Author: wmb Date: Wed Mar 6 20:53:52 2013 New Revision: 3594 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3594
Log: wrapper.c - added commentary telling another way to accomplish the same result as mprotect()ing the dictionary memory to make it executable.
Modified: forth/wrapper/wrapper.c
Modified: forth/wrapper/wrapper.c ============================================================================== --- forth/wrapper/wrapper.c Wed Mar 6 19:55:27 2013 (r3593) +++ forth/wrapper/wrapper.c Wed Mar 6 20:53:52 2013 (r3594) @@ -2201,6 +2201,13 @@ return 0L; #endif #if defined(__linux__) && defined(ARM) + /* There is another way to achieve the goal of making the */ + /* dictionary executable. You can add "-Wl,-z,execstack" */ + /* to the cc command line or add "-z execstack" to the ld */ + /* command line. mprotect() is perhaps more precise, making */ + /* only the dictionary executable while leaving the stack */ + /* protected, although that is probably pointless since */ + /* the whole point of this program is code injection. */ mprotect(adr, len, PROT_READ | PROT_WRITE | PROT_EXEC); __clear_cache(adr, adr+len); return 0L;
