Author: wmb Date: Wed Aug 11 10:50:37 2010 New Revision: 1934 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/1934
Log: SD driver - added the ability to disable high-speed operation on specific platforms.
Modified: dev/mmc/sdhci/sdhci.fth
Modified: dev/mmc/sdhci/sdhci.fth ============================================================================== --- dev/mmc/sdhci/sdhci.fth Wed Aug 11 10:48:52 2010 (r1933) +++ dev/mmc/sdhci/sdhci.fth Wed Aug 11 10:50:37 2010 (r1934) @@ -643,6 +643,24 @@ h# e data-timeout! \ 2^26 / 48 MHz = 1.4 sec ;
+false value avoid-high-speed? +: set-speed ( -- ) + avoid-high-speed? if + card-clock-25 + exit + then + + \ Ask if high-speed is supported + h# 00ff.fff1 switch-function d# 13 + c@ 2 and if \ cmd6 + h# 80ff.fff1 switch-function drop \ Perform the switch cmd6 + \ Bump the host controller clock + host-high-speed \ Changes the clock edge + card-clock-50 + else + card-clock-25 + then +; + : configure-transfer ( -- ) mmc? if 1-bit @@ -660,15 +678,7 @@ \ 1 for v1.10, and 2 for v2. get-scr c@ h# f and 0= if exit then \ acmd51
- \ Ask if high-speed is supported - h# 00ff.fff1 switch-function d# 13 + c@ 2 and if \ cmd6 - h# 80ff.fff1 switch-function drop \ Perform the switch cmd6 - \ Bump the host controller clock - host-high-speed \ Changes the clock edge - card-clock-50 - else - card-clock-25 - then + set-speed then ;
