Author: quozl Date: Thu Feb 14 06:01:19 2013 New Revision: 3555 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3555
Log: OLPC - startup sound. Avoid searching jffs2 filesystem on XO-1 because mounting it takes a long time. Avoid checking for file existence; just try and if we fail, fallback to the built-in sound. Avoids one microSD or eMMC power cycle from boot on XO-1.5, XO-1.75, and XO-4 when the startup sound is present.
Modified: cpu/x86/pc/olpc/sound.fth
Modified: cpu/x86/pc/olpc/sound.fth ============================================================================== --- cpu/x86/pc/olpc/sound.fth Thu Feb 14 05:37:52 2013 (r3554) +++ cpu/x86/pc/olpc/sound.fth Thu Feb 14 06:01:19 2013 (r3555) @@ -28,13 +28,20 @@ : softer ( -- ) -2 +volume ; : louder ( -- ) 2 +volume ;
-" int:\boot\jingle.wav" d# 128 config-string jingle -: sound-name$ ( -- adr len ) - jingle $file-exists? if - jingle - else - " rom:splash" - then +: sound-int? ( -- error? ) + " int:\boot\jingle.wav" ['] $play-wav catch dup if nip nip then +; + +: sound-rom? ( -- error? ) + " rom:splash" ['] $play-wav catch dup if nip nip then +; + +: (sound) + [ifdef] jffs2-support + sound-rom? drop \ jffs2 is very slow to mount + [else] + sound-int? if sound-rom? drop then + [then] ;
: sound ( -- ) @@ -42,7 +49,7 @@ playback-volume >r get-saved-volume to playback-volume ['] load-started behavior >r ['] noop to load-started - sound-name$ ['] $play-wav catch if 2drop then + (sound) r> to load-started r> to playback-volume ;
