time Clock)" - ['] rtc-item clock.icon 2 4 install-icon + ['] rtc-item clock.icon add-icon
+ olpc-cl2 " USB ports" + olpc-cl3 " USB-A port" - ['] usb-item usb.icon 3 0 install-icon + ['] usb-item usb.icon add-icon
+ olpc-cl3 " USB OTG port" -+ olpc-cl3 ['] otg-item usb.icon 3 1 install-icon ++ olpc-cl3 ['] otg-item usb.icon add-icon
\ These are last because they require user participation. \ The earlier tests are all included in automatic batch-mode.
-- olpc-cl3 " Keyboard" -- olpc-cl3 ['] keyboard-item keyboard.icon 3 1 install-icon +- olpc-cl3 " Keyboard" +- olpc-cl3 ['] keyboard-item keyboard.icon add-icon
-- olpc-cl3 " Touchpad" -- olpc-cl3 ['] touchpad-item touchpad.icon 3 2 install-icon +- olpc-cl3 " Touchpad" +- olpc-cl3 ['] touchpad-item touchpad.icon add-icon
-+ olpc-cl3 " Touchscreen" -+ olpc-cl3 ['] touchscreen-item touchscreen.icon 3 2 install-icon ++ olpc-cl3 " Touchscreen" ++ olpc-cl3 ['] touchscreen-item touchscreen.icon add-icon
" LEDs" - ['] leds-item leds.icon 3 3 install-icon + ['] leds-item leds.icon add-icon
" Switches and Accelerometer" - ['] switch-item ebook.icon 3 4 install-icon + ['] switch-item ebook.icon add-icon ; ' olpc-test-menu-items to test-menu-items
