Author: wmb Date: Wed Oct 24 20:37:38 2012 New Revision: 3380 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3380
Log: OLPC XO-1.75 - Script to modify fuse settings so that production 1 GHz MMP2 chips use the same speed code as 1 Ghz engineering sample chips.
Added: cpu/arm/mmp2/fusepgm.fth
Added: cpu/arm/mmp2/fusepgm.fth ============================================================================== --- /dev/null 00:00:00 1970 (empty, because file is newly added) +++ cpu/arm/mmp2/fusepgm.fth Wed Oct 24 20:37:38 2012 (r3380) @@ -0,0 +1,86 @@ +\ Script to change the speed code in 1 GHz production MMP2 chips to +\ match the old speed code value that was used for 1 GHz engineering +\ sample MMP2 chips. + +0 value fuse-block# +: fuse-ena! ( n -- ) h# 68 pmua! ; +: fuse-ena@ ( -- n ) h# 68 pmua@ ; + +: ena-fuse-module ( -- ) + \ Do not touch the enable register if it is already enabled. + \ That register also controls the interface between the SP and + \ PJ4 processors, which is used for keyboard communication. + \ The enabling process resets the device, causing system lockups + \ if the keyboard interface is active. + fuse-ena@ h# 1b = if exit then + + h# 08 fuse-ena! + h# 09 fuse-ena! + h# 19 fuse-ena! + h# 1b fuse-ena! +; + +: fuse-ctl! ( n -- ) + fuse-block# d# 18 lshift or h# 292804 io! + d# 100 ms +; + +: otp-setup ( -- ) + ena-fuse-module + h# 0002.0000 fuse-ctl! \ HiV + h# 0042.0000 fuse-ctl! \ Reset + HiV + h# 0002.0000 fuse-ctl! \ HiV +; +: otp-teardown ( -- ) + h# 0200.4000 fuse-ctl! \ ClkDiv + SOFT + h# 0240.4000 fuse-ctl! \ ClkDiv + SetRst + SOFT + h# 0200.4000 fuse-ctl! \ ClkDiv + SOFT +; + +: pgm-fuses2 ( v7 v6 v5 v4 v3 v2 v1 v0 block# -- ) + to fuse-block# ( v7 v6 v5 v4 v3 v2 v1 v0 ) + otp-setup ( v7 v6 v5 v4 v3 v2 v1 v0 ) + h# 292838 h# 20 bounds do i io! 4 +loop ( ) + + h# 0203.4000 fuse-ctl! \ ClkDiv + HiV + Burn + SOFT + begin h# 292984 io@ h# 100 and until \ Wait for complete + h# 0202.4000 fuse-ctl! \ ClkDiv + HiV + + SOFT + h# 0200.4000 fuse-ctl! \ ClkDiv + + SOFT + h# 0240.4000 fuse-ctl! \ ClkDiv + SetRst + SOFT + h# 0200.4000 fuse-ctl! \ ClkDiv + + SOFT + + otp-teardown +; + +2 value es-speed-1g \ This is the engineering sample speed code for 1 GHz parts +: fix-speed ( -- ) + ena-fuse-module + + \ Reprogram only if the divider values are the ones that we + \ observe in the first batch of production parts - indicating + \ that the SoC is not an engineering sample + h# 290c fuse@ h# 90001410 = if + + \ Reprogram only if the SW version field is 0 - a virgin part + \ that we have not yet reprogrammed + h# 2898 fuse@ 0= if + + \ If the speed code indicates a 988 MHz part, change the + \ speed code to the old engineering sample code for 1001 MHz + \ and reboot to switch to the higher speed + rated-speed 0= if + es-speed-1g d# 14 lshift 0 0 1 0 0 0 0 3 pgm-fuses2 + bye + then + + \ If the speed code has already been reprogrammed to the + \ engineering sample 1001 MHz value, but the SW version field + \ is 0, set the SW version field to 1. This fixes an initial + \ batch of 200 chips whose speed code was reprogrammed + \ using a different procedure. + rated-speed 2 = if + 0 0 0 1 0 0 0 0 3 pgm-fuses2 + then + then + then +;
