Author: wmb Date: Wed Mar 10 18:35:32 2010 New Revision: 1771 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/1771
Log: Libertas WLAN driver improvements for adhoc multicasting.
Modified: dev/libertas.fth
Modified: dev/libertas.fth ============================================================================== --- dev/libertas.fth Wed Mar 10 10:30:58 2010 (r1770) +++ dev/libertas.fth Wed Mar 10 18:35:32 2010 (r1771) @@ -16,8 +16,8 @@ \ Interface to /supplicant support package 0 value supplicant-ih : $call-supplicant ( ...$ -- ... ) supplicant-ih $call-method ; -: do-associate ( -- flag ) " do-associate" $call-supplicant ; -: process-eapol ( adr len -- ) " process-eapol" $call-supplicant ; +: supplicant-associate ( -- flag ) " do-associate" $call-supplicant ; +: supplicant-process-eapol ( adr len -- ) " process-eapol" $call-supplicant ; : .scan ( adr -- ) " .scan" $call-supplicant ; : .ssids ( adr -- ) " .ssids" $call-supplicant ;
@@ -112,8 +112,10 @@
\ Data rates d# 14 constant #rates -create supported-rates 82 c, 84 c, 8b c, 96 c, 0c c, 12 c, 18 c, 24 c, - 30 c, 48 c, 60 c, 6c c, 00 c, 00 c, +\ create supported-rates 82 c, 84 c, 8b c, 96 c, 0c c, 12 c, 18 c, 24 c, +\ 30 c, 48 c, 60 c, 6c c, 00 c, 00 c, +create supported-rates 82 c, 84 c, 8b c, 96 c, 8c c, 92 c, 98 c, a4 c, + b0 c, c8 c, e0 c, ec c, 00 c, 00 c, #rates buffer: common-rates
external @@ -308,7 +310,7 @@ then ;
-: do-process-eapol ( adr len -- ) false to got-data? process-eapol ; +: do-process-eapol ( adr len -- ) false to got-data? supplicant-process-eapol ;
\ ========================================================================= \ Generic commands & responses @@ -1104,7 +1106,8 @@ atim +xw \ ATIM window 4 +x \ Reserved bytes
- cap +xw \ Capability info: ESS, short slot, WEP +\ cap +xw \ Capability info: ESS, short slot, WEP + 2 +xw \ Capability info: IBSS (WEP/WPA would add h# 10)
\ XXX 14 bytes for 802.11g, 8 bytes for 802.11b common-rates #rates +x$ \ Common supported data rates @@ -1352,10 +1355,12 @@ headers
: do-associate ( -- ok? ) - do-associate dup if + ['] 2drop to ?process-eapol \ Don't reenter the supplicant while associating + supplicant-associate dup if ds-disconnected reset-driver-state ds-associated set-driver-state then + ['] do-process-eapol to ?process-eapol ;
: ?reassociate ( -- ) @@ -1640,11 +1645,7 @@ ds-disconnected reset-driver-state else link-up? 0= if - ['] 2drop to ?process-eapol do-associate 0= if free-buf false exit then - ds-disconnected reset-driver-state - ds-associated set-driver-state - ['] do-process-eapol to ?process-eapol then start-nic then
