Author: wmb Date: Thu Aug 16 04:16:12 2012 New Revision: 3181 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3181
Log: OLPC ARM - Tweaks to the last EDI checkin so that EDI operations are always bracketed exactly the same way, with use-edi-spi ... use-ssp-spi
Modified: cpu/arm/olpc/build-fw.fth cpu/arm/olpc/ecflash.fth
Modified: cpu/arm/olpc/build-fw.fth ============================================================================== --- cpu/arm/olpc/build-fw.fth Thu Aug 16 04:01:14 2012 (r3180) +++ cpu/arm/olpc/build-fw.fth Thu Aug 16 04:16:12 2012 (r3181) @@ -195,13 +195,14 @@ fload ${BP}/cpu/arm/olpc/ecflash.fth
: ec-spi-reprogrammed ( -- ) - edi-spi-start + use-edi-spi spi-start set-ec-reboot unreset-8051 + use-ssp-spi ;
: ignore-power-button ( -- ) - edi-spi-start + use-edi-spi edi-open-active ['] reset-8051 catch if ['] reset-8051 catch if ." Write Protected EC" cr then
Modified: cpu/arm/olpc/ecflash.fth ============================================================================== --- cpu/arm/olpc/ecflash.fth Thu Aug 16 04:01:14 2012 (r3180) +++ cpu/arm/olpc/ecflash.fth Thu Aug 16 04:16:12 2012 (r3181) @@ -66,6 +66,7 @@ ." Restarting EC and rebooting" cr set-ec-reboot unreset-8051 + use-ssp-spi [then] ec-power-cycle ; @@ -79,6 +80,7 @@ [else] use-edi-spi edi-open flash-buf /ec-flash 0 edi-read-flash + use-ssp-spi [then] ; : save-ec-flash ( "name" -- )
