Author: wmb Date: Wed Aug 4 18:51:00 2010 New Revision: 1912 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/1912
Log: OLPC NANDblaster - added nb-update and related words to make the XO-1.5 syntax for NANDblasting very similar to the XO-1 syntax.
Modified: cpu/x86/pc/olpc/fw.bth cpu/x86/pc/olpc/nandcastui.fth cpu/x86/pc/olpc/nb15tx.fth cpu/x86/pc/olpc/wifichannel.fth
Modified: cpu/x86/pc/olpc/fw.bth ============================================================================== --- cpu/x86/pc/olpc/fw.bth Wed Aug 4 11:08:59 2010 (r1911) +++ cpu/x86/pc/olpc/fw.bth Wed Aug 4 18:51:00 2010 (r1912) @@ -465,8 +465,8 @@
create use-mesh fload ${BP}/cpu/x86/bootascall.fth -fload ${BP}/cpu/x86/pc/olpc/nandcastui.fth fload ${BP}/cpu/x86/pc/olpc/wifichannel.fth +fload ${BP}/cpu/x86/pc/olpc/nandcastui.fth fload ${BP}/cpu/x86/pc/olpc/nbrx.fth fload ${BP}/cpu/x86/pc/olpc/fsupdate.fth
Modified: cpu/x86/pc/olpc/nandcastui.fth ============================================================================== --- cpu/x86/pc/olpc/nandcastui.fth Wed Aug 4 11:08:59 2010 (r1911) +++ cpu/x86/pc/olpc/nandcastui.fth Wed Aug 4 18:51:00 2010 (r1912) @@ -51,6 +51,10 @@ : #nb-update-def ( channel# -- ) >r " u:\fs.plc" " u:\fs.img" r> #nb-update ; : #nb-secure-def ( channel# -- ) >r " u:\fs.zip" " u:\fs.img" r> #nb-secure ;
+: nb-clone ( -- ) nb-auto-channel #nb-clone ; +: nb-secure ( -- ) nb-auto-channel #nb-secure-def ; +: nb-update ( -- ) nb-auto-channel #nb-update-def ; + : nb-clone1 ( -- ) 1 #nb-clone ; : nb-clone6 ( -- ) 6 #nb-clone ; : nb-clone11 ( -- ) d# 11 #nb-clone ;
Modified: cpu/x86/pc/olpc/nb15tx.fth ============================================================================== --- cpu/x86/pc/olpc/nb15tx.fth Wed Aug 4 11:08:59 2010 (r1911) +++ cpu/x86/pc/olpc/nb15tx.fth Wed Aug 4 18:51:00 2010 (r1912) @@ -47,6 +47,7 @@
" boot rom:nb_tx thinmac:OLPC-NANDblaster,%d %s %d 131072" sprintf eval ; + : #nb-secure ( zip-filename$ image-filename$ channel# -- ) depth 5 < abort" #nb-secure-update - too few arguments" >r 2>r ( placement-filename$ r: channel# image-filename$ ) @@ -57,7 +58,17 @@ ; : #nb-secure-def ( channel# -- ) >r " u:\fs.zip" " u:\fs.zd" r> #nb-secure ;
+: #nb-update-def ( channel# -- ) >r " u:\fs.zd" r> $nb-tx ; +: nb-update1 ( -- ) 1 #nb-update-def ; +: nb-update6 ( -- ) 6 #nb-update-def ; +: nb-update11 ( -- ) d# 11 #nb-update-def ; + +: nb-secure1 ( -- ) 1 #nb-secure-def ; +: nb-secure6 ( -- ) 6 #nb-secure-def ; +: nb-secure11 ( -- ) d# 11 #nb-secure-def ; + : nb-secure ( -- ) nb-auto-channel #nb-secure-def ; +: nb-update ( -- ) nb-auto-channel #nb-update-def ;
[ifdef] use-nb15-precomputed \ NANDblaster sender using thin firmware on XO-1.5, with precomputed
Modified: cpu/x86/pc/olpc/wifichannel.fth ============================================================================== --- cpu/x86/pc/olpc/wifichannel.fth Wed Aug 4 11:08:59 2010 (r1911) +++ cpu/x86/pc/olpc/wifichannel.fth Wed Aug 4 18:51:00 2010 (r1912) @@ -314,12 +314,6 @@ d# 4000 ms ;
-[ifdef] use-mesh -: nb-clone ( -- ) nb-auto-channel #nb-clone ; -: nb-secure ( -- ) nb-auto-channel #nb-secure-def ; -: nb-update ( -- ) nb-auto-channel #nb-update-def ; -[then] - : load-read ( filename$ -- ) open-dev dup 0= abort" Can't open file" >r ( r: ih ) load-base " load" r@ $call-method !load-size
