Author: lwalter Date: Tue Aug 9 20:23:46 2011 New Revision: 2440 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2440
Log: Add mfgtest support
Added: cpu/x86/pc/alex/kbdtest.fth
Added: cpu/x86/pc/alex/kbdtest.fth ============================================================================== --- /dev/null 00:00:00 1970 (empty, because file is newly added) +++ cpu/x86/pc/alex/kbdtest.fth Tue Aug 9 20:23:46 2011 (r2440) @@ -0,0 +1,641 @@ +purpose: Interactive keyboard test shows which keys are pressed +\ See license at end of file + +\needs final-test? 0 value final-test? +\needs smt-test? 0 value smt-test? + +dev /keyboard +hex + +\ This is 1 for the Alex keyboard and 2 for the AT keyboard. +1 value keyboard-type + +\ There are two scancode tables: +\ 1. simple scancode (down values); up value is f0 + scancode +\ 2. e0 + scancode (down values); up value is e0 + f0 + scancode +\ For each scancode: index into keys + +\ For each key: x, y, w, h +\ where x, y, w, h are parameters for painting the key + +struct + /n field >key-x + /n field >key-y + /n field >key-w + /n field >key-h + /n field >key-time +constant /key + +/key d# 128 * buffer: keys + +0 value #keys +0 value key-y +0 value key-x + +\ Based on 1280*800 screen resolution + +d# 10 constant key-gap +d# 12 constant row-gap +d# 0 constant hidden-key-w +d# 70 constant smulti-key-w +d# 70 constant single-key-w +d# 70 constant single-key-h +d# 45 constant squat-key-h +d# 33 constant half-key-h +d# 4 constant half-key-gap +d# 105 constant shift-key-w +d# 540 constant space-key-w +d# 300 constant top-row-offset + +: key-adr ( i -- adr ) /key * keys + ; +: top-key-row ( -- ) top-row-offset to key-y key-gap to key-x ; +: next-key-row ( -- ) + key-y single-key-h + row-gap + to key-y + key-gap to key-x +; +: next-squat-row ( -- ) + key-y squat-key-h + row-gap + to key-y + key-gap to key-x +; +: #keys++ ( -- ) #keys 1+ to #keys ; +: ++key-x ( n -- ) key-x + to key-x ; +: add-key-gap ( -- ) key-gap ++key-x ; +: (make-key) ( x y w h -- ) + #keys key-adr >r + r@ >key-h ! r@ >key-w ! r@ >key-y ! r@ >key-x ! + 0 r> >key-time ! + #keys++ +; +: make-key ( w -- ) dup key-x key-y rot single-key-h (make-key) ++key-x ; +: make-key&gap ( w -- ) make-key add-key-gap ; +: make-squat-key&gap ( w -- ) dup key-x key-y rot squat-key-h (make-key) ++key-x add-key-gap ; +: make-single-key ( -- ) single-key-w make-key&gap ; +: make-smulti-key ( i -- ) + 1 and if + hidden-key-w make-key + else + smulti-key-w make-key + then +; +: make-double-key ( -- ) single-key-w 2* make-key&gap ; +: make-shift-key ( -- ) shift-key-w make-key&gap ; +: make-space-key ( -- ) space-key-w make-key&gap ; +: make-quad-key ( -- ) + key-x key-y single-key-w 2* dup >r single-key-h 2* row-gap + (make-key) + r> ++key-x + add-key-gap +; +: make-narrower-key ( -- ) d# 60 make-key&gap ; +: make-std-key ( -- ) d# 78 make-key&gap ; +: make-wider-key ( -- ) d# 120 make-key&gap ; +: make-wider-key1 ( -- ) d# 143 make-key&gap ; +: make-wider-key2 ( -- ) d# 165 make-key&gap ; +: make-wider-key3 ( -- ) d# 187 make-key&gap ; +: make-squat-key ( -- ) d# 96 make-squat-key&gap ; +: make-space-bar ( -- ) d# 440 make-key&gap ; +: make-top-half ( -- ) + d# 70 key-x key-y rot half-key-h (make-key) +; +: make-bottom-half&gap ( -- ) + d# 70 dup + key-x key-y half-key-h + half-key-gap + rot half-key-h (make-key) + ++key-x add-key-gap +; + +: make-keys1 ( -- ) + 0 to #keys + top-key-row + d# 11 0 do make-squat-key loop \ esc, f1-f10, hole for power + + next-squat-row + d# 13 0 do make-std-key loop \ ` 1-0 -= + make-wider-key \ bksp + + next-key-row + make-wider-key \ tab + d# 13 0 do make-std-key loop \ Q-P []\ + + next-key-row + make-wider-key1 \ Win L + d# 11 0 do make-std-key loop \ A-L ;' + make-wider-key1 \ enter + + next-key-row + make-wider-key3 \ lshift + d# 10 0 do make-std-key loop \ Z-M ,./ + make-wider-key3 \ rshift + + next-key-row + d# 2 0 do make-wider-key2 loop \ lctrl lalt + make-space-bar \ space + make-wider-key \ ralt + d# 2 0 do make-std-key loop \ rctrl < + make-top-half \ ^ + make-bottom-half&gap \ v + make-std-key \ > +; +: make-keys2 ( -- ) + 0 to #keys + top-key-row + make-std-key \ esc + d# 88 ++key-x + 4 0 do make-std-key loop \ F1-F4 + d# 21 ++key-x + 4 0 do make-std-key loop \ F5-F8 + d# 21 ++key-x + 4 0 do make-std-key loop \ F9-F12 + + next-key-row + d# 13 0 do make-std-key loop \ ` 1-0 -= + make-wider-key \ bksp + + next-key-row + make-wider-key \ tab + d# 13 0 do make-std-key loop \ Q-P []\ + + next-key-row + make-wider-key1 \ capslock + d# 11 0 do make-std-key loop \ A-L ;' + make-wider-key1 \ enter + + next-key-row + make-wider-key3 \ lshift + d# 10 0 do make-std-key loop \ Z-M ,./ + make-wider-key3 \ rshift + + next-key-row + d# 2 0 do make-wider-key1 loop \ lctrl lalt + d# 652 make-key&gap \ space + d# 2 0 do make-wider-key1 loop \ ralt rctrl +; + +0 [if] +hex +\ This is indexed by the IBM key number (the physical key number as +\ shown on language-independent drawings of the keyboard layout since +\ the original IBM documentation). The values are scanset1 codes. +create (ibm#>scan1) +\ 0 1 3 3 4 5 6 7 8 9 + 00 c, 29 c, 02 c, 03 c, 04 c, 05 c, 06 c, 07 c, 08 c, 09 c, \ + 0a c, 0b c, 0c c, 0d c, 00 c, 0e c, 0f c, 10 c, 11 c, 12 c, \ 1x + 13 c, 14 c, 15 c, 16 c, 17 c, 18 c, 19 c, 1a c, 1b c, 2b c, \ 2x + 3a c, 1e c, 1f c, 20 c, 21 c, 22 c, 23 c, 24 c, 25 c, 26 c, \ 3x + 27 c, 28 c, 00 c, 1c c, 2a c, 56 c, 2c c, 2d c, 2e c, 2f c, \ 4x + 30 c, 31 c, 32 c, 33 c, 34 c, 35 c, 73 c, 36 c, 1d c, 00 c, \ 5x + 38 c, 39 c, 00 c, 00 c, 00 c, 00 c, 00 c, 00 c, 00 c, 00 c, \ 6x + 00 c, 00 c, 00 c, 00 c, 00 c, 00 c, 00 c, 00 c, 00 c, 00 c, \ 7x + 00 c, 00 c, 00 c, 00 c, 00 c, 00 c, 00 c, 00 c, 00 c, 00 c, \ 8x + 45 c, 47 c, 4B c, 4F c, 00 c, 00 c, 48 c, 4C c, 50 c, 52 c, \ 9x + 37 c, 49 c, 4D c, 51 c, 53 c, 4A c, 4E c, 00 c, 1c c, 00 c, \ 1 + 01 c, 00 c, 3b c, 3c c, 3d c, 3e c, 3f c, 40 c, 41 c, 42 c, \ 11x + 43 c, 44 c, 57 c, 58 c, 00 c, 46 c, 00 c, 00 c, 00 c, 00 c, \ 12x + 79 c, 00 c, 00 c, 5c c, 73 c, 6e c, 00 c, 00 c, 00 c, 00 c, \ 13x (analog intermediates) + 00 c, 00 c, 00 c, 00 c, 00 c, \ 14x + +\ A program to invert the table above. We used the inverted form. +h# 80 buffer: sc1 +: invert-ibm ( -- ) + sc1 h# 80 erase + d# 145 0 do + (ibm#>scan1) i + c@ ?dup if i swap sc1 + c! then + loop + + h# 80 0 do + ." ( " i 2 u.r ." ) " + i 8 bounds do + sc1 i + c@ push-decimal 3 u.r pop-base ." c, " + loop + cr + 8 +loop +; +[then] + +0 value key-stuck? + +d# 128 8 / constant #key-bytes +#key-bytes buffer: key-bitmap +: set-key-bit ( key# -- ) + 8 /mod ( bit# byte# ) + key-bitmap + ( bit# adr ) + tuck c@ ( adr bit# old-byte ) + 1 rot lshift or ( adr byte ) + swap c! +; +-1 value last-1 +-1 value last-2 +: clear-key-bitmap ( -- ) + key-bitmap #key-bytes erase + -1 to last-1 -1 to last-2 +; + +0 [if] +\ Funny-map1 has bits clear at the locations of intermediate +\ slider keys. Those keys are only active by pressing the fn +\ key, and need not be tested during operator finger-sweeps of the +\ keyboard. It is okay if the operator tests them, so we mask +\ off those bits if they happen to be set in the bitmap. +h# ffd5ab57 constant funny-map1 + +create all-keys-bitmap1 +57 c, ab c, d5 c, ff c, ff c, ff c, ff c, ff c, \ Omits the intermediate slider keys +ff c, ff c, ff c, ff c, 03 c, 00 c, 00 c, 00 c, +[else] +\ The mechanical keyboard has no slider keys. All displayed button locations are +\ activated by pressing single keystrokes, so the map is dense +h# ffffffff constant funny-map1 +create all-keys-bitmap1 +ff c, ff c, ff c, ff c, ff c, ff c, ff c, ff c, +ff c, ff c, 3f c, 00 c, 00 c, 00 c, 00 c, 00 c, +[then] + +\ The mechanical keyboard has no slider keys. All displayed button locations are +\ activated by pressing single keystrokes, so the map is dense +h# ffffffff constant funny-map2 +create all-keys-bitmap2 +ff c, ff c, ff c, ff c, ff c, ff c, ff c, ff c, +ff c, ff c, 3f c, 00 c, 00 c, 00 c, 00 c, 00 c, + +: all-tested?1 ( -- flag ) + key-bitmap @ funny-map1 and key-bitmap ! + key-bitmap all-keys-bitmap1 #key-bytes comp 0= +; +: all-tested?2 ( -- flag ) + key-bitmap @ funny-map2 and key-bitmap ! + key-bitmap all-keys-bitmap2 #key-bytes comp 0= +; +defer all-tested? + +\ This table is indexed by the (unescaped) scanset1 code, giving +\ an IBM physical key number. + +decimal +create (scan1>ibm#) +\ 0/8 1/9 2/a 3/b 4/c 5/d 6/e 7/f +( 0 ) 0 c, 110 c, 2 c, 3 c, 4 c, 5 c, 6 c, 7 c, \ 01 is esc +( 8 ) 8 c, 9 c, 10 c, 11 c, 12 c, 13 c, 15 c, 16 c, +( 10 ) 17 c, 18 c, 19 c, 20 c, 21 c, 22 c, 23 c, 24 c, +( 18 ) 25 c, 26 c, 27 c, 28 c, 43 c, 58 c, 31 c, 32 c, \ 1d is ctrl, 1c is Enter +( 20 ) 33 c, 34 c, 35 c, 36 c, 37 c, 38 c, 39 c, 40 c, +( 28 ) 41 c, 1 c, 44 c, 29 c, 46 c, 47 c, 48 c, 49 c, +( 30 ) 50 c, 51 c, 52 c, 53 c, 54 c, 55 c, 57 c, 100 c, +( 38 ) 60 c, 61 c, 30 c, 112 c, 113 c, 114 c, 115 c, 116 c, +( 40 ) 117 c, 118 c, 119 c, 120 c, 121 c, 90 c, 125 c, 91 c, +( 48 ) 96 c, 101 c, 105 c, 92 c, 97 c, 102 c, 106 c, 93 c, +( 50 ) 98 c, 103 c, 99 c, 104 c, 0 c, 0 c, 45 c, 122 c, +( 58 ) 123 c, 59 c, 0 c, 0 c, 133 c, 0 c, 0 c, 0 c, \ scan h# 59 is Fn - ibm# d# 59 +( 60 ) 0 c, 0 c, 0 c, 0 c, 0 c, 150 c, 153 c, 151 c, \ 66-68 are left rocker +( 68 ) 152 c, 154 c, 0 c, 0 c, 0 c, 0 c, 135 c, 0 c, \ 69 is rotate +( 70 ) 0 c, 0 c, 0 c, 56 c, 0 c, 0 c, 0 c, 0 c, +( 78 ) 0 c, 130 c, 0 c, 0 c, 0 c, 0 c, 0 c, 0 c, +hex + +\ This should be a lookup table. It would be smaller that way +: e0-scan1>ibm# ( scancode -- ibm# ) + case + h# 38 of d# 62 endof \ R ALT + +\ For a standard PC keyboard +( \ ) h# 1c of d# 64 endof \ Numeric enter +( \ ) h# 1d of d# 64 endof \ R CTRL + h# 52 of d# 75 endof \ Insert + h# 53 of d# 76 endof \ Delete +( \ ) h# 47 of d# 80 endof \ Home +( \ ) h# 4f of d# 81 endof \ End +( \ ) h# 49 of d# 85 endof \ PageUp +( \ ) h# 51 of d# 86 endof \ PageDown + + h# 3b of d# 112 endof \ Fn 1 + h# 3c of d# 113 endof \ Fn 2 + h# 3d of d# 114 endof \ Fn 3 + h# 3e of d# 115 endof \ Fn 4 + h# 3f of d# 116 endof \ Fn 5 + h# 40 of d# 117 endof \ Fn 6 + h# 41 of d# 118 endof \ Fn 7 + h# 42 of d# 119 endof \ Fn 8 + h# 43 of d# 120 endof \ Fn 9 + h# 44 of d# 121 endof \ Fn 10 + h# 57 of d# 122 endof \ Fn 11 + h# 58 of d# 123 endof \ Fn 12 + + h# 4b of d# 79 endof \ Left Arrow + h# 48 of d# 83 endof \ Up Arrow + h# 50 of d# 84 endof \ Down Arrow + h# 4d of d# 89 endof \ Right Arrow + + h# 5b of d# 131 endof \ Win L + endcase +; + +: scan1>ibm# ( scancode1 esc? -- ibm# ) + if e0-scan1>ibm# else (scan1>ibm#) + c@ then +; + +\ "key#" is a physical location on the screen +\ "ibm#" is the key number as shown on the original IBM PC documents +decimal + +create ibm#s1 + \ Top row, key#s 0x00-0x18 + 110 c, \ ESC + 112 c, 113 c, 114 c, 115 c, 116 c, 117 c, \ F1-F6 + 118 c, 119 c, 120 c, 121 c, \ F7-F10 + + \ Number row - `1234567890-= BS + 1 c, 2 c, 3 c, 4 c, 5 c, 6 c, 7 c, 8 c, 9 c, 10 c, 11 c, 12 c, 13 c, 15 c, + + \ Top alpha row - tab QWERTYUIOP []\ + 16 c, 17 c, 18 c, 19 c, 20 c, 21 c, 22 c, 23 c, 24 c, 25 c, 26 c, 27 c, 28 c, 29 c, + + \ Middle alpha row - win ASDFGHIJKL ;' enter + 131 c, 31 c, 32 c, 33 c, 34 c, 35 c, 36 c, 37 c, 38 c, 39 c, 40 c, 41 c, 43 c, + + \ Bottom alpha row - shift ZXCVBNM , . / shift + 44 c, 46 c, 47 c, 48 c, 49 c, 50 c, 51 c, 52 c, 53 c, 54 c, 55 c, 57 c, + + \ Function row - ctrl alt space alt ctrl < ^v > + 58 c, 60 c, 61 c, 62 c, 64 c, 79 c, 83 c, 84 c, 89 c, + +here ibm#s1 - constant /ibm#s1 + +\ "key#" is a physical location on the screen +\ "ibm#" is the key number as shown on the original IBM PC documents +\ The actual #s for F6 and F7 are 146 and 147, but the EC does some magic +create ibm#s2 + \ Top row, key#s 0x00-0x18 + 110 c, \ ESC + 112 c, 113 c, 114 c, 115 c, 116 c, 117 c, \ F1-F6 + 118 c, 119 c, 120 c, 121 c, 122 c, 123 c, \ F7-F12 +\ 148 c, 149 c, \ ins, del +\ 75 c, 76 c, \ ins, del + + \ Number row - `1234567890-= BS + 1 c, 2 c, 3 c, 4 c, 5 c, 6 c, 7 c, 8 c, 9 c, 10 c, 11 c, 12 c, 13 c, 15 c, \ 1 is really 150 + + \ Top alpha row - tab QWERTYUIOP []\ + 16 c, 17 c, 18 c, 19 c, 20 c, 21 c, 22 c, 23 c, 24 c, 25 c, 26 c, 27 c, 28 c, 29 c, \ 28 is really 151 + + \ Middle alpha row - capslock ASDFGHIJKL ;' enter + 30 c, 31 c, 32 c, 33 c, 34 c, 35 c, 36 c, 37 c, 38 c, 39 c, 40 c, 41 c, 43 c, + + \ Bottom alpha row - shift ZXCVBNM , . / shift + 44 c, 46 c, 47 c, 48 c, 49 c, 50 c, 51 c, 52 c, 53 c, 54 c, 55 c, 57 c, + + \ Function row - ctrl alt space alt ctrl + 58 c, 60 c, 61 c, 62 c, 64 c, + +here ibm#s2 - constant /ibm#s2 +hex + +defer make-keys ( -- ) +defer ibm#s ( -- adr ) +defer /ibm#s ( -- n ) + +: ibm#>key# ( ibm# -- true | key# false ) + /ibm#s 0 ?do ( ibm# ) + dup ibm#s i + c@ = if + drop i false unloop exit + then + loop ( ibm# ) + drop true +; + +0 [if] +\ This is a program to invert the ibm#s table +d# 145 buffer: sc2 +: invert-key ( -- ) + sc2 d# 145 erase + h# 59 0 do + i ibm#s i + c@ sc2 + c! + loop + + d# 145 0 do + ." ( " i push-decimal 3 u.r pop-base ." ) " + i d# 10 bounds do + sc2 i + c@ push-hex 2 u.r pop-base ." c, " + loop + cr + d# 10 +loop +; +[then] + +0 [if] +\ These are maps from scanset 2 to key position numbers. +\ They are no longer used +hex +create raw-scancode + ( -0 ) -1 c, 10 c, 0d c, 09 c, 06 c, 02 c, 04 c, 16 c, + ( 08 ) -1 c, 12 c, 0f c, 0b c, 08 c, 27 c, 19 c, 50 c, + ( 10 ) -1 c, 52 c, 42 c, -1 c, 35 c, 28 c, 1a c, -1 c, + ( 18 ) -1 c, -1 c, 43 c, 37 c, 36 c, 29 c, 1b c, -1 c, + ( 20 ) -1 c, 45 c, 44 c, 38 c, 2a c, 1d c, 1c c, -1 c, + ( 28 ) -1 c, 53 c, 46 c, 39 c, 2c c, 2b c, 1e c, -1 c, + ( 30 ) -1 c, 48 c, 47 c, 3b c, 3a c, 2d c, 1f c, -1 c, + ( 38 ) -1 c, -1 c, 49 c, 3c c, 2e c, 20 c, 21 c, -1 c, + ( 40 ) -1 c, 4a c, 3d c, 2f c, 30 c, 23 c, 22 c, -1 c, + ( 48 ) -1 c, 4b c, 4c c, 3e c, 3f c, 31 c, 24 c, -1 c, + ( 50 ) -1 c, 4f c, 40 c, -1 c, 32 c, 25 c, -1 c, -1 c, + ( 58 ) -1 c, 4d c, 34 c, 33 c, -1 c, 41 c, -1 c, -1 c, + ( 60 ) -1 c, -1 c, -1 c, -1 c, -1 c, -1 c, 26 c, -1 c, + ( 68 ) -1 c, -1 c, -1 c, -1 c, -1 c, 4f c, -1 c, -1 c, + ( 70 ) -1 c, -1 c, -1 c, -1 c, -1 c, -1 c, 00 c, -1 c, + ( 78 ) 14 c, -1 c, -1 c, -1 c, -1 c, -1 c, -1 c, -1 c, + +create e0-scancode + ( 00 ) -1 c, 10 c, 0d c, 09 c, 06 c, 02 c, 04 c, 16 c, + ( 08 ) 17 c, 12 c, 0f c, 0b c, 08 c, -1 c, -1 c, -1 c, + ( 10 ) -1 c, 54 c, -1 c, 13 c, -1 c, -1 c, -1 c, 18 c, + ( 18 ) -1 c, 11 c, -1 c, -1 c, -1 c, -1 c, -1 c, 51 c, + ( 20 ) -1 c, -1 c, -1 c, -1 c, -1 c, -1 c, -1 c, 55 c, + ( 28 ) -1 c, -1 c, -1 c, -1 c, -1 c, -1 c, -1 c, 18 c, + ( 30 ) -1 c, -1 c, -1 c, -1 c, -1 c, -1 c, -1 c, -1 c, + ( 38 ) -1 c, 0e c, -1 c, -1 c, -1 c, -1 c, -1 c, -1 c, + ( 40 ) -1 c, -1 c, -1 c, -1 c, -1 c, -1 c, -1 c, -1 c, + ( 48 ) -1 c, -1 c, -1 c, -1 c, -1 c, -1 c, -1 c, -1 c, + ( 50 ) -1 c, 0c c, -1 c, 0a c, -1 c, -1 c, -1 c, 17 c, + ( 58 ) -1 c, -1 c, -1 c, -1 c, 07 c, -1 c, -1 c, 05 c, + ( 60 ) -1 c, 53 c, 03 c, 01 c, 01 c, -1 c, -1 c, -1 c, + ( 68 ) -1 c, 58 c, -1 c, 56 c, 56 c, -1 c, -1 c, 15 c, + ( 70 ) 4d c, 26 c, 57 c, -1 c, 58 c, 4e c, 00 c, -1 c, + ( 78 ) 14 c, -1 c, 57 c, -1 c, -1 c, 4e c, -1 c, -1 c, + +raw-scancode value cur-sc-table +[then] + +h# f81f constant down-key-color +h# 07ff constant tested-key-color +h# 001f constant idle-key-color +h# ffff constant kbd-bc + +0 value esc? + +: scan1->key# ( scancode -- true | key# false ) + esc? scan1>ibm# + ?dup 0= if true exit then + ibm#>key# +; + +: set-key-time ( timestamp key-adr -- ) + over 0<> over >key-time @ 0<> and if ( timestamp key-adr ) + \ If both timestamp and old key time are nonzero, then we preserve the old key time + >key-time @ d# 3,000 + - 0> to key-stuck? + else + \ If either timestamp or old key time is 0, we set the key time + >key-time ! + then +; + +: draw-key ( key# color timestamp -- ) + rot key-adr >r ( color# timestamp r: key-adr ) + r@ set-key-time ( color# r: key-adr ) + r@ >key-w @ hidden-key-w = if ( color# r: key-adr ) + r> 2drop ( ) + else ( color# r: key-adr ) + r@ >key-x @ r@ >key-y @ r@ >key-w @ r> >key-h @ ( color# x y w h ) + " fill-rectangle" $call-screen ( ) + then +; +: key-tested ( key# -- ) tested-key-color 0 draw-key ; +: key-down ( key# -- ) down-key-color get-msecs draw-key ; +: key-up ( key# -- ) idle-key-color 0 draw-key ; + +: fill-screen ( color -- ) + 0 0 " dimensions" $call-screen " fill-rectangle" $call-screen +; + +: draw-keyboard ( -- ) + kbd-bc fill-screen + #keys 0 ?do i key-up loop +\ final-test? smt-test? or 0= if 0 d# 13 at-xy ." X" then +; + +false value verbose? + +: process-raw ( scan-code -- exit? ) + verbose? if dup u. then + dup h# e0 = if ( scan ) + drop true to esc? ( ) + else ( scan ) + dup h# 7f and scan1->key# if ( scan ) + drop ( ) + else ( scan key# ) + swap h# 80 and if \ Up ( key# ) + final-test? smt-test? or if ( key# ) + dup key-tested ( key# ) + dup 0= last-1 0= and last-2 0= and if ( key# ) + drop true ( exit? ) + else ( key# ) + last-1 to last-2 to last-1 ( ) + all-tested? ( exit? ) + then + else ( key# ) + dup key-up ( key# ) + \ 0 is the ESC key + 0= ( exit? ) + then ( exit? ) + if true exit then ( ) + else ( key# ) + dup set-key-bit ( key# ) + key-down ( ) + then ( ) + then ( ) + false to esc? ( ) + then ( ) + false +; + +0 value last-timestamp +: selftest-keys ( -- ) + false to esc? + clear-key-bitmap + get-msecs to last-timestamp + begin + final-test? smt-test? or if + key-stuck? if exit then + then + get-data? if ( scancode ) + process-raw ( exit? ) + get-msecs to last-timestamp + else + final-test? smt-test? or if + false \ Final test exit inside process-raw + else +\ get-msecs last-timestamp - d# 100,000 >= +false + then + then ( exit? ) + until + begin get-data? while drop repeat +; + +: toss-keys ( -- ) begin key? while key drop repeat ; + +: set-keyboard-type ( -- ) + keyboard-type case + 1 of ['] make-keys1 ['] ibm#s1 ['] /ibm#s1 ['] all-tested?1 endof + 2 of ['] make-keys2 ['] ibm#s2 ['] /ibm#s2 ['] all-tested?2 endof + ( default ) true abort" Unknown keyboard type" + endcase + to all-tested? to /ibm#s to ibm#s to make-keys +; + +warning @ warning off +: selftest ( -- error? ) + open 0= if true exit then + + set-keyboard-type + + make-keys + + 0 to key-stuck? + cursor-off draw-keyboard + true to locked? \ Disable the keyboard alarm handler; it steals our scancodes + selftest-keys + false to locked? + cursor-on + screen-ih iselect erase-screen iunselect + page + close + + final-test? smt-test? or if + key-stuck? if + ." Stuck key" cr + true exit + then + + all-tested? if + false + else + ." Some keys were not pressed" cr + true + then + else + confirm-selftest? + then +; +warning ! + +device-end + +\ LICENSE_BEGIN +\ Copyright (c) 2007 FirmWorks +\ +\ Permission is hereby granted, free of charge, to any person obtaining +\ a copy of this software and associated documentation files (the +\ "Software"), to deal in the Software without restriction, including +\ without limitation the rights to use, copy, modify, merge, publish, +\ distribute, sublicense, and/or sell copies of the Software, and to +\ permit persons to whom the Software is furnished to do so, subject to +\ the following conditions: +\ +\ The above copyright notice and this permission notice shall be +\ included in all copies or substantial portions of the Software. +\ +\ THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, +\ EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF +\ MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND +\ NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE +\ LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION +\ OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION +\ WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. +\ +\ LICENSE_END
