Author: wmb Date: Sat Sep 15 09:32:29 2012 New Revision: 3307 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3307
Log: OLPC XO-4 - Removed temporary upgrade-to-2m code, as it is now being done in a script in manufacturing.
Modified: dev/olpc/spiflash/spiui.fth
Modified: dev/olpc/spiflash/spiui.fth ============================================================================== --- dev/olpc/spiflash/spiui.fth Fri Sep 14 08:22:45 2012 (r3306) +++ dev/olpc/spiflash/spiui.fth Sat Sep 15 09:32:29 2012 (r3307) @@ -70,24 +70,9 @@ ;
[ifndef] 2meg h# 20.0000 constant 2meg [then] -: +1m ( offset -- offset' ) 1meg + ; - -\ This is for upgrading an XO-4 with a 2 MiB FLASH part from -\ a 1 MiB installed OFW image to a 2 MiB OFW image. -\ After flash-open, /flash is the size of the physical SPI FLASH device. -\ On exit, /flash is the size of the image, i.e. the amount to program. -\ /rom is the size of the image that is currently running. -: ?upgrade-to-2mb ( len -- len ) - flash-open \ Sets /flash according to the device installed - dup 2meg = /rom 1meg = and /flash 2meg = and if - signature-offset +1m to signature-offset - mfg-data-offset +1m to mfg-data-offset - crc-offset +1m to crc-offset - then -;
: ?image-valid ( len -- ) - flash-open \ Sets /flash according to the device installed + flash-open \ Sets /flash to the size of the SPI FLASH device /flash <> abort" Image file is the wrong length"
." Got firmware version: "
