Author: rsmith Date: 2010-01-27 07:21:04 +0100 (Wed, 27 Jan 2010) New Revision: 1714
Modified: cpu/x86/pc/olpc/via/assy.fth Log: OLPC 1.5: Add >= firmware upgrade check to assy
Modified: cpu/x86/pc/olpc/via/assy.fth =================================================================== --- cpu/x86/pc/olpc/via/assy.fth 2010-01-27 05:42:50 UTC (rev 1713) +++ cpu/x86/pc/olpc/via/assy.fth 2010-01-27 06:21:04 UTC (rev 1714) @@ -2,6 +2,14 @@
visible
+\ Does a base 36 compare on the firmware versions +\ true if $2 <= $1 +: fw-$compare ( $1 $2 -- $2>$1 ) + base @ >r d# 36 base ! ( $1 $2 ) + $number if exit then ( $1 n2 ) + -rot $number if exit then ( n2 n1 ) + pop-base u<= +; \ If the firmware file is on a CIFS share on the factory server, it \ should be read-only so multiple clients can read it simultaneously.
@@ -28,9 +36,11 @@ ;
: ?update-firmware ( -- ) - update-firmware? 0= if exit then \ Exit if the existing firmware and the wanted firmware are the same - fw-version$ wanted-fw$ nocase-$= if exit then + fw-version$ wanted-fw$ fw-$compare if + fw-version$ type ." >= " wanted-fw$ type cr + ." Not updating fimware" cr exit + then ." Updating firmware to version " fw-version$ type cr d# 2000 ms ?enough-power
