Author: wmb Date: 2008-12-06 11:40:16 +0100 (Sat, 06 Dec 2008) New Revision: 1025
Added: cpu/x86/pc/biosload/HOWTO_QEMU.txt cpu/x86/pc/biosload/config-virtualbox.fth cpu/x86/pc/biosload/makefloppy.fth Modified: cpu/x86/pc/biosload/mbootsec.fth Log: Biosload version - added instructions for creating a floppy image that will boot under QEMU.
Added: cpu/x86/pc/biosload/HOWTO_QEMU.txt =================================================================== --- cpu/x86/pc/biosload/HOWTO_QEMU.txt (rev 0) +++ cpu/x86/pc/biosload/HOWTO_QEMU.txt 2008-12-06 10:40:16 UTC (rev 1025) @@ -0,0 +1,82 @@ +== Booting OFW Under QEMU == + +You can boot OFW directly from the BIOS in QEMU; you don't need +Coreboot (formerly LinuxBIOS) or external bootloaders like GRUB +or Lilo or syslinux. OFW has its own little (two sector) BIOS +bootloader that can be used to make a bootable floppy image. + +The instructions below tell how to prepare a bootable floppy +disk image that can be booted from QEMU, VirtualBox, or several +other emulators. + +=== Build OFW === + + $ cd cpu/x86/pc/biosload/ + $ cp config-virtualbox.fth config.fth + $ cd build + $ cd cpu/x86/pc/biosload/build + $ make floppyofw.img + +The "config-virtualbox.fth" configuration is known to work with QEMU. +Other configurations may work also - but the "qemu-loaded" config +option isn't what you want for this technique, because itt is a subcase +of the CoreBoot-payload configuration. + +You will use the "floppyofw.img" output file in a later step. + +=== Make a bootable Floppy Image === + + $ ../../../Linux/forth fw.dic ../makefloppy.fth + +This creates a file that is a bootable floppy image with an empty +FAT12 filesystem. This step only has to be done once. + +=== Copy OFW onto the Floppy Image === + + $ mkdir flp + $ sudo mount -t msdos -o loop floppy.img flp + $ sudo cp floppyofw.img flp/ofw.img + $ sudo umount flp + +=== Boot OFW from QEMU === + + $ qemu -L <dir> -boot a -fda floppy.img + +"<dir>" is the directory that contains QEMU's BIOS and VGA BIOS files. + +If you want to make changes and recompile OFW, you need not repeat the +"makefloppy" step; you can just loopback mount the floppy image and +copy the new OFW version to ofw.img . + +== What is on the Floppy Image == + +The floppy image is a bootable floppy with a FAT12 filesystem. Its first two +sectors contain a simple bootloader program that uses BIOS INT 13 callbacks to +read floppy sectors. The program scans the FAT root directory entries to find +the file "ofw.img", then loads that into memory and jumps to it. + +When you build floppyofw.img, as a side effect it also builds bootsec.img, which +is that simple bootloader. The source code (Forth-style assembly language) is in +biosload/bootsec.fth . + +The "makefloppy.fth" program that creates the image is pretty simple; it copies +bootsec.img to the output file "floppy.img", creates a couple of initially +empty FAT tables, zeros the root directory area, and fills the data area with +zeros. Here's a pair of Linux commands that accomplish the same thing +as makefloppy.fth: + + Step6a $ /sbin/mkdosfs -C -f 2 -F 12 -R 2 -r 224 -s 1 -S 512 floppy.img 1440 + Step6b $ dd <bootsec.img of=floppy.img conv=nocreat,notrunc + +The arguments to mkdosfs force the filesystem layout to match the layout that +is specified in the BIOS parameter block in bootsec.img. + +The advantage of makefloppy.fth is that it reads the filesystem layout parameters +from the BPB in bootsec.img, so its guaranteed to be conistent. If bootsec.fth +were edited to change the layout, the arguments to "mkdosfs" would have to change. +(But there's little need to change that layout, since it's a standard floppy +size.) + +The advantage of the Linux command sequence is that it creates a file with +"holes", thus saving disk space for awhile (until something happens to fill +in the holes).
Added: cpu/x86/pc/biosload/config-virtualbox.fth =================================================================== --- cpu/x86/pc/biosload/config-virtualbox.fth (rev 0) +++ cpu/x86/pc/biosload/config-virtualbox.fth 2008-12-06 10:40:16 UTC (rev 1025) @@ -0,0 +1,136 @@ +\ See license at end of file +purpose: Establish configuration definitions + +\ create pc \ Demo version for generic PC +\ create pc-linux \ Demo version for generic PC and Linux +\ create pc-serial \ Demo version for generic PC + +\ --- The environment that "boots" OFW --- +\ - Image Format - Example Media - previous stage bootloader + +\ - (Syslinux) COM32 format - USB Key w/ FAT FS - Syslinux +\ create syslinux-loaded + +\ - Linux kernel format - USB Key w/ FAT FS - LinuxBIOS w/ stripped Linux payload +\ create bzimage-loaded + +\ - ELF format w/ Multiboot signature - various - GRUB +\ create grub-loaded +\ create etherboot-variant \ Enable additional tweaks for Etherboot + +\ - ELF format (no pheader) - ROM - LinuxBIOS direct +\ create linuxbios-loaded + +\ Load and run in qemu +\ create qemu-loaded + +\ Load and run in VirtualBox +create virtualbox-loaded + +\ Load from ROM by preOF code from Intel +\ create preof-loaded + +[ifdef] pc-serial +create serial-console +create pc +[then] + +[ifdef] qemu-loaded \ LinuxBIOS+OFW under QEMU currently does not do VGA right +create serial-console +[then] + +[ifdef] virtualbox-loaded +\ create debug-startup +\ create serial-console +create resident-packages +create addresses-assigned \ Don't reassign PCI addresses +\ create virtual-mode +\ create use-root-isa +create use-timestamp-counter +create use-pci-isa +create use-isa-ide +create use-ega +create use-elf +\ create use-ne2000 +create use-watch-all +create use-null-nvram +\ create no-floppy-node +[then] + +[ifdef] etherboot-variant +create debug-startup +create serial-console +[then] + +[ifdef] pc-linux +\ In virtual mode, OFW runs with the MMU on. The advantages are +\ that OFW can automatically locate itself out of the way, at the +\ top of physical memory, it can dynamically allocate exactly as +\ much physical memory as it needs, and it can remain alive after +\ the OS starts. The disadvantage is that it is more confusing - +\ you always have to be aware of the distinction between virtual +\ and physical addresses. + +\ Here we use virtual mode for Linux, so that we can debug past +\ the point where Linux starts using the MMU. It is not strictly +\ necessary to use virtual mode if you just want to boot Linux +\ and then have OFW disappear. +create virtual-mode +create pc +create linux-support +[then] + +[ifdef] pc +\ create pseudo-nvram +create resident-packages +create addresses-assigned \ Don't reassign PCI addresses +\ create virtual-mode +create use-root-isa +create use-isa-ide +create use-ega +create use-elf +create use-ne2000 +create use-watch-all +create use-null-nvram +create no-floppy-node +[then] + +[ifdef] preof-loaded +create serial-console +create use-timestamp-counter +create resident-packages +create addresses-assigned \ Don't reassign PCI addresses +\ create virtual-mode +create use-root-isa +create use-isa-ide +create use-elf +create use-watch-all +create use-null-nvram +create no-floppy-node +[then] + +fload ${BP}/cpu/x86/pc/biosload/addrs.fth + +\ LICENSE_BEGIN +\ Copyright (c) 2006 FirmWorks +\ +\ Permission is hereby granted, free of charge, to any person obtaining +\ a copy of this software and associated documentation files (the +\ "Software"), to deal in the Software without restriction, including +\ without limitation the rights to use, copy, modify, merge, publish, +\ distribute, sublicense, and/or sell copies of the Software, and to +\ permit persons to whom the Software is furnished to do so, subject to +\ the following conditions: +\ +\ The above copyright notice and this permission notice shall be +\ included in all copies or substantial portions of the Software. +\ +\ THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, +\ EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF +\ MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND +\ NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE +\ LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION +\ OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION +\ WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. +\ +\ LICENSE_END
Added: cpu/x86/pc/biosload/makefloppy.fth =================================================================== --- cpu/x86/pc/biosload/makefloppy.fth (rev 0) +++ cpu/x86/pc/biosload/makefloppy.fth 2008-12-06 10:40:16 UTC (rev 1025) @@ -0,0 +1,55 @@ +\ This program creates a bootable 1.44 MB floppy disk image with an +\ initially-empty FAT12 filesystem. +\ The FATs begin at sector 2. Sectors 0 and 1 contain a simple +\ FAT filesystem reader that uses INT 13 to load the file "\OFW.IMG" +\ into memory, then jumps to it. + +hex + +d# 512 constant /sector +/sector buffer: sector-buf + +create ofw-boot-sectors + " ${BP}/cpu/x86/pc/biosload/build/bootsec.img" $file, +here ofw-boot-sectors - constant /ofw-boot-sectors + +: make-floppy-image ( -- ) + " floppy.img" $new-file + + \ Write boot sectors + ofw-boot-sectors /ofw-boot-sectors ofd @ fputs + + \ Init FATs + sector-buf /sector erase + + \ BPB offset h#10.b is NumFATCopies + ofw-boot-sectors h# 10 + c@ 0 ?do \ Loop over number of FATs + h# 00fffff0 sector-buf le-l! \ First FAT12 entry + sector-buf /sector ofd @ fputs + 0 sector-buf le-l! + + \ BPB offset h#16.w is SectorsPerFAT + ofw-boot-sectors h# 16 + le-w@ 1- 0 ?do \ Remainder of FAT + sector-buf /sector ofd @ fputs + loop + loop + + \ Init root directory + \ BPB offset h#11.w is RootDirEntries. Each entry is h#20 bytes. + ofw-boot-sectors h# 11 + le-w@ ( #root-dir-entries ) + h# 20 * ( root-dir-bytes ) + /sector / 0 ?do \ Loop over root dir sectors + sector-buf /sector ofd @ fputs + loop + + \ Zero the rest of the floppy image + ofw-boot-sectors h# 13 + le-w@ ( total#sectors ) + /sector * ofd @ fsize ?do + sector-buf /sector ofd @ fputs + /sector +loop + + ofd @ fclose + ." Open Firmware bootable floppy image created as floppy.img ." cr + ." Loopback-mount it and copy OFW.IMG to it." cr +; +make-floppy-image
Modified: cpu/x86/pc/biosload/mbootsec.fth =================================================================== --- cpu/x86/pc/biosload/mbootsec.fth 2008-12-06 10:40:12 UTC (rev 1024) +++ cpu/x86/pc/biosload/mbootsec.fth 2008-12-06 10:40:16 UTC (rev 1025) @@ -69,6 +69,11 @@ ofw-boot-sectors 11 + lew@ 20 * /sector / 0 ?do sector-buf /sector ofd @ fputs loop + + \ Fill the rest of the disk image with zeros + d# 1440 d# 1024 * ofd @ fsize ?do + sector-buf /sector ofd @ fputs + /sector +loop [then]
ofd @ fclose
