Author: wmb Date: 2009-10-10 03:04:57 +0200 (Sat, 10 Oct 2009) New Revision: 1415
Modified: cpu/x86/pc/olpc/via/startcominit.fth Log: Via - startup optimization to use new fast-path EC board ID command.
Modified: cpu/x86/pc/olpc/via/startcominit.fth =================================================================== --- cpu/x86/pc/olpc/via/startcominit.fth 2009-10-10 01:04:08 UTC (rev 1414) +++ cpu/x86/pc/olpc/via/startcominit.fth 2009-10-10 01:04:57 UTC (rev 1415) @@ -44,6 +44,7 @@ \ When the RTC is guarded against power glitches, there is a 50 mS delay before \ reads return the correct data upon wakeup from S3. On power-up, the delay is \ present even with the RTC unguarded. Unguarding it here speeds up S3 startup. + \ !! Not only does it affect the RTC, empirically it affects D17F0 Rx9Bh too! 81 ff 88 mreg \ Enable ACPI regs, 32-bit PM timer, disable RTC power glitch guard 4e 08 08 mreg \ Enable ports 74/75 for high-bank CMOS RAM access end-table @@ -52,50 +53,17 @@ 70 fb 82 mreg \ CPU to PCI flow control - CPU to PCI posted write, Enable Delay Transaction end-table
- \ Wait until RTC PSON Gating is complete. See PG_VX855_VX875_092 page 139 (pdf page 160) - \ This takes about 48 mS in the power-on case, and is almost instantaneous in the - \ resume-from-S3 case due to the clearing of D17F0 Rx81[2] above. - cx cx xor - begin cx inc 8882 config-rb h# 40 # al and 0<> until - cl al mov - h# 88 # al mov al h# 74 # out cl al mov al h# 75 # out - h# 89 # al mov al h# 74 # out ch al mov al h# 75 # out - d# 16 # cx shr - h# 8a # al mov al h# 74 # out cl al mov al h# 75 # out +\ rdtsc ax bx mov \ Mark time
- \ As an optimization to avoid long waits for the EC to respond, read the board ID - \ that is cached in CMOS RAM. - h# 83 # al mov al h# 74 # out h# 75 # al in \ check byte - should be ~board-id - al ah mov ah not \ ~check byte in AH - h# 82 # al mov al h# 74 # out h# 75 # al in \ board-id in AL + \ Read board ID from the EC + h# 62 # al in \ Read output register to ensure that OBF is clear + begin h# 66 # al in 2 # al test 0= until \ Wait IBF empty + h# d4 # al mov al h# 66 # out \ Write command 0xd4 + begin h# 66 # al in 1 # al test 0<> until \ Wait OBF full + h# 62 # al in \ Get the board ID
- al ah cmp 0<> if \ If the check byte matches, fall through with the ID in AL +\ rdtsc bx ax sub ax bx mov h# 4d0 config-setup bx ax mov ax dx out \ Elapsed time in BIOS scratch register
- \ If check byte is wrong, we have to ask the EC - - h# 6c # al in \ EC status register - 2 # al and \ input buffer full bit - 0<> if \ If the bit is nonzero, we can't send a command yet - \ We don't wait for the EC; if it is busy we assume B-test - \ It shouldn't be busy at this point because we haven't tried to talk to it yet - h# d1 # al mov \ EC busy - report B-test - else - h# 19 # al mov al h# 6c # out \ Send board ID command to EC - d# 200 # cx mov \ Wait up to 200 mS for the EC to respond - begin - d# 1000 wait-us \ 1 mS delay so we don't pound on the EC - h# 6c # al in \ Get status register - 3 # al and \ Check for output buffer full - 1 # al cmp - loopne - <> if \ Not equal means timeout - h# d1 # al mov \ EC timeout - report B-test - else - h# 68 # al in \ Get board ID byte from EC - then - then - then - \ Now AL contains the board ID h# d1 # al cmp u< if acpi-io-base h# 4c + port-rl h# 200000 bitclr ax dx out \ Turn off WLAN activity LED (GPIO10)
