Author: wmb Date: 2009-05-06 20:54:58 +0200 (Wed, 06 May 2009) New Revision: 1174
Modified: cpu/x86/pc/olpc/rmstart.fth Log: OLPC - fixed rmstart to setup the GDT consistently with the new version of resetend.fth
Modified: cpu/x86/pc/olpc/rmstart.fth =================================================================== --- cpu/x86/pc/olpc/rmstart.fth 2009-05-06 07:08:33 UTC (rev 1173) +++ cpu/x86/pc/olpc/rmstart.fth 2009-05-06 18:54:58 UTC (rev 1174) @@ -29,6 +29,7 @@
\needs start-assembling fload ${BP}/cpu/x86/asmtools.fth \needs write-dropin fload ${BP}/forth/lib/mkdropin.fth +fload ${BP}/cpu/x86/pc/port80.fth
hex
@@ -58,7 +59,6 @@ " h# 9 # ah cmp > if h# 57 # ah add else h# 30 # ah add then " evaluate
" al bl mov ah al mov bl ah mov " evaluate - ;
[ifdef] debug-reset @@ -106,26 +106,21 @@
\ ffff.fc00 GDT
- 0 w, 0 l, 0 w, \ 0 Mandatory null descriptor - 0 w, 0 l, 0 w, \ * Another null descriptor + 1f w, ffff.fc00 l, 0 w, \ 0 Pointer to GDT in first slot + 0 w, 0 l, 0 w, \ * Null descriptor ffff w, 9b.000000 l, 00.c.f w, \ 10 Code, linear=physical, full 4Gbytes ffff w, 93.000000 l, 00.c.f w, \ 18 Data, linear=physical, full 4Gbytes
- \ ffff.fc20 GDT limit + address - - 1f w, ffff.fc00 l, \ # slots (4 * 8 - 1) , starting address - 0 w, \ Padding - \ ------->>>>> Startup code, reached by branch from main entry point below \ - \ ffff.fc28 + \ ffff.fc20
here \ Mark the beginning of this code so its size may be determined \ and so that a jump to it may be assembled later.
16-bit
- h# 01 # al mov al h# 80 # out + h# 01 port80
\ The following code sequence is a workaround for a hardware situation. \ The MIC-on LED defaults to "on", because the CODEC chip powers on with @@ -220,7 +215,7 @@ then
\ Return to here after the reset - h# 02 # al mov al h# 80 # out + h# 02 port80
op: h# 1430 # dx mov op: dx ax in op: h# 9999 # ax cmp = if h# 34 # al mov al h# 70 # out \ Write to CMOS 0x34 @@ -243,7 +238,7 @@ \ above is reachable with a 16-bit address and through the "boosted" \ code segment.
- op: cs: 0f c, 01 c, 16 c, fc20 w, \ lgdte cs:[fc20] Setup GDT + op: cs: 0f c, 01 c, 16 c, fc00 w, \ lgdte cs:[fc00] Setup GDT
op: cr0 bx mov \ Get existing CR0 value
@@ -253,7 +248,7 @@ eb c, 0 c, \ jmp to next location to flush prefetch queue \ note: CPL is now 0
- h# 03 # al mov al h# 80 # out + h# 03 port80
op: h# 1430 # dx mov op: dx ax in op: h# 9999 # ax cmp = if h# 34 # al mov al h# 70 # out \ Write to CMOS 0x34 @@ -288,7 +283,7 @@ ascii h report [then]
- h# 0f # al mov al h# 80 # out + h# 0f port80
op: h# 1430 # dx mov op: dx ax in op: h# 9999 # ax cmp = if h# 34 # al mov al h# 70 # out \ Write to CMOS 0x34 @@ -302,8 +297,8 @@
here over - ( adr , size-of-preceding-code )
- \ ffff.fc28 is the location of the code that follows the GDT - ffff.fff0 ffff.fc28 - swap - ( address #bytes-to-pad ) + \ ffff.fc20 is the location of the code that follows the GDT + ffff.fff0 ffff.fc20 - swap - ( address #bytes-to-pad )
\ The code mustn't extend past ffff.ffc0, because that is where PC \ manufacturers put the 0x10-byte BIOS version string. @@ -318,9 +313,8 @@ \ when it comes out of reset
16-bit - cli cld \ Turn off interrupts (does not affect NMI) - #) jmp \ Relative jump back to ffff.fc28 + #) jmp \ Relative jump back to ffff.fc20 0 w, 0 c, \ align "pad" to end of ROM loader-version# l, \ version# loader-format# w, \ "format" (>1 when crc present)
