Author: wmb Date: Wed Dec 1 10:08:17 2010 New Revision: 2054 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2054
Log: SDHCI - keep track of last 8 commands and display them when an error occurs.
Modified: dev/mmc/sdhci/sdhci.fth
Modified: dev/mmc/sdhci/sdhci.fth ============================================================================== --- dev/mmc/sdhci/sdhci.fth Wed Dec 1 10:07:24 2010 (r2053) +++ dev/mmc/sdhci/sdhci.fth Wed Dec 1 10:08:17 2010 (r2054) @@ -238,6 +238,25 @@ 0 instance value allow-timeout? 0 instance value timeout?
+8 instance buffer: cmds +: init-cmds ( -- ) cmds 8 h# ff fill ; +: add-cmd ( cmdreg -- ) + cmds 1+ cmds 7 move ( cmdreg ) + 8 rshift cmds 7 + c! +; +: show-cmds ( -- ) + ." Recent commands (decimal): " + cmds 8 bounds do + i c@ dup h# ff <> if ( cmd ) + base @ decimal ( cmd base ) + swap . ( base ) + base ! ( ) + else ( cmd ) + drop ( ) + then ( ) + loop + cr +; : .sderror ( isr -- ) debug? if ." Chip registers: " cr @@ -262,6 +281,10 @@
." SDHCI: Error: ISR = " swap u. ." ESR = " dup u. decode-esr + ." Command reg: " h# e cw@ u. + ." Mode reg: " h# c cw@ u. + ." Arg reg: " h# 8 cl@ u. cr + show-cmds \ debug-me card-clock-off card-power-off @@ -329,9 +352,9 @@ \ Argument register: \ Mode register: --Md-ABD M-Multi d-Direction A-Auto_CMD12 B-BlockCntEnable D-DMAEnable
- : cmd ( arg cmd mode -- ) debug? if ." CMD: " over 4 u.r space then + over add-cmd wait-ready h# c cw! ( arg cmd ) \ Mode swap 8 cl! ( cmd ) \ Arg @@ -994,6 +1017,7 @@ open-count 0= if d# 64 " dma-alloc" $call-parent to scratch-buf then + init-cmds open-count 1+ to open-count true ;
