Author: lwalter Date: Wed Aug 10 00:42:06 2011 New Revision: 2453 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2453
Log: Automate video settings based on VC and VS descriptors
Modified: dev/usb2/device/common.fth dev/usb2/device/webcam/desc.fth dev/usb2/device/webcam/webcam.fth
Modified: dev/usb2/device/common.fth ============================================================================== --- dev/usb2/device/common.fth Tue Aug 9 20:41:09 2011 (r2452) +++ dev/usb2/device/common.fth Wed Aug 10 00:42:06 2011 (r2453) @@ -53,6 +53,8 @@ " iso-out-pipe" get-int-property to iso-out-pipe " iso-in-size" get-int-property to /iso-in-pipe " iso-out-size" get-int-property to /iso-out-pipe + " iso-in-interval" get-int-property to iso-in-interval + " iso-out-interval" get-int-property to iso-out-interval " intr-in-pipe" get-int-property to intr-in-pipe " intr-out-pipe" get-int-property to intr-out-pipe " intr-in-size" get-int-property to /intr-in-pipe
Modified: dev/usb2/device/webcam/desc.fth ============================================================================== --- dev/usb2/device/webcam/desc.fth Tue Aug 9 20:41:09 2011 (r2452) +++ dev/usb2/device/webcam/desc.fth Wed Aug 10 00:42:06 2011 (r2453) @@ -23,14 +23,14 @@ d# 32 constant MAX_FRAME_DESC \ Maximum number of frame descriptors/format 0 value #fdesc \ Number of uncompressed frame descriptors 0 value #alt \ Number of alternate interface descriptors -MAX_FRAME_DESC /n* 2* buffer: farray \ Array of width and height per frame -MAX_ALT_DESC /n* buffer: iarray \ Array of /payload per alternate interface +MAX_FRAME_DESC /n* 2* buffer: frame-array \ Array of width and height per frame +MAX_ALT_DESC /n* buffer: alt-array \ Array of /payload per alternate interface
: #fdesc! ( idx -- ) #fdesc max to #fdesc ; : #alt! ( idx -- ) #alt max to #alt ; -: alt-array! ( l idx -- ) /n* iarray + ! ; -: alt-array@ ( idx -- l ) /n* iarray + @ ; -: frame-array! ( w h idx -- ) /n* 2* farray + tuck na1+ ! ! ; +: alt-array! ( l idx -- ) /n* alt-array + ! ; +: alt-array@ ( idx -- l ) /n* alt-array + @ ; +: frame-array! ( w h idx -- ) /n* 2* frame-array + tuck na1+ ! ! ; : frame-array@ ( idx -- width height ) /n* 2* frame-array + dup @ swap na1+ @ ;
: process-vc ( idx -- ) @@ -40,7 +40,7 @@ ;
: process-vs-desc ( adr -- adr' ) - farray MAX_FRAME_DESC /n* 2* erase + frame-array MAX_FRAME_DESC /n* 2* erase begin dup desc-buf-end <> while ( adr ) dup 1+ c@ h# 24 <> if exit then \ CS_INTERFACE dup 2 + c@ case @@ -59,24 +59,24 @@ ;
: process-alt-desc ( idx adr -- ) - iarray MAX_ALT_DESC /n* erase ( idx adr ) + alt-array MAX_ALT_DESC /n* erase ( idx adr ) begin dup desc-buf-end <> while ( idx adr ) dup 1+ c@ 4 = if ( idx adr ) 2dup 2 + c@ = if \ Alternate INTERFACE descriptor dup 3 + c@ dup #alt! ( idx adr alt ) - swap c@ + ( idx alt adr' ) + swap dup c@ + ( idx alt adr' ) dup 1+ c@ 5 = if \ Endpoint descriptor tuck 4 + le-w@ swap alt-array! ( idx adr ) dup 3 + c@ 1 and 0= if abort" Expect isochronous endpoint" then dup 2 + c@ h# f and ( idx adr pipe ) - dup 6 + c@ ( idx adr pipe interval ) + over 6 + c@ ( idx adr pipe interval ) 2 pick 2 + c@ h# 80 and if to iso-in-interval to iso-in-pipe else to iso-out-interval to iso-out-pipe then then then then dup c@ + - repeat drop + repeat 2drop ;
: process-vs ( idx -- )
Modified: dev/usb2/device/webcam/webcam.fth ============================================================================== --- dev/usb2/device/webcam/webcam.fth Tue Aug 9 20:41:09 2011 (r2452) +++ dev/usb2/device/webcam/webcam.fth Wed Aug 10 00:42:06 2011 (r2453) @@ -49,31 +49,12 @@ then ;
-create samsung-frame-array - 0 , 0 , \ width height - h# 280 , h# 1e0 , - h# a0 , h# 78 , - h# b0 , h# 90 , - h# 140 , h# f0 , - h# 160 , h# 120 , - h# 320 , h# 258 , - h# 500 , h# 2d0 , - 0 value hint 5 value frame-idx h# 160 value width h# 120 value height width height * 2* value /frame \ 16-bit per pixel
-create samsung-alt-array - 0 , h# c0 , h# 180 , h# 200 , - h# 280 , h# 320 , h# 3b0 , h# a80 , - h# b20 , h# be0 , h# 1380 , h# 13fc , - -['] samsung-frame-array to frame-array \ Comment these 2 lines to use -['] samsung-alt-array to alt-array \ descriptor info - -\ Make sure the alt interface's endpoint and maxpayload matches d# 5 value alt-interface h# 320 value /payload d# 256 value #payload @@ -82,13 +63,13 @@ external : set-frame ( idx -- ) dup to frame-idx - /n * 2* frame-array + dup @ to width na1+ @ to height - width height * 2* to /frame + frame-array@ 2dup to height to width + * bytes/pixel * to /frame ;
: set-alt ( idx -- ) dup to alt-interface - alt-array swap na+ @ dup to /payload + alt-array@ dup to /payload dup h# 7ff and swap d# 11 >> 1+ * to /xlen ;
@@ -108,8 +89,6 @@
: init-stream \ Make sure the alt interface's endpoint and maxpayload matches - 1 to iso-in-pipe \ Remove when init is properly done - 1 to iso-in-interval \ Remove when init is properly done /payload iso-in-pipe set-pipe-maxpayload #payload iso-in-pipe iso-in-interval init-iso-in vs-interface alt-interface set-interface if abort" Failed to set alternate interface" then @@ -118,34 +97,34 @@ ; headers
-\ Algorithm for selecting a particular alternate interface and the corresponding -\ uncompressed resolution: +\ Algorithm for selecting a particular alternate interface and +\ the corresponding uncompressed resolution: \ -\ Empirically, when the webcam sends a video line of data out at a time, -\ ofw can process the video data reasonably well. +\ Empirically, when the webcam sends a video line of data out at +\ a time, ofw can process the video data reasonably well. \ -\ Thus, choose the largest payload bandwidth without employing MULT. -\ Then, choose a best match video resolution. +\ Thus, choose a video highest resolution that satisfy: +\ width*byte/pixel+c < h# 400 +\ Then, choose a best match alternate interface
+h# 400 constant MAX_PAYLOAD 0 value twidth 0 value tidx : select-alt ( -- idx ) 0 to tidx - 0 to twidth - #alt 1 do - i alt-array@ dup h# f800 and if - drop - else - dup twidth > if to twidth i to tidx else drop then - then + MAX_PAYLOAD to twidth + #alt 1+ 1 do + i alt-array@ dup h# 7ff and swap d# 11 >> 1+ * + dup width bytes/pixel * h# c + twidth between + if to twidth i to tidx else drop then loop tidx ; : select-frame ( -- idx ) 0 to twidth 0 to tidx - #fdesc 1 do + #fdesc 1+ 1 do i frame-array@ drop - dup bytes/pixel * h# c + /xlen <= if + dup bytes/pixel * h# c + MAX_PAYLOAD < if dup twidth > if to twidth i to tidx else drop then else drop @@ -154,11 +133,15 @@ ;
: set-params ( -- ) - ['] farray to frame-array - ['] iarray to alt-array - - select-alt set-alt select-frame set-frame + select-alt set-alt +; + +: int-property ( n name$ -- ) rot encode-int 2swap property ; +: make-properties ( -- ) + iso-in-pipe " iso-in-pipe" int-property + iso-in-interval " iso-in-interval" int-property + /payload " iso-in-size" int-property ;
: get-next-payload ( -- len ) @@ -235,8 +218,9 @@
: init ( -- ) init device set-target - ( init-params ) - ( set-params ) + init-params + set-params + make-properties ;
0 value selftest-adr
