Author: wmb Date: Tue Sep 27 06:54:19 2011 New Revision: 2536 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2536
Log: OLPC XO-1.75 - version of low-level suspend-resume code that seems to be stable on SKU 198. There is a lot of commented-out stuff that needs cleanup, but I'm checking in this version for reference.
Modified: cpu/arm/mmp2/dramrecal.fth
Modified: cpu/arm/mmp2/dramrecal.fth ============================================================================== --- cpu/arm/mmp2/dramrecal.fth Sat Sep 24 02:38:55 2011 (r2535) +++ cpu/arm/mmp2/dramrecal.fth Tue Sep 27 06:54:19 2011 (r2536) @@ -59,22 +59,32 @@ here ddr-recal - constant /ddr-recal
label ddr-self-refresh ( r0:memctrl-va -- ) - dsb - mcr p15,0,r0,cr8,cr5,0 \ Invalidate TLB -\ mcr p15,0,r0,cr7,cr10,4 \ Write data synchronization barrier +\ dsb +\ mcr p15,0,r0,cr8,cr5,0 \ Invalidate TLB +\ \ mcr p15,0,r0,cr7,cr10,4 \ Write data synchronization barrier
mov r1, #0x1 \ Block all data requests str r1, [r0, #0x7e0] \ SDRAM_CTRL14
- ldr r1, [r0, #0x120] \ USER_INITIATED_COMMAND0 - bic r1, r1, #0xc0 \ USER_SR_REQUEST field - orr r1, r1, #0x40 \ Enter Self Refresh value - str r1, [r0, #0x120] \ USER_INITIATED_COMMAND0 +\ Latest test +\ ldr r1, [r0, #0x120] \ USER_INITIATED_COMMAND0 +\ bic r1, r1, #0xc0 \ USER_SR_REQUEST field +\ orr r1, r1, #0x40 \ Enter Self Refresh value +\ str r1, [r0, #0x120] \ USER_INITIATED_COMMAND0
\ This block was commented-out in the Linux code, and the value is incorrect for OLPC in any case \ mov r1, #0x03000000 \ PAD_TERM_SWITCH_MODE: Termination disabled \ orr r1, r1, #0x000a \ ODT{1,0}_SWITCH_MODE: Termination controlled by Read and Write enables \ str r1, [r0, #0x770] \ SDRAM_CTRL7_SDRAM_ODT_CTRL2 + \ OLPC + ldr r1, [r0, #0x770] \ SDRAM_CTRL7_SDRAM_ODT_CTRL2 + orr r1, r1, #0x03000000 \ PAD_TERM_SWITCH_MODE: Termination disabled + str r1, [r0, #0x770] \ SDRAM_CTRL7_SDRAM_ODT_CTRL2 + +\ mov r1, #0x1000000 \ Chip select 0 +\ orr r1, r1, #0x40 \ Enter Self Refresh value + mov r1, #0x40 \ Enter Self Refresh value + str r1, [r0, #0x120] \ USER_INITIATED_COMMAND0
\ Store registers in SRAM so CForth can see them, for debugging set r2, #0xd102.0400 @@ -85,7 +95,7 @@ bic r1,r1,#0x07700000 \ PHY_ADCM_ZPDRV: 0 PHY_ADCM_ZNDRV: 0 (Disable drivers 6:0) str r1, [r0, #0x1e0] \ PHY_CTRL8
- mov r1, #0x80000 str r1, [r0, #0x110] \ MMAP1 - breadcrumb + mov r1, #0x70000 str r1, [r0, #0x110] \ MMAP1 - breadcrumb
dsb \ Data Synchronization Barrier wfi \ Wait for interrupt @@ -100,8 +110,8 @@ \ orr r1, r1, #0x000a \ ODT{1,0}_SWITCH_MODE: Termination controlled by Read and Write enables \ str r1, [r0, #0x770] \ SDRAM_CTRL7_SDRAM_ODT_CTRL2
- mov r1, #0x80000000 \ PHY_SYNC_EN - str r1, [r0, #0x240] \ PHY_CTRL14 +\ mov r1, #0x80000000 \ PHY_SYNC_EN \ Wad suggests commenting out... +\ str r1, [r0, #0x240] \ PHY_CTRL14
\ There used to be code to set register 230, but Marvell says it is unnecessary.
@@ -111,18 +121,57 @@ mov r1, #0x40000000 \ DLL_UPDATE_EN str r1, [r0, #0x240] \ PHY_CTRL14
- ldr r1, [r0, #0x120] \ USER_INITIATED_COMMAND0 - bic r1, r1, #0xc0 \ USER_SR_REQUEST field - orr r1, r1, #0x80 \ Exit Self Refresh value +\ ldr r1, [r0, #0x120] \ USER_INITIATED_COMMAND0 +\ bic r1, r1, #0xc0 \ USER_SR_REQUEST field +\ orr r1, r1, #0x80 \ Exit Self Refresh value +\ str r1, [r0, #0x120] \ USER_INITIATED_COMMAND0 + +\ mov r1, #0x01000000 \ Chip select 0 +\ orr r1, r1, #0x80 \ Exit Self Refresh value + mov r1, #0x80 \ Exit Self Refresh value str r1, [r0, #0x120] \ USER_INITIATED_COMMAND0
- ldr r1, [r0, #0x80] \ SDRAM_CTRL1 - orr r1, r1, #0x40 \ DLL_RESET - str r1, [r0, #0x80] \ SDRAM_CTRL1 +\ ldr r1, [r0, #0x80] \ SDRAM_CTRL1 +\ orr r1, r1, #0x40 \ DLL_RESET +\ str r1, [r0, #0x80] \ SDRAM_CTRL1 + +\ mov r1, #0x01000000 \ Chip select 0 +\ orr r1, r1, #0x0100 \ USER_LMR0_REQ - Initiate Mode Register Set +\ str r1, [r0, #0x120] \ USER_INITIATED_COMMAND0 + + \ ZQ calibration long takes 512 memory clock cycles after a reset + \ At 400 MHz, that's a little more than 2 us. We spin here to + \ ensure that the recal is complete before we touch the DRAM again. + mov r1, #0x200 \ 512 spins, takes about 4 uS (from SRAM) + begin + decs r1, #1 + 0= until + + ldr r1, [r0, #0x770] \ SDRAM_CTRL7_SDRAM_ODT_CTRL2 + bic r1, r1, #0x02000000 \ PAD_TERM_SWITCH_MODE: Change 3 to 1 to enable termination for Read and Write + str r1, [r0, #0x770] \ SDRAM_CTRL7_SDRAM_ODT_CTRL2 + + \ ZQ calibration long takes 512 memory clock cycles after a reset + \ At 400 MHz, that's a little more than 2 us. We spin here to + \ ensure that the recal is complete before we touch the DRAM again. + mov r1, #0x20 \ 32 spins, takes about 16 uS (from SRAM) + begin + decs r1, #1 + 0= until
- mov r1, #0x01000000 \ Chip select 0 - orr r1, r1, #0x0100 \ USER_LMR0_REQ - Initiate Mode Register Set - str r1, [r0, #0x120] \ USER_INITIATED_COMMAND0 + +[ifdef] notdef + mov r1, #0x01000000 \ Chip select 0 + orr r1, r1, #0x00001000 \ Initiate ZQ calibration long + str r1, [r0, #0x120] \ USER_INITIATED_COMMAND0 + + \ ZQ calibration long takes 512 memory clock cycles after a reset + \ At 400 MHz, that's a little more than 2 us. We spin here to + \ ensure that the recal is complete before we touch the DRAM again. + mov r1, #0x20 \ 32 spins, takes about 16 uS (from SRAM) + begin + decs r1, #1 + 0= until
\ ldr r1, [r0, #0x120] \ USER_INITIATED_COMMAND0 \ bic r1, r1, #0xc0 \ USER_SR_REQUEST field @@ -133,15 +182,26 @@ begin decs r1,#1 0= until +[then]
mov r1, #0x0 \ Unblock data requests str r1, [r0, #0x7e0] \ SDRAM_CTRL14
dsb - mcr p15,0,r0,cr8,cr5,0 \ Invalidate TLB +\ mcr p15,0,r0,cr8,cr5,0 \ Invalidate TLB
+ mov r1, #0x10000 \ 64k spins, takes about 32 mS (from SRAM) + begin + decs r1,#1 + 0= until + + set r2, #0xd102.0440 + stmia r2, {r0-r15} + + mov r1, #0x90000 str r1, [r0, #0x110] \ MMAP1 - breadcrumb + mov pc, lr end-code here ddr-self-refresh - constant /ddr-self-refresh @@ -180,10 +240,12 @@ set r1,`'ddr-self-refresh #` \ Address of ddr-self-refresh routine in SRAM mov r7,sp set sp,`'ddr-self-refresh-sp #` + ldr r2,[r1] \ Force the code translation into the TLB + ldr r3,[r0,#0x110] \ Force the memory controller translation into the TLB mov lr,pc mov pc,r1
- mov r1,#0x90000 str r1,[r0,#0x110] \ MMAP1 - breadcrumb + mov r1,#0xa0000 str r1,[r0,#0x110] \ MMAP1 - breadcrumb mov sp,r7 c;
@@ -794,7 +856,6 @@ do-self-refresh ( )
hdd-led-on - h# a0000 breadcrumb
restore-run-state \ end mmp2_cpu_do_idle()
