Author: quozl Date: Tue Nov 20 02:49:48 2012 New Revision: 3443 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3443
Log: OLPC XO-4 - touchscreen firmware programming, fix INCREDIBLE slowness problem #12327 by following TI specification, convert progress bar to using hex file byte position instead of load address, since load address is outside our control.
Modified: cpu/arm/olpc/bsl.fth
Modified: cpu/arm/olpc/bsl.fth ============================================================================== --- cpu/arm/olpc/bsl.fth Mon Nov 19 23:37:03 2012 (r3442) +++ cpu/arm/olpc/bsl.fth Tue Nov 20 02:49:48 2012 (r3443) @@ -86,6 +86,14 @@ [then]
\ These are MMP2/3 dependent +\ Section 1.4 of TI slau319c.pdf says to wait 1.2 ms after receiving a +\ character from MSP430 BSL prior to sending a new character. +0 value bsl-time +: set-bsl-time ( -- ) + \ MMP2 Timer 0 runs at 6.5 MHz so 1.2 ms is 1200 * 13 / 2 ticks + timer0@ [ d# 1200 d# 13 2 */ ] literal + to bsl-time +; +: wait-send ( -- ) begin timer0@ bsl-time - 0>= until ;
: bsl-baud ( baud-rate -- ) \ 9600,8,e,1 uart-base >r ( baud-rate r: uart-base ) @@ -96,11 +104,14 @@ r> to uart-base ( ) ;
-: bsl-send ( char -- ) uart-base >r bsl-uart-base to uart-base uemit r> to uart-base ; +: bsl-send ( char -- ) + wait-send + uart-base >r bsl-uart-base to uart-base uemit r> to uart-base +;
: receive? ( -- false | char true ) uart-base >r bsl-uart-base to uart-base - ukey? if ukey true else false then + ukey? if ukey true set-bsl-time else false then r> to uart-base ;
@@ -116,6 +127,7 @@ touch-tck-gpio# gpio-dir-out
d# 9600 bsl-baud + set-bsl-time ; : bsl-close ( -- ) touch-rst-gpio# gpio-dir-in @@ -144,7 +156,7 @@ : flush-bsl get-msecs d# 2000 + ( limit ) begin - receive? 0= if drop exit then ( limit char ) + receive? 0= if drop exit then ( limit char ) drop dup get-msecs - 0< ( limit timeout? ) until drop true abort" BSL flush timeout" @@ -224,7 +236,6 @@
defer bsl-progress ' 2drop is bsl-progress ( offset size -- ) : rx-data-block ( adr len device-adr -- ) - dup h# 8000 - h# 8000 bsl-progress over h# 12 frame( ( adr len device-adr ) send-summed ( adr len ) \ device address dup send-summed ( adr len ) \ data length @@ -491,6 +502,7 @@ force-erase ( ) ." Programming" cr begin ( ) + ifd @ ftell ifd @ fsize bsl-progress [char] . emit bsl-line-buf d# 100 ifd @ read-line abort" Read line failed" while ( len )
