Author: quozl Date: Thu Aug 9 10:28:22 2012 New Revision: 3142 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3142
Log: OLPC CL4 - Neonode touchscreen driver, bare bones
Added: cpu/arm/olpc/nn-touchscreen.fth Modified: cpu/arm/olpc/1.75/fw.bth cpu/arm/olpc/1.75/gpiopins.fth cpu/arm/olpc/cl4/fw.bth
Modified: cpu/arm/olpc/1.75/fw.bth ============================================================================== --- cpu/arm/olpc/1.75/fw.bth Thu Aug 9 10:27:52 2012 (r3141) +++ cpu/arm/olpc/1.75/fw.bth Thu Aug 9 10:28:22 2012 (r3142) @@ -25,6 +25,7 @@ fload ${BP}/cpu/arm/olpc/1.75/sdhci.fth fload ${BP}/cpu/arm/olpc/1.75/lcdcfg.fth fload ${BP}/cpu/arm/olpc/1.75/usb.fth +fload ${BP}/cpu/arm/olpc/nn-touchscreen.fth fload ${BP}/cpu/arm/olpc/rm3150-touchscreen.fth fload ${BP}/cpu/arm/olpc/1.75/compass.fth fload ${BP}/cpu/arm/olpc/1.75/switches.fth
Modified: cpu/arm/olpc/1.75/gpiopins.fth ============================================================================== --- cpu/arm/olpc/1.75/gpiopins.fth Thu Aug 9 10:27:52 2012 (r3141) +++ cpu/arm/olpc/1.75/gpiopins.fth Thu Aug 9 10:28:22 2012 (r3142) @@ -66,3 +66,4 @@ d# 14 constant touch-hd-gpio# d# 98 constant touch-tck-gpio# d# 152 constant touch-rst-gpio# +d# 99 constant touch-scr-gpio#
Modified: cpu/arm/olpc/cl4/fw.bth ============================================================================== --- cpu/arm/olpc/cl4/fw.bth Thu Aug 9 10:27:52 2012 (r3141) +++ cpu/arm/olpc/cl4/fw.bth Thu Aug 9 10:28:22 2012 (r3142) @@ -18,7 +18,7 @@ fload ${BP}/cpu/arm/olpc/cl4/sdhci.fth fload ${BP}/cpu/arm/olpc/1.75/lcdcfg.fth fload ${BP}/cpu/arm/olpc/1.75/usb.fth -\ fload ${BP}/cpu/arm/olpc/nn-touchscreen.fth +fload ${BP}/cpu/arm/olpc/nn-touchscreen.fth fload ${BP}/cpu/arm/olpc/cl4/switches.fth fload ${BP}/cpu/arm/olpc/cl4/leds.fth fload ${BP}/cpu/arm/olpc/cl4/testitems.fth
Added: cpu/arm/olpc/nn-touchscreen.fth ============================================================================== --- /dev/null 00:00:00 1970 (empty, because file is newly added) +++ cpu/arm/olpc/nn-touchscreen.fth Thu Aug 9 10:28:22 2012 (r3142) @@ -0,0 +1,139 @@ +\ See license at end of file +purpose: Driver and diagnostic for Neonode zForce MultiSensing I2C Touchscreen + +0 0 " 4,a0" " /twsi" begin-package +my-space encode-int my-address encode-int encode+ " reg" property + +\ XXX these are really platform-related, not touchscreen-related +: targets? ( -- flag ) final-test? ; +: .tsmsg ( -- ) 0 d# 27 at-xy ." Touchscreen test. Type a key to exit" cr ; + +fload ${BP}/cpu/arm/olpc/touchscreen-common.fth + +: reset ( -- ) touch-rst-gpio# dup gpio-clr gpio-set d# 250 ms ; +: no-data? ( -- false | true ) touch-scr-gpio# gpio-pin@ ; + +d# 250 constant /packet +/packet buffer: packet +0 value packet-size + +: in? ( -- false | true ) + no-data? if false then + + packet 2 " twsi-read" $call-parent ( ) + packet 1+ c@ ( size ) + dup 2+ to packet-size ( size ) + + packet 2+ swap " twsi-read" $call-parent ( ) + true +; + +: out ( byte ... bytes# -- ) " twsi-out" $call-parent ; + +defer process +' noop to process + +: expect ( id msecs -- ) + get-msecs + ( id limit ) + begin + in? if + process + over packet 2+ c@ ( id limit received-id ) + = if 2drop exit then + then ( id limit ) + dup get-msecs - 0< ( id limit timeout? ) + until ( id limit ) + 2drop ( ) +; + +: read-boot-complete ( -- ) h# 07 d# 10 expect ; + +: initialise ( -- ) h# ee h# 01 h# 01 3 out h# 01 d# 10 expect ; + +: set-resolution ( -- ) + set-geometry + h# ee h# 05 h# 02 screen-w wbsplit screen-h wbsplit 7 out + h# 02 d# 10 expect +; + +: start ( -- ) h# ee h# 01 h# 04 3 out ; + +: deactivate ( -- ) h# ee h# 01 h# 00 3 out h# 00 d# 10 expect ; + +: configure ( -- ) + read-boot-complete + initialise + set-resolution + start +; + +: open ( -- okay? ) + my-unit " set-address" $call-parent + no-data? if reset then + no-data? if false exit then + ['] configure catch if false exit then + true +; + +: close + deactivate +; + +: stream-poll? ( -- false | x y buttons true ) + in? if + packet 2+ c@ h# 04 = if + packet 4 + w@ packet 6 + w@ ( x y ) + packet 8 + c@ 3 and 0= ( x y down? ) + true ( x y buttons true ) + else + false + then + else + false + then +; + +: selftest + open 0= if + ." No touchscreen present" cr false exit + then + + \ FIXME: graphically show data on screen until key + begin + in? if + ." rx: " packet packet-size bounds do + i c@ 0 <# # # #> type space + loop cr + then + key? + until + key drop + + close false +; + +end-package + +\ LICENSE_BEGIN +\ Copyright (c) 2012 FirmWorks +\ +\ Permission is hereby granted, free of charge, to any person obtaining +\ a copy of this software and associated documentation files (the +\ "Software"), to deal in the Software without restriction, including +\ without limitation the rights to use, copy, modify, merge, publish, +\ distribute, sublicense, and/or sell copies of the Software, and to +\ permit persons to whom the Software is furnished to do so, subject to +\ the following conditions: +\ +\ The above copyright notice and this permission notice shall be +\ included in all copies or substantial portions of the Software. +\ +\ THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, +\ EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF +\ MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND +\ NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE +\ LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION +\ OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION +\ WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. +\ +\ LICENSE_END
