Author: quozl Date: Wed Feb 13 08:36:31 2013 New Revision: 3544 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3544
Log: mkdropin - again fix calculation of ending address for reserved area skip, by adding the pad to 4-byte boundary. A build using builder.dic from before svn 3540 had the reserved header exactly at reserved-start. See also svn 1980. Regenerated ARM builder using koji2.laptop.org.
Modified: cpu/arm/build/builder.dic forth/lib/mkdropin.fth
Modified: cpu/arm/build/builder.dic ============================================================================== Binary file (source and/or target). No diff available.
Modified: forth/lib/mkdropin.fth ============================================================================== --- forth/lib/mkdropin.fth Tue Feb 12 06:19:52 2013 (r3543) +++ forth/lib/mkdropin.fth Wed Feb 13 08:36:31 2013 (r3544) @@ -130,13 +130,13 @@ dup 4 round-up swap ?do 1 ofd @ fputc loop ( ) ; : write-dropin ( adr len expanded-len name-str -- ) - 2>r >r ( adr len r: name$ expanded-len ) + 2>r >r ( adr len r: name$ expanded-len )
- \ Calculate expected ending position - dup ofd @ ftell h# 20 + + ( adr len pos ) + \ Calculate expected ending file position + ofd @ ftell over 4 round-up + h# 20 + ( adr len pos )
\ Encroaches upon manufacturing data area? If so, enumerate as a dropin. - reserved-start h# 20 - reserved-end within if + reserved-start reserved-end within if \ Calculate size of a dropin covering reserved area reserved-end ofd @ ftell - h# 20 - ( adr len reslen ) \ Allocate memory for it
