Author: wmb Date: 2009-12-16 08:56:51 +0100 (Wed, 16 Dec 2009) New Revision: 1622
Modified: dev/olpc/viacamera/camera.fth Log: Via diagnostics - don't fail the camera test if serial is preventing it from running.
Modified: dev/olpc/viacamera/camera.fth =================================================================== --- dev/olpc/viacamera/camera.fth 2009-12-16 07:24:34 UTC (rev 1621) +++ dev/olpc/viacamera/camera.fth 2009-12-16 07:56:51 UTC (rev 1622) @@ -507,7 +507,7 @@ : selftest ( -- error? ) serial-enabled? if ." The serial port is in use so the camera cannot be used" cr - true exit + false exit then open 0= if true exit then d# 300 ms
