Author: wmb Date: Fri Sep 23 00:38:28 2011 New Revision: 2525 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2525
Log: Fixed pingd, which has been broken for a long time.
Modified: ofw/inet/ping.fth
Modified: ofw/inet/ping.fth ============================================================================== --- ofw/inet/ping.fth Wed Sep 21 19:16:42 2011 (r2524) +++ ofw/inet/ping.fth Fri Sep 23 00:38:28 2011 (r2525) @@ -30,23 +30,17 @@ /packet-max buffer: packet
: get-packet? ( -- packet? ) - packet /packet-max " read" $call-net to /packet - /packet -1 = if cr ." Packet error" cr false exit then - /packet -2 = if false exit then - ." ." true + h# 800 " receive-ethernet-packet" $call-net if false exit then ( adr len ) + /packet-max min to /packet ( adr ) + packet /packet move ( ) + ." ." true ( packet ) ; d# 14 constant /ether-header 0 value ip-offset
: ip-header ( -- adr ) packet ip-offset + ;
-: ip? ( -- flag ) - ip-header c@ h# 45 = if - ip-header - then - - false -; +: ip? ( -- flag ) ip-header c@ h# 45 = ;
: link-level-ok? ( -- flag ) packet c@ h# 45 = if @@ -110,7 +104,10 @@ packet packet 6 + 6 exchange-bytes then ; -: exchange-ips ( -- ) ip-header d# 12 + dup 4 + 4 exchange-bytes ; +: 'ip-src ( -- adr ) ip-header d# 12 + ; +: 'ip-dst ( -- adr ) ip-header d# 16 + ; + +: exchange-ips ( -- ) 'ip-src 'ip-dst 4 exchange-bytes ; : change-type ( -- ) 0 ip-payload drop c! ; : recompute-ip-checksum ( -- ) 0 ip-header d# 10 + be-w! \ Zap IP checksum @@ -148,8 +145,7 @@ ;
: send-packet ( -- ) - packet /packet " write" $call-net - /packet <> if cr ." Send failed" cr then + packet /packet 'ip-dst h# 800 " send-link-packet" $call-net ;
: echo-packet ( -- ) @@ -162,7 +158,6 @@ ; : ?echo-packet ( -- ) ping? if - first? if .ip false to first? then echo-packet then ;
