Author: wmb Date: Wed Jan 19 23:47:46 2011 New Revision: 2121 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2121
Log: ARM assembler / disassembler enhancements thanks to Mike Tuciarone.
Modified: cpu/arm/assem.fth cpu/arm/disassem.fth
Modified: cpu/arm/assem.fth ============================================================================== --- cpu/arm/assem.fth Wed Jan 19 23:42:31 2011 (r2120) +++ cpu/arm/assem.fth Wed Jan 19 23:47:46 2011 (r2121) @@ -951,6 +951,7 @@ : bl 0b00.0000 {cond} amode-bbl ;
: bx 012f.ff10 {cond} amode-bx ; +: blx 012f.ff30 {cond} amode-bx ;
: swp 0100.0090 {cond} {b} amode-swp ; : strex 0180.0f90 {cond} {bh} amode-swp ;
Modified: cpu/arm/disassem.fth ============================================================================== --- cpu/arm/disassem.fth Wed Jan 19 23:42:31 2011 (r2120) +++ cpu/arm/disassem.fth Wed Jan 19 23:47:46 2011 (r2121) @@ -52,6 +52,7 @@ swap >mask and ( field ) ; : 4bits ( right-bit -- field ) 4 bits ; +: 8bits ( right-bit -- field ) 8 bits ; : bit? ( bit# -- f ) instruction @ 1 rot lshift and 0<> ; \ Extracts an index from the field "bit# #bits", indexes into the string \ "adr len", which is assumed to contain substrings of length /entry, @@ -83,12 +84,13 @@ : op.rd, ( -- ) op-col .rd, ; : .rb ( -- ) d# 16 .reg ; alias .rn .rb +: rn ( -- rn ) d# 16 4bits ;
: .rm,shift ( -- ) .rm - d# 4 8 bits if \ LSL #0 is no-shift; this isn't it + d# 4 8bits if \ LSL #0 is no-shift; this isn't it ., - 4 8 bits 6 = if ." rrx" exit then + 4 8bits 6 = if ." rrx" exit then 5 2 " lsllsrasrror" 3 .fld ." " 4 bit? if .rs else ." #" 7 5 bits .d then then @@ -96,7 +98,7 @@
: u.h ( n -- ) dup d# 9 u> if ." 0x" then (u.) type ; : ror ( n cnt -- ) 2dup d# 32 swap - lshift -rot rshift or ; -: .imm ( -- ) 0 8 bits 8 4bits 2* ror u.h ; +: .imm ( -- ) 0 8bits 8 4bits 2* ror u.h ;
: ?.bit ( adr len bit# -- ) bit? if type else 2drop then ;
@@ -159,6 +161,9 @@ ." wrc" {<cond>} op-col .rn ; +: .clz ( -- ) + ." clz" {<cond>} op.rd, .rm +; : .mrs/sr ( -- ) d#21 bit? if \ MSR instruction @ h# 00cf.fff8 and h# 0000.f000 = if @@ -169,6 +174,10 @@ .wrc exit then + instruction @ h# 0fff.0ff0 and h# 016f.0f10 = if + .clz + exit + then ." msr" {<cond>} op-col .psr .fields ., .r/imm else \ MRS @@ -198,9 +207,11 @@ : p-bit ( -- flag ) d#24 bit? ;
\ LD/ST extension space -\ SWP{<cond>} Rd, Rm, [Rn] cond 0001 00ZZ Rn Rd SBZ 1001 Rm \ LDR{<cond>}{H|SH|SB} Rd, Rm, [Rn] cond 000P UBW1 Rn Rd addr 1SH1 addr \ STR{<cond>}{H|SH|SB} Rd, Rm, [Rn] cond 000P UBW0 Rn Rd addr 1SH1 addr +\ SWP{<cond>}{B} Rd, Rm, [Rn] cond 0001 0BZZ Rn Rd SBZ 1001 Rm +\ LDREX{<cond>}{H|B} Rd, [Rn] cond 0001 1BH1 Rn Rd SBO 1001 SBO +\ STREX{<cond>}{H|B} Rd, Rm, [Rn] cond 0001 1BH0 Rn Rd SBO 1001 Rm : imm8 ( -- n ) 8 4bits 4 lshift 0 4bits or ; : ,.r/imm8 ( -- ) d#22 bit? if @@ -215,9 +226,20 @@ op.rd, .[ .rn p-bit if ,.r/imm8 .] {!} else .] ,.r/imm8 then ; -: .swp ( -- ) ." swp" {<cond>} " b" d#22 ?.bit op.rd, .rm ., .[ .rn .] ; +: .swp/ex ( -- ) + 8 4bits 0= if + ." swp" {<cond>} " b" d#22 ?.bit op.rd, .rm ., .[ .rn .] + else + .ld/st ." rex" {<cond>} + d#21 2 bits case + 1 of ." d" endof + 2 of ." b" endof + 3 of ." h" endof endcase + op.rd, d#20 bit? 0= if .rm ., then .[ .rn .] + then +;
-: .ld/st-ext ( -- ) 5 2 bits if .ldx else .swp then ; +: .ld/st-ext ( -- ) 5 2 bits if .ldx else .swp/ex then ;
: .ext ( -- ) \ Extension space d#24 bit? 0= 5 2 bits 0= and if .alu-ext else .ld/st-ext then @@ -322,7 +344,7 @@ [then] : p# ( -- n ) 8 4bits ; : .p#, ( n -- ) ." p" p# n.d ., ; -: .offset8 ( -- ) ." #" +/- 0 8 bits 4 * u.h ; +: .offset8 ( -- ) ." #" +/- 0 8bits 4 * u.h ; : .ldc/stc ( -- ) .ld/st ." c" {<cond>} " l" d#22 ?.bit op-col .p#, d# 12 .creg ., .[ .rn @@ -413,10 +435,29 @@ ['] .ldc/stc compile, \ 6 ['] .coproc compile, \ 7
+: uncond-op ( -- op ) d# 4 bit? ; +: uncond-op1 ( -- op1 ) d# 20 8bits ; +: uncond-op2 ( -- op2 ) d# 4 4bits ; + +: .uncond ( -- ) + uncond-op1 case + h# 57 of uncond-op2 case + 4 of ." dsb" endof + 5 of ." dmb" endof + 6 of ." isb" endof + endcase endof + ." ?" + endcase +; + : disasm ( x -- ) push-hex instruction ! - classes d#25 3 bits ta+ token@ execute + d# 28 4bits h# f = if + .uncond + else + classes d#25 3 bits ta+ token@ execute + then pop-base ;
