Author: quozl Date: Tue Jun 14 04:20:57 2011 New Revision: 2272 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2272
Log: OLPC XO-1.75 trac #10919 - tune accelerometer selftest based on two more laptop samples.
Modified: cpu/arm/olpc/1.75/accelerometer.fth
Modified: cpu/arm/olpc/1.75/accelerometer.fth ============================================================================== --- cpu/arm/olpc/1.75/accelerometer.fth Tue Jun 14 04:17:05 2011 (r2271) +++ cpu/arm/olpc/1.75/accelerometer.fth Tue Jun 14 04:20:57 2011 (r2272) @@ -55,9 +55,12 @@
\ The datasheet says the selftest change range is 3 to 32, but we \ give a little headroom on the high end to allow for external -\ vibration. Empirically, on the unit I tested, the measurement -\ was maxed out at 32. Typical is supposed to be 19. -: out-of-range? ( delta -- error? ) 3 d# 40 between 0= ; +\ vibration. Typical is supposed to be 19. +\ Empirically, measured maximums were: +\ - Mitch's unit, 32 +\ - James' A3, 41 (on rubber mat on bare ground) +\ - James' A2, 39 +: out-of-range? ( delta -- error? ) 3 d# 50 between 0= ;
: error? ( dx dy dz -- error? ) out-of-range? if ." X axis error" cr 2drop true exit then ( dx dy )
