Author: wmb Date: Sat Oct 1 21:49:30 2011 New Revision: 2560 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2560
Log: OLPC XO-1.75 - this change goes with svn 2556 to implement YCrCv support.
Modified: cpu/arm/olpc/1.75/lcd.fth
Modified: cpu/arm/olpc/1.75/lcd.fth ============================================================================== --- cpu/arm/olpc/1.75/lcd.fth Sat Oct 1 19:48:05 2011 (r2559) +++ cpu/arm/olpc/1.75/lcd.fth Sat Oct 1 21:49:30 2011 (r2560) @@ -85,9 +85,8 @@ \ 5:YUV422packed 6:YUV422planar 7:YUV420planar 8:SmartPanelCmd \ 9:Palette4bpp A:Palette8bpp B:RGB888A : set-video-mode ( mode -- ) - d# 20 lshift ( x00000 ) h# 190 lcd@ ( x00000 regval ) - h# f00000 invert and ( x00000 regval' ) + h# f0.000e invert and ( x00000 regval' ) or ( regval' ) h# 190 lcd! ( ) ; @@ -95,14 +94,17 @@ : video-off ( -- ) h# 190 lcd@ 1 invert and h# 190 lcd! ; : set-video-dma-adr ( adr -- ) h# 0c0 lcd! ;
-\ Assumes RGB565 -: start-video ( adr w h -- ) - clear-unused-regs normal-hsv ( adr w h ) - over 2* h# 0e0 lcd! ( adr w h ) \ Pitch - width * 2 bytes/pixel - placement ( adr ) - set-video-dma-adr ( ) \ Video buffer - 0 set-video-mode ( ) \ RGB565 - d# 255 set-video-alpha ( ) \ Opaque video +defer foo ' noop to foo + +: start-video ( adr w h ycrcb? -- ) + >r ( adr w h r: ycrcb? ) + clear-unused-regs normal-hsv ( adr w h r: ycrcb? ) + over 2* h# 0e0 lcd! ( adr w h r: ycrcb? ) \ Pitch - width * 2 bytes/pixel for RGB565, width for YCrCr4:2:2 + placement ( adr r: ycrcb? ) + set-video-dma-adr ( r: ycrcb? ) \ Video buffer + r> if h# 50.000e else 0 then set-video-mode ( ) + d# 255 set-video-alpha ( ) \ Opaque video + foo video-on ; : stop-video ( -- ) video-off ;
