Author: wmb Date: Sat Jun 4 08:48:27 2011 New Revision: 2244 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2244
Log: Fixed decompiler problem - it was failing to display the names of some data types. The code to display them existed, but wasn't enabled due to a search order problem.
Modified: forth/lib/objects.fth
Modified: forth/lib/objects.fth ============================================================================== --- forth/lib/objects.fth Sat Jun 4 00:56:50 2011 (r2243) +++ forth/lib/objects.fth Sat Jun 4 08:48:27 2011 (r2244) @@ -160,6 +160,7 @@ -level \ Exit temporary compile state, perhaps run word ;
+also hidden [ifdef] object-definer : (object-definer) ( action-acf -- definer ) dup /n - @ ( action-acf #actions ) @@ -172,8 +173,9 @@ ta1+ dup probably-cfa? until ; -also hidden ' (object-definer) is object-definer previous +' (object-definer) is object-definer [then] +previous
\ action-compiler: to action-compiler: addr
