Author: wmb Date: Tue Dec 6 13:57:33 2011 New Revision: 2742 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2742
Log: OLPC XO-3 - Platform ID -> 10000, fixed touchscreen driver.
Modified: cpu/arm/olpc/build-fw.fth cpu/arm/olpc/exc7200-touchscreen.fth
Modified: cpu/arm/olpc/build-fw.fth ============================================================================== --- cpu/arm/olpc/build-fw.fth Tue Dec 6 13:57:29 2011 (r2741) +++ cpu/arm/olpc/build-fw.fth Tue Dec 6 13:57:33 2011 (r2742) @@ -438,7 +438,8 @@ " /usb" " reset-usb" execute-device-method drop ;
-d# 9999 to arm-linux-machine-type \ Marvell Jasper ++ olpc-cl2 d# 9999 to arm-linux-machine-type \ XO-1.75 ++ olpc-cl3 d# 10000 to arm-linux-machine-type \ XO-3
\ Add a tag describing the linear frame buffer : mmp-fb-tag, ( -- ) @@ -740,8 +741,8 @@ device-end fload ${BP}/cpu/x86/pc/olpc/gridmap.fth \ Gridded display tools fload ${BP}/cpu/x86/pc/olpc/via/copynand.fth -\ fload ${BP}/cpu/arm/olpc/exc7200-touchscreen.fth \ Touchscreen driver and diagnostic -fload ${BP}/cpu/arm/olpc/rm3150-touchscreen.fth \ Touchscreen driver and diagnostic ++ olpc-cl3 fload ${BP}/cpu/arm/olpc/exc7200-touchscreen.fth \ Touchscreen driver and diagnostic ++ olpc-cl2 fload ${BP}/cpu/arm/olpc/rm3150-touchscreen.fth \ Touchscreen driver and diagnostic fload ${BP}/cpu/arm/olpc/roller.fth \ Accelerometer test
\ fload ${BP}/cpu/arm/olpc/pinch.fth \ Touchscreen gestures
Modified: cpu/arm/olpc/exc7200-touchscreen.fth ============================================================================== --- cpu/arm/olpc/exc7200-touchscreen.fth Tue Dec 6 13:57:29 2011 (r2741) +++ cpu/arm/olpc/exc7200-touchscreen.fth Tue Dec 6 13:57:33 2011 (r2742) @@ -69,7 +69,11 @@ h# 7fff constant touchscreen-max-x h# 7fff constant touchscreen-max-y
+: invert-x ( x y -- x' y ) touchscreen-max-x rot - swap ; +: invert-y ( x y -- x y' ) touchscreen-max-y swap - ; + : scale-xy ( x y -- x' y' ) + invert-x invert-y swap screen-w touchscreen-max-x */ swap screen-h touchscreen-max-y */ ;
