Author: wmb Date: 2009-04-29 19:50:29 +0200 (Wed, 29 Apr 2009) New Revision: 1162
Added: dev/usb2/device/debugport.fth Log: Checked in debugport.fth
Added: dev/usb2/device/debugport.fth =================================================================== --- dev/usb2/device/debugport.fth (rev 0) +++ dev/usb2/device/debugport.fth 2009-04-29 17:50:29 UTC (rev 1162) @@ -0,0 +1,291 @@ +purpose: Driver for USB 2.0 Debug Device via EHCI Debug Port + +\ USB PID values: +\ Token: out e1 in 69 sof a5 setup 2d +\ Data: data0 c3 data1 4b data2 87 mdata 0f +\ Handshake: ack d2 nak 5a stall 1e nyet 96 +\ Special: pre/err 3c split 78 ping b4 reserved/unused f0 + +0 value ehci-cfg \ Set to known value to skip search +0 value dbgp-offset \ Set to known value to skip search +0 value dbgp-bar \ Base address register that maps the DBGP + +0 value ebase +0 value dbgp-base + +\ Only look on the main PCI host bridge ... +: slot,fn> ( slot fn -- cfg-base ) swap d# 11 lshift swap 8 lshift or ; +: find-ehci ( -- ) + ehci-cfg if exit then + d# 32 0 do \ Scan all slot + i 0 slot,fn> config-l@ h# ffff.ffff <> if + 8 0 do + j i slot,fn> 8 + config-l@ ( class ) + h# ffffff00 and h# 0c032000 = if ( ) + j i slot,fn> to ehci-cfg ( ) + unloop unloop exit + then + loop + then + loop + true abort" Can't find EHCI" +; +: find-dbgp-regs ( -- ) + dbgp-offset if exit then \ Don't search if known + ehci-cfg h# 34 + config-l@ ( capability-ptr ) + begin dup while ( cap-offset ) + ehci-cfg + ( cfg-adr ) + dup config-b@ h# 0a = if ( cfg-adr ) + 2+ config-w@ ( dbgp-ptr ) + dup h# 1fff and to dbgp-offset ( ) + d# 13 rshift 7 and 1- /l* h# 10 + to dbgp-bar + exit + then ( cfg-adr ) + 1+ config-b@ ( cap-offset' ) + repeat ( cap-offset ) + true abort" Can't find debug port registers" +; + +: find-dbgp-controller ( -- ) + find-ehci + find-dbgp-regs + + ehci-cfg 4 + dup config-w@ 2 or swap config-w! \ Enable memory access + ebase 0= if + ehci-cfg dbgp-bar + config-l@ ( map-it ) to ebase \ Get the BAR + then + dbgp-base 0= if + ebase dbgp-offset + to dbgp-base + then +; + +: pscbase ( port# -- adr ) /l* h# 44 + ebase c@ + ebase + ; +: psc@ ( port# -- 0 ) pscbase l@ ; : psc! ( val port# -- ) pscbase l! ; +: rstport ( port# -- ) + dup psc@ h# 100 or 4 invert and over psc! + d# 100 ms + dup psc@ h# 100 invert and swap psc! + d# 10 ms +; + +: +dbgp ( reg# -- adr ) dbgp-offset + ebase + ; +: dbgp-l! dbgp-base + l! ; : dbgp-b! dbgp-base + c! ; +: dbgp-l@ dbgp-base + l@ ; : dbgp-b@ dbgp-base + c@ ; + +: disable-dbgp ( -- ) \ Disable the debug port + dbgp-base if + 0 0 dbgp-l! d# 10 ms + then +; + +: grab-dbgp ( -- ) + find-dbgp-controller + + disable-dbgp + 0 rstport \ Put the debug port in probe state + h# 5001.0400 0 dbgp-l! \ Enable the debug port + d# 10 ms + 0 dbgp-l@ h# 1000.0000 and 0= abort" Can't enable debug port" + 0 psc@ 4 invert and 0 psc! \ Detach the normal EHCI host controller +; + +: wait-done ( -- finished? ) + begin 2 dbgp-b@ 1 and until + 1 2 dbgp-b! \ Turn off the done bit + 0 dbgp-b@ h# 40 and if \ Error + 0 dbgp-l@ 7 rshift 7 and + case + 1 of ." DBGP USB hardware error" cr endof + 2 of ." DBGP transacation error" cr endof + endcase + abort + then +; +: data-toggle ( -- ) 5 dbgp-b@ h# 88 xor 5 dbgp-b! ; +: acked? ( -- flag ) + 6 dbgp-b@ ( received-PID ) + case + \ Toggle DATA0 to DATA1 on an ACK + h# d2 of data-toggle true endof \ ACK + h# 96 of data-toggle true endof \ NYET (perhaps initiate slowdown) + h# 1e of true abort" DBGP stall" endof \ STALL + ( default ) false swap \ Probably NAK + endcase +; + +: dbgp-rcv ( -- ) + h# 69 4 dbgp-b! \ IN PID + h# 20 0 dbgp-b! \ Go, Read# + wait-done +; + +: dbgp-send ( size -- ) + h# 30 or + begin dup 0 dbgp-b! wait-done acked? until ( control-val ) + drop +; + +0 value dbgp-in +0 value dbgp-out + +: set-dev ( device -- ) h# 11 dbgp-b! ; +: set-endpoint ( ep -- ) h# 10 dbgp-b! ; +: control-out ( data1 data0 -- ) + 0 set-endpoint \ Control endpoint + 8 dbgp-l! \ wValue.bRequest.bRequestType + h# c dbgp-l! \ wSize.wIndex + h# c3.2d 4 dbgp-l! \ DATA0.SETUP + 8 dbgp-send \ Setup + Data + dbgp-rcv \ Status +; +: debug-mode ( -- ) + 0 h# 0006.03.00 control-out \ size0.index0 DEBUG_MODE(6).SET_FEATURE(3).REQUESTTYPE_OUT(0) +; +: force-dbgp-adr ( -- error? ) + 0 h# 007f.05.00 control-out \ size0.index0 NewAddress.SET_ADDRESS(5).REQUESTTYPE_OUT(0) + h# 7f set-dev +; + +: get-dbgp-desc ( -- ) + 0 set-endpoint \ Control endpoint + h# 0a00.06.80 8 dbgp-l! \ USB_DT_DEBUG<<8(a00).GET_DESCRIPTOR(6).REQUESTTYPE_IN(80) + h# 0004.0000 h# c dbgp-l! \ SIZE(4).Index(0) + h# c3.2d 4 dbgp-l! \ DATA0.SETUP + 8 dbgp-send \ Setup + dbgp-rcv \ In + h# 4b.e1 4 dbgp-l! \ Status (DATA1.OUT) + 0 dbgp-send \ Setup +; +: find-dbgp-device ( -- ) + d# 80 0 do + i set-dev + ['] get-dbgp-desc catch 0= if + 8 dbgp-l@ lbsplit to dbgp-out to dbgp-in 2drop + unloop exit + then + loop + true abort" No Debug Device" +; + +true value dbgp-off? +: uemit ( char -- ) + dbgp-off? if drop exit then + dbgp-out set-endpoint \ Bulk out endpoint + 8 dbgp-l! \ char + h# e1 4 dbgp-b! \ OUT + 1 dbgp-send +; + +0 value nkeys +0 value k0 +0 value k1 +: pullkey ( -- char ) + nkeys 1- 0 max to nkeys + k0 lbsplit k1 lbsplit 0 bljoin to k1 bljoin to k0 ( char ) +; + +: ukey? ( -- flag ) + dbgp-off? if false exit then + nkeys if true exit then + dbgp-in set-endpoint \ Bulk in endpoint + dbgp-rcv + 6 dbgp-b@ ( received-PID ) + dup h# c3 = swap h# 4b = or if + 0 dbgp-b@ to nkeys + 8 dbgp-l@ to k0 + h# c dbgp-l@ to k1 + nkeys 0<> + else + false + then +; +: ukey ( -- char ) + dbgp-off? if 0 exit then + nkeys if pullkey exit then + begin ukey? until + pullkey +; + +: dbgp-io ( -- ) + ['] uemit is (emit + ['] ukey is (key + ['] ukey? is key? + ['] default-type is (type + ['] emit1 is emit + ['] type1 is type +; + +: init-dbgp ( -- ) + grab-dbgp \ Attach the debug host controller + find-dbgp-device + force-dbgp-adr + debug-mode +; +: dbgp-off ( -- ) + true to dbgp-off? \ Make the uemit routines do nothing + disable-dbgp +; + +: inituarts + ['] init-dbgp catch to dbgp-off? + \ Leave the EHCI debug port off if a Debug Device wasn't attached + dbgp-off? dbgp-base 0<> and if disable-dbgp then +; + +: start-dbgp ( -- ) + init-dbgp + dbgp-io +; + +[ifdef] notdef +Sending bytes via debug port, assuming it's already inited. + + ( char in al ) + dbgp_adr # bp mov + al 8 [bp] mov \ char + OUT_ENDP # h# 10 [bp] byte mov \ endpoint + h# e1 # 4 [bp] byte mov \ OUT token + begin + h# 31 # 0 [bp] byte mov \ Go, write, 1 char + begin 1 # 2 [bp] byte tst 0<> until \ Wait for DONE + 1 # 2 [bp] byte mov \ Clear done bit + h# 40 # 0 [bp] byte tst \ Check error bit + 0<> if \ Error + al al cmp \ Force loop exit + else \ Not error + 6 [bp] al mov \ Get PID + h# d2 # al cmp \ Compare to ACK + 0<> if \ Not ACK + h# 96 # al cmp \ Compare to NYET + then + then \ Z will be set for exit + 0= until + +Receiving bytes via debug port, assuming it's already inited. + + dbgp_adr # bp mov + IN_ENDP # h# 10 [bp] byte mov \ endpoint + h# 69 # 4 [bp] byte mov \ IN token + h# 20 # 0 [bp] byte mov \ Go, read + begin 1 # 2 [bp] byte tst 0<> until \ Wait for DONE + 1 # 2 [bp] byte mov \ Clear done bit + h# 40 # 0 [bp] byte tst \ Check error bit + 0<> if \ Error + clrc + else + 6 [bp] al mov \ Get PID + h# c3 # al cmp 0= if \ Compare to DATA0 + 8 [bp] al mov + setc + else + h# c3 # al cmp 0= if \ Compare to DATA1 + 8 [bp] al mov + setc + else + clrc + then + then + then + \ Carry set if got a char, and char in al + +[then]
