Author: wmb Date: Fri Aug 17 01:27:02 2012 New Revision: 3186 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3186
Log: OLPC ARM - Finished adding USB properties.
Added: cpu/arm/olpc/cl4/usb.fth Modified: cpu/arm/olpc/cl4/fw.bth
Modified: cpu/arm/olpc/cl4/fw.bth ============================================================================== --- cpu/arm/olpc/cl4/fw.bth Fri Aug 17 01:25:00 2012 (r3185) +++ cpu/arm/olpc/cl4/fw.bth Fri Aug 17 01:27:02 2012 (r3186) @@ -17,7 +17,7 @@ fload ${BP}/cpu/arm/olpc/cl4/uart.fth fload ${BP}/cpu/arm/olpc/cl4/sdhci.fth fload ${BP}/cpu/arm/olpc/1.75/lcdcfg.fth -fload ${BP}/cpu/arm/olpc/1.75/usb.fth +fload ${BP}/cpu/arm/olpc/cl4/usb.fth fload ${BP}/cpu/arm/olpc/nn-touchscreen.fth fload ${BP}/cpu/arm/olpc/cl4/switches.fth fload ${BP}/cpu/arm/olpc/cl4/leds.fth
Added: cpu/arm/olpc/cl4/usb.fth ============================================================================== --- /dev/null 00:00:00 1970 (empty, because file is newly added) +++ cpu/arm/olpc/cl4/usb.fth Fri Aug 17 01:27:02 2012 (r3186) @@ -0,0 +1,17 @@ +purpose: Platform-specific USB elaborations +\ See license at end of file + +dev /usb@d4208000 + \ Port 1 on the hub is connected to unused pins on the WLAN connector, + \ so testing it is confusing + \ Port 2 is right upper + \ Port 3 is left + " 3,2" " usb-hub-test-list" string-property +device-end + +: (reset-usb-hub) ( -- ) + usb-hub-reset-gpio# gpio-clr d# 10 ms usb-hub-reset-gpio# gpio-set +; +' (reset-usb-hub) to reset-usb-hub + +devalias u /usb/disk
