Author: wmb Date: Wed Sep 28 03:06:17 2011 New Revision: 2544 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2544
Log: OLPC XO-1.75 - suspend/resume test4 improvements - slightly longer cycle time to ensure at least one whole clock tick, display power info.
Modified: cpu/arm/mmp2/rtc.fth
Modified: cpu/arm/mmp2/rtc.fth ============================================================================== --- cpu/arm/mmp2/rtc.fth Wed Sep 28 03:04:52 2011 (r2543) +++ cpu/arm/mmp2/rtc.fth Wed Sep 28 03:06:17 2011 (r2544) @@ -48,7 +48,7 @@
int5-mask@ 1 invert and int5-mask! \ Unmask alarm enable-rtc-wakeup - 0 soc-rtc@ d# 1 + 4 soc-rtc! \ Set alarm for 3 seconds from now + 0 soc-rtc@ d# 2 + 4 soc-rtc! \ Set alarm for 2 seconds from now 7 8 soc-rtc! \ Ack old interrupts and enable new ones ['] cancel-alarm 5 interrupt-handler! 5 enable-interrupt @@ -91,15 +91,15 @@ key? until ; : test4 - begin - 0 d# 13 at-xy + d# 1000000 0 do + 0 d# 13 at-xy i .d 5 0 do - wake1 str cr i . + wake1 strp d# 500 ms - key? if unloop exit then + key? if unloop unloop exit then loop - again + 5 +loop ;
\ test3
