Author: wmb Date: 2009-01-28 18:09:50 +0100 (Wed, 28 Jan 2009) New Revision: 1087
Modified: cpu/x86/pc/biosints.fth cpu/x86/pc/olpc/fw.bth cpu/x86/pc/olpc/gui.fth cpu/x86/pc/olpc/security.fth Log: OLPC - default to pretty boot even when not secure.
Modified: cpu/x86/pc/biosints.fth =================================================================== --- cpu/x86/pc/biosints.fth 2009-01-28 17:08:08 UTC (rev 1086) +++ cpu/x86/pc/biosints.fth 2009-01-28 17:09:50 UTC (rev 1087) @@ -1102,7 +1102,11 @@ 0 0 " " " /" begin-package " xp" device-name : open - " sd:1" ntfs? if " sd:0" set-hd-boot true exit then + " sd:1" ntfs? if + " sd:0" set-hd-boot + dcon-unfreeze unfreeze + true exit + then false ; : close ;
Modified: cpu/x86/pc/olpc/fw.bth =================================================================== --- cpu/x86/pc/olpc/fw.bth 2009-01-28 17:08:08 UTC (rev 1086) +++ cpu/x86/pc/olpc/fw.bth 2009-01-28 17:09:50 UTC (rev 1087) @@ -616,11 +616,11 @@ secure-startup unblock-exceptions ['] (interrupt-auto-boot?) to interrupt-auto-boot? - text-on - banner ?usb-keyboard auto-boot
+ unfreeze visible + blue-letters ." Type 'help' for more information." black-letters cr cr
Modified: cpu/x86/pc/olpc/gui.fth =================================================================== --- cpu/x86/pc/olpc/gui.fth 2009-01-28 17:08:08 UTC (rev 1086) +++ cpu/x86/pc/olpc/gui.fth 2009-01-28 17:09:50 UTC (rev 1087) @@ -393,16 +393,70 @@ : dcon-freeze ( -- ) 0 " set-source" $call-screen d# 30 ms ; : dcon-unfreeze ( -- ) 1 " set-source" $call-screen d# 30 ms ;
+\ === Stuff moved from security.fth === + +: text-on screen-ih stdout ! ; + +: visible dcon-unfreeze text-on ; + +0 0 2value next-icon-xy +0 0 2value next-dot-xy +d# 463 d# 540 2constant progress-xy + +: show-going ( -- ) + background-rgb rgb>565 progress-xy d# 500 d# 100 " fill-rectangle" $call-screen + d# 588 d# 638 to icon-xy " bigdot" show-icon + " vga?" $call-screen 0= if dcon-unfreeze dcon-freeze then +; +: show-x ( -- ) " x" show-icon ; +: show-sad ( -- ) + icon-xy + d# 552 d# 283 to icon-xy " sad" show-icon + to icon-xy +; +: show-lock ( -- ) " lock" show-icon ; +: show-unlock ( -- ) " unlock" show-icon ; +: show-plus ( -- ) " plus" show-icon ; +: show-minus ( -- ) " minus" show-icon ; +: show-child ( -- ) + " erase-screen" $call-screen + d# 552 d# 384 to icon-xy " rom:xogray.565" $show-opaque + progress-xy to next-icon-xy \ For boot progress reports +; + +0 [if] +: show-warnings ( -- ) + " erase-screen" $call-screen + d# 48 d# 32 to icon-xy " rom:warnings.565" $show-opaque + dcon-freeze +; +[then] + +0 value alternate? +: show-dot ( -- ) + next-dot-xy to icon-xy next-dot-xy d# 16 0 d+ to next-dot-xy ( ) + alternate? if " yellowdot" else " lightdot" then show-icon +; + +: show-dev-icon ( devname$ -- ) + next-icon-xy ( devname$ ) + 2dup to icon-xy ( devname$ ) + 2dup image-width 0 d+ to next-icon-xy ( devname$ ) + 2dup d# 5 d# 77 d+ to next-dot-xy ( devname$ ) + show-icon ( ) +; + : linux-hook-unfreeze [ ' linux-hook behavior compile, ] ; : linux-hook-freeze [ ' linux-hook behavior compile, ] - dcon-freeze + show-going ; : freeze ( -- ) ['] linux-hook-freeze to linux-hook ; : unfreeze ( -- ) ['] linux-hook-unfreeze to linux-hook ;
+ \ LICENSE_BEGIN \ Copyright (c) 2006 FirmWorks \
Modified: cpu/x86/pc/olpc/security.fth =================================================================== --- cpu/x86/pc/olpc/security.fth 2009-01-28 17:08:08 UTC (rev 1086) +++ cpu/x86/pc/olpc/security.fth 2009-01-28 17:09:50 UTC (rev 1087) @@ -3,19 +3,10 @@
\ Specs at http://wiki.laptop.org/go/Firmware_Security
-: text-on screen-ih stdout ! ; - -: visible dcon-unfreeze text-on ; - : ?unfreeze ( -- ) game-key@ button-check and if visible banner unfreeze then ;
-0 0 2value base-xy -0 0 2value next-xy -d# 463 d# 540 2constant progress-xy -d# 552 d# 283 2constant sad-xy - true value debug-security? : ?lease-debug ( msg$ -- ) debug-security? if type else 2drop then @@ -51,42 +42,12 @@ then ;
-: +icon-xy ( delta-x,y -- ) icon-xy d+ to icon-xy ; - -: show-going ( -- ) - background-rgb rgb>565 progress-xy d# 500 d# 100 " fill-rectangle" $call-screen - d# 588 d# 638 to icon-xy " bigdot" show-icon - " vga?" $call-screen 0= if dcon-unfreeze dcon-freeze then -; -: show-x ( -- ) " x" show-icon ; -: show-sad ( -- ) - icon-xy - sad-xy to icon-xy " sad" show-icon - to icon-xy -; : .security-failure ( error$ -- ) visible red-letters type black-letters cr show-sad security-failure ;
-: show-lock ( -- ) " lock" show-icon ; -: show-unlock ( -- ) " unlock" show-icon ; -: show-child ( -- ) - " erase-screen" $call-screen - d# 552 d# 384 to icon-xy " rom:xogray.565" $show-opaque - progress-xy to icon-xy \ For boot progress reports -; - -0 [if] -: show-warnings ( -- ) - " erase-screen" $call-screen - d# 48 d# 32 to icon-xy " rom:warnings.565" $show-opaque - dcon-freeze -; -[then] - - h# 20 buffer: cn-buf \ filename prefix - either "act" or "run" h# 20 buffer: fn-buf \ filename tail - either "os" or "rd" h# 100 buffer: pn-buf \ pathname - either "\boot" or "\boot-alt" @@ -617,8 +578,8 @@ then ( actual -eof? ) while ( actual ) sec-line-buf swap check-lease case ( -1|0|1 ) - 1 of r> close-file drop " unlock" show-icon true exit endof - -1 of r> close-file drop " lock" show-icon false exit endof + 1 of r> close-file drop show-unlock true exit endof + -1 of r> close-file drop show-lock false exit endof endcase repeat ( actual ) drop ( ) @@ -641,11 +602,6 @@ cn-buf place ;
-0 value alternate? -: show-dot ( -- ) - alternate? if " yellowdot" else " lightdot" then show-icon -; - : set-alternate ( -- ) button-o game-key? if true to alternate? exit then h# 82 cmos@ [char] A = if @@ -677,7 +633,7 @@ ['] load-path behavior >r ( r: xt ) ['] ramdisk-buf to load-path ( r: xt )
- d# 16 0 +icon-xy show-dot + show-dot \ cn-buf is already set as a result of the ?leased that \ happened before loading the OS file " rd" bundle-present? if @@ -856,16 +812,16 @@
: load-from-device ( devname$ -- done? )
- d# 16 0 +icon-xy show-dot + show-dot null$ cn-buf place " bootfw" bundle-present? if " FW found - " ?lease-debug
img$ firmware-up-to-date? if - " plus" show-icon + show-plus " current FW is up-to-date" ?lease-debug-cr else - " minus" show-icon + show-minus " new - " ?lease-debug fwkey$ to pubkey$ img$ sig$ fw-valid? if @@ -875,10 +831,10 @@ then then
- d# 16 0 +icon-xy show-dot + show-dot ?leased \ Sets cn-buf
- d# 16 0 +icon-xy show-dot + show-dot " os" bundle-present? if " OS found - " ?lease-debug oskey$ to pubkey$ @@ -904,20 +860,16 @@ ;
: load-from-list ( list$ -- devkey? ) - " dev /jffs2-file-system ' ?unfreeze to scan-callout dend" eval - begin dup while ( list$ ) ?unfreeze bl left-parse-string ( list$ devname$ ) 2dup dn-buf place ( list$ devname$ )
- show-icon ( list$ xy ) - icon-xy to base-xy - icon-xy image-width 0 d+ to next-xy ( list$ ) + show-dev-icon ( list$ )
filesystem-present? if ( list$ )
- d# 5 d# 77 +icon-xy show-dot ( list$ ) + show-dot ( list$ ) has-developer-key? if ( list$ ) 2drop ( ) true to security-off? @@ -933,14 +885,12 @@ " init-program" $find if set-cmdline execute - show-going go + go then show-x security-failure then then ( list$ ) - - next-xy to icon-xy ( list$ ) repeat ( list$ ) 2drop false ( ) ; @@ -967,18 +917,23 @@ \ button-rotate game-key? if show-warnings then show-child
- ?force-secure - - secure? 0= if visible unfreeze exit then - button-check game-key? if unfreeze visible banner else freeze dcon-freeze + + \ The following is a hack to let the user unfreeze the screen during + \ the several-second period while JFFS2 is scanning the NAND + " dev /jffs2-file-system ' ?unfreeze to scan-callout dend" eval then
- persistent-devkey? if true to security-off? visible unfreeze exit then + \ The screen may be frozen when we exit, because we want pretty + \ boot even when not secure.
+ ?force-secure + persistent-devkey? if true to security-off? exit then + secure? 0= if exit then + get-my-sn if " No serial number" .security-failure then
date-bad? if
