Author: wmb Date: Wed Jul 6 04:20:34 2011 New Revision: 2330 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2330
Log: OLPC SP PS/2 interface - fixed locking and queuing problems that were causing flakiness in "menu" and "test mouse".
Modified: cpu/arm/olpc/spcmd.fth
Modified: cpu/arm/olpc/spcmd.fth ============================================================================== --- cpu/arm/olpc/spcmd.fth Wed Jul 6 04:17:56 2011 (r2329) +++ cpu/arm/olpc/spcmd.fth Wed Jul 6 04:20:34 2011 (r2330) @@ -41,7 +41,7 @@ 2 constant #ports #ports constant #queues
-d# 16 constant /q +d# 64 constant /q
0 value queue# #queues /n* buffer: heads : head ( -- adr ) heads queue# na+ ; @@ -61,6 +61,11 @@ dup @ q-end >= if 0 swap ! else /c swap +! then ;
+false value locked? \ Interrupt lockout for get-scan + +: lock ( -- ) true to locked? ; +: unlock ( -- ) false to locked? ; + : select-queue ( channel# -- error? ) to queue# queue# #queues >= @@ -73,14 +78,14 @@ ;
: deque? ( channel# -- false | entry true ) - select-queue if false exit then - lock[ + lock + select-queue if unlock false exit then head @ tail @ <> if q head @ ca+ c@ head inc-q-ptr true else false then - ]unlock + unlock ;
0 value reg-base @@ -89,21 +94,23 @@
: data? ( -- flag ) h# c8 reg@ 1 and ; : send-rdy ( -- ) h# ff00 h# 40 reg! ; + : poll ( -- ) - lock[ - data? if + begin data? while h# 80 reg@ wbsplit enque 1 h# c8 reg! send-rdy - then - ]unlock + repeat ;
0 instance value port# : set-port ( port# -- ) to port# ; : get-data? ( -- false | data true ) + locked? if false exit then + lock port# deque? ( false | data true ) poll + unlock ; : get-data ( -- data | -1 ) \ Wait for data from our device d# 1000 0 do @@ -131,7 +138,10 @@ open-count 1- 0 max to open-count ;
-: put-data ( byte -- ) port# bwjoin h# 40 reg! ; +: put-data ( byte -- ) + begin h# c4 reg@ 7 and 0= until + port# bwjoin h# 40 reg! +; : put-get-data ( cmd -- data | -1 ) put-data get-data ;
new-device
