Author: wmb Date: Fri Jul 1 20:48:15 2011 New Revision: 2325 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2325
Log: OLPC XO-1.75 - EC-SPI command protocol: don't complain if the EC has queued-up a couple of upstream events and extend the command timeout to 50 ms.
Modified: dev/olpc/kb3700/spicmd.fth
Modified: dev/olpc/kb3700/spicmd.fth ============================================================================== --- dev/olpc/kb3700/spicmd.fth Fri Jul 1 20:46:54 2011 (r2324) +++ dev/olpc/kb3700/spicmd.fth Fri Jul 1 20:48:15 2011 (r2325) @@ -262,7 +262,6 @@ pulse-ack ; : (upstream) ( -- ) - rxavail 2 <> if ." ec-spi rxavail = " rxavail . cr then ssp-ssdr rl@ ssp-ssdr rl@ ( channel# data ) debug? if ." UP: " over . dup . cr @@ -290,7 +289,7 @@ lock[ ssp-ready? if do-state then ]unlock - debug? if key? if key drop debug-me then then +\ debug? if key? if key drop debug-me then then ; : cancel-command ( -- ) \ Called when the command child times out clr-cmd @@ -371,7 +370,7 @@ ec-cmdbuf 3 + swap bounds ?do i c! loop ( ) ; : timed-get-results ( -- b ) - get-msecs d# 20 + begin ( limit ) + get-msecs d# 50 + begin ( limit ) 2 deque? if ( limit b ) nip exit ( -- b ) then ( limit )
